Drain plug
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Tue May 09, 2017 5:47 pm    Post subject: Drain plug Reply with quote
While doing maintenance on 49er, I removed the bilge drain plug and found it rusted and barely if at all functional - maybe why I was getting water in cockpit while under way. It's an expanding rubber and brass plug. Wondering if all of you use same or anything better?
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Tue May 09, 2017 6:00 pm    Post subject: Reply with quote
I use something similar and pull it about once per year just to inspect it (indoor storage). I also have a spare on board in case it fails or is lost.
I can see how it could corrode to the point of causing a minor leak.
Greg
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
PostPosted: Tue May 09, 2017 9:57 pm    Post subject: Reply with quote
Try and find one which is all bronze. Definitely something which needs inspection regularly,. There have also been a few instances where the tube has loosened and some water come in thru that area. On our 25, we pulled the drain plug, filled the area with thickened epoxy, redid the hole, and epoxied the tube in place.
My Catamaran has threaded bronze plugs--I feel quite a bit safer.
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Tue May 09, 2017 10:04 pm    Post subject: Reply with quote
Thanks Bob.
Page generation time: 0.0288s (PHP: 65% - SQL: 35%) - SQL queries: 17 - GZIP disabled - Debug on
