Sufficiency/efficiency of twin 40s on 22'
qboat
City/Region: Delmarva
State or Province: DE
Vessel Name: Runt
PostPosted: Tue May 30, 2017 12:34 pm    Post subject: Sufficiency/efficiency of twin 40s on 22' Reply with quote
I am looking--from a distance--at several used C-22s. One has twin 40s--carbed Hondas. I don't want to restart the single/twin squabble that I see in the archives, but I do note that most singles are 90s or better, and I assume twins are less efficient than singles. Is performance with twin 40s OK? I don't need high top end speed, but when it is flat, I would like to be able to cruise 18-20 without straining the motors unduly. Is that possible with twin Honda 40s? As always, I appreciate any response. Sam
El and Bill
City/Region: Lakewood, CO
Vessel Name: Halcyon
Photos: Halcyon
PostPosted: Tue May 30, 2017 12:47 pm    Post subject: Reply with quote
In our many years and miles of living aboard and cruising on a 22' C-Dory, our twin 40hp Hondas were sufficient and efficient for us. We seldom needed to move fast, and enjoyed the efficiency of twin 40's. Often we were cruising with one up and the other purring us along just fine. It was the cruise, not the destination, that was our joy on the boat thru those years of living aboard.
El and Bill
Photos: Halcyon
PostPosted: Tue May 30, 2017 12:58 pm    Post subject: Reply with quote
check out our website cruisingamerica/halcyon days and click on the theme, fast or slow. We discuss this topic there.
CDory23
Photos: CDory23
PostPosted: Tue May 30, 2017 3:37 pm    Post subject: Reply with quote
I run a heavily loaded 22 and have carbed twin 40 yamahas. I would say the power is the least amount I'd like to have but gets the job done. 18 to 20 knots on flat seas should be easy if that's your concern. I have recently repropped from 13" to 11" and it has made a huge difference so be aware of the way you run your boat and the prop as well. If I upgraded I would do twin 60's or a single 115 with a 9.9 kicker.
I do a lot of run in choppy waters so most of the time i would never notice the difference in hp because our boats are "go slow" boats in those conditions and I generally limit speed to 14 knots.
If I was looking at a 22 C dory I really liked the twin 40's I wouldn't make me hesitate one bit. I can't emphasize enough how important Permatrims and the right prop are.
C-Green
City/Region: Houghton
Vessel Name: C-Green
Photos: C-Green
PostPosted: Tue May 30, 2017 10:25 pm    Post subject: Reply with quote
I run a heavy CD22 (lots of living gear) with carbed twin 40 Hondas with 11x11 4 bladed aluminum Solas props. WOT alone is at 58-5900 and with 3 other passengers at approximately 5500. I do 18 smph alone at 4500 or 4800 (can not quite remember) but prefer 14 smph at about 4000. I'd be pushing the engines trying to do 20 smph with 3 passengers - my sop is to run 1000 less than WOT for the load. Like CDory23 said, twin 40's are the least power I'd like but I rarely do 20 smph and am happy with the set up I have.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Wed May 31, 2017 7:23 am    Post subject: Reply with quote
Given the same load to push thru the water, the engine(s) with less cu in
displacement will work harder than an engine(s) with more cu in displacement.
This assumes both will be propped correctly, same Mfg, etc.
On a CD 22, the differences would be inconsequential with 'normal' use save
using less fuel with a single vs twin (more u/w drag and weight).
Aye.
smittypaddler
City/Region: Neenah, Wisconsin
Vessel Name: Na Waqa
PostPosted: Wed May 31, 2017 11:00 am    Post subject: 40s OK, but I'd like 50s Reply with quote
I have twin 40s on my 2004 CD-22 Cruiser. I bought twins for safety, figuring I could lose one engine and still get home. The engines have 1400 hours, and I've lost an engine once, and I was able to get home on the other. I cruise at wide open throttle most of the time, if waves allow, and unless I'm very heavily loaded, top out at 24 knots. However, I also take the family waterskiing, and often wish I had twin 50s. When these motors finally go (if ever) I'll upgrade to twin 50s.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Wed May 31, 2017 12:54 pm    Post subject: Reply with quote
I've never regretted going with the larger engine option.
Why? Because boats, like most people, get heavier with age.
Aye.
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Wed May 31, 2017 3:25 pm    Post subject: Reply with quote
I run with twin Yami 40s, the older carbed models. I get 18 knots with the boat heavey laden, which seems to be all the time. Probably 22/23 knots if light. Don't ask me about fuel consumption. I have never bothered to work it out.
If I was re-powering, I would go with the new twin Yami 50s.
Martin.
PostPosted: Wed May 31, 2017 4:34 pm    Post subject: Reply with quote
My previous 22 had twin, carbed Honda 40's. Without permatrims, wide open with a light load on flat water was about 30MPH or 26kts. For the 22, that's just about the speed where the boat feels a little squirrely - e.g. still controllable but on the edge of not having enough wetted surface to maintain control. Once I put on the permatrims, the top end speed dropped to about 28MPH or 24kts. I put over 1000 hours on the twin 40's with nary a problem. IMHO, they are plenty adequate but if I got a new 22, I'd probably put twin 50's on it or a single 90-115. For a used purchase, I wouldn't bat an eye at buying one with twin 40's.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Wed May 31, 2017 4:40 pm    Post subject: Reply with quote
I just sold my 26 Venture w/twin Honda 90s. I felt it did about everything I
asked of it including planing with 8 adults on board; an unusual event.
Still, now Honda has new 100 hp available, I do believe a pair of these would be
my choice if I opted to repeat. And it's not about speed in the CDory.
Aye.
PostPosted: Fri Jun 02, 2017 12:29 pm    Post subject: Reply with quote
Twin 40's. Totally efficient, adequatly sufficient. After 10 plus years with a 22 Cruiser and twin 40 Yamies, running a farly heavy cruising load I would agree with that. I have never needed more power, and only rarely pushed the throttles to the pegs, very rarely. (A few times for WOT test runs, and a couple of times in big 8 to 10 foot following seas.) Rarely over 2/3 or 3/4 throttle. Most of my cruise time is around 6 knots, and planning is around 15, easy at half throttle.
The boat was set up by a guy who was getting his 34th boat for his last and retirement boat. Guess he knew what he was doing. I would like twin 50s, and EFI, but I only have 1300 hours on and a long time to repower, so for the next while, my twin 40s are where it's at.
SleepyC
Karl
City/Region: NORTHERN
State or Province: NY
PostPosted: Tue Jun 06, 2017 3:19 am    Post subject: Reply with quote
Frankly, I would prefer a 90hp single + 9.9 kicker...
To me twins = 2x the maintenance costs, but will provide marginally better maneuverability with adequate separation distance, but will always cost more to maintain. And if one fails, the other could get you home at non-planing speeds.
Arguments for either choice.
PostPosted: Tue Jun 06, 2017 12:30 pm    Post subject: Reply with quote
Karl,
The arguments for twins vs single is almost like religion. Discussed a lot on the forum--those who have twins love them, and they have their posts. Those of us who prefer a single plus a kicker, have out points. (But single with a kicker is still maintaining two engines.)
PostPosted: Tue Jun 06, 2017 7:46 pm    Post subject: Reply with quote
True with one exception, "will provide marginally better maneuverability with adequate separation distance" I would beg to differ. Twins set up on a C-Dory provide considerably improved maneuverability when moving at slow (read marine and docking) speeds. It may not be religion, but it is definitely a subset of the sect species.
Page generation time: 0.0381s (PHP: 70% - SQL: 30%) - SQL queries: 28 - GZIP disabled - Debug on
