Led replacement bulbs
beachin
City/Region: Sebastian
Vessel Name: Dawn Treader
Photos: Dawn Treader
PostPosted: Tue Apr 25, 2017 2:16 pm    Post subject: Led replacement bulbs Reply with quote
I want to replace the two interior lite bulbs and two bulbs in the V-Birth, the bulbs are a #1004 bulb, I want to replace them with LED's. My boat is a 22ft cruiser 2006 yr. Any help would be appricated
PostPosted: Tue Apr 25, 2017 3:34 pm    Post subject: Reply with quote
http://store.marinebeam.com/replacement-bulbs/
Discovery
City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
PostPosted: Tue Apr 25, 2017 3:35 pm    Post subject: Reply with quote
Check Amazon. Here is an example https://www.amazon.com/10-Pack-18-SMD-Replacement-Backup-Parking/dp/B01N05KTTI/ref=sr_1_fkmr0_1?ie=UTF8&qid=1493148795&sr=8-1-fkmr0&keywords=1004+bulb+replacement+w%2Fled
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
PostPosted: Tue Apr 25, 2017 6:10 pm    Post subject: Reply with quote
These are the ones that replaced my nav lights.
https://www.amazon.com/gp/product/B00BWA6OEI/ref=ox_sc_sfl_title_48?ie=UTF8&psc=1&smid=A3IZHOEADOGAP0
I'm In the still looking for the ones that replaced my interior lights. In the mean time, these may have been them: https://www.amazon.com/10-Pack-18-SMD-Replacement-Backup-Parking/dp/B01N05KTTI/ref=sr_1_5?s=beauty&ie=UTF8&qid=1493157845&sr=8-5&keywords=Led+replacement+for+1004
Colby
PostPosted: Tue Apr 25, 2017 6:19 pm    Post subject: Reply with quote
I put one in above the Admiral's seat. Two birds. One stone.
http://store.marinebeam.com/red-white-switchable-led-for-dome-lights-un-dome-15-rww/
The rest I replaced with this:
http://store.marinebeam.com/9-led-bayonet-array-matrix-for-overhead-dome-lights-ba-15-09/
Check your plug...but they are top quality.
I did not change the nav lights since every time they are on, I am moving, ergo the engine is on and charging.
Bob&Alicia
City/Region: Athens
State or Province: GA
Photos: Bob&Alicia
PostPosted: Tue Apr 25, 2017 8:55 pm    Post subject: Reply with quote
I ordered from Marinebeam in 2015. I've been pleased. Below is my order. The G4 was for another boat. I have a Perko anchor light and used the Cool White for it. Very bright. I returned the Warm White.
I can have the LED anchor light plus another LED light on inside and draw less amps than one incandescent original bulb did.
I really do like the switchable white/red. I put one over the table. Makes it bright enough to see inside but you can still look out over the anchorage. The other one is in the Head. Nice to have a light in there and it doesn't wake the spouse up. If one of the plain white ones goes out I will replace with the red/white.
I need to order some LED for the cockpit courtesy lights. I keep forgetting to look at the size.
2 x 9-LED Bayonet Array Matrix for Overhead Dome Lights (BA-15-09)
(Base Type: Double-Contact BA15D, Output Color: Warm White)
1 x Replacement for GE89 and GE90 Attwood & Perko Bayonets
(Output Color: Warm White, Base Type: Double Contact)
(Output Color: Cool White, Base Type: Double Contact)
2 x G4 LED Bulb 6-LED Power Cluster - Novi
(Output Color: Warm White)
2 x Red/White "Switchable" LED for Dome Lights
(Base Type: Double-Contact (BA15d))
Bob and Alicia
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Tue Apr 25, 2017 9:29 pm    Post subject: LED Reply with quote
Replace any and all C-Dory lights with LED'S from Marinebeam, and you'll be glad you did. Great customer service and knowledge base, best quality (not low bid Chinese on Amazon).
Buy Quality the first time and you'll be glad in the long run.
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150
PostPosted: Tue Apr 25, 2017 11:50 pm    Post subject: Reply with quote
For the Perko interior lights I used the flat LED array "bulbs". They come with adapters to connect to the regular festoon bulb holders. I just wired them directly though. You do need to modify the Perko fixture a little to hold the array (small piece of wood or plastic). I got mine off eBay for about $1.50 each. Get the warm white color to replicate the incandescent bulbs that you remove.
Yes, they are a lot cheaper than the Marinebeam replacements. But they've worked fine going on 4 years now. Replacing all the incandescent bulbs with LEDs was one of the first things I did when I bought my boat.
FWIW. I used the Marinebeam LED replacement for my anchor light. It was around $25 (with shipping). It is way brighter than the incandescent bulb it replaced. It lights up the whole top of the boat and the front deck.
PostPosted: Wed Apr 26, 2017 9:15 am    Post subject: Reply with quote
http://www.c-brats.com/modules.php?set_albumName=album1405&op=modload&name=gallery&file=index&include=view_album.php
PostPosted: Wed Apr 26, 2017 11:22 am    Post subject: Reply with quote
From what I read, it is better to use the "warm" white bulbs for the interior lights (more incandescent like) and the cool white (or led white) bulbs for the anchor light (stands out more).
PostPosted: Wed Apr 26, 2017 12:22 pm    Post subject: Reply with quote
It's what I did, exactly. The cool white is much "whiter". (am I allowed to even say that?)
PostPosted: Thu Apr 27, 2017 1:53 am    Post subject: Reply with quote
Yes Mark you are Wink
and I did the same.
I replaced the interior lights with new fixtures with 2-way switches, white or red, (2 in the cabin, and one in the birth). The nav lights got replaced too, I was tired of replacing bulbs every year due to (I think) vibration. Seems they would work until I trailered home, then quit. I also replace the anchor light, with a Perko 30 inch, aluminum pole LED. Now it clears the inflatable when it is up on the rack, and it is definitely brighter (whiter) than the incandescent OEM.
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Thu Jul 14, 2022 10:09 am    Post subject: Reply with quote
I changed all the bulbs on my 22 to LED. Go to a RV shop, they cost 75% less than a marine chandler. You can buy them online but if any arrive not working you have the hassle of sending them back and getting replacements. Buy from the RV shop and they replace any duds no questions asked.
Martin.
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Thu Jul 14, 2022 11:54 am    Post subject: Reply with quote
I replaced all of my interior lights for $15.
https://www.amazon.com/10-6500K-Replacement-Interior-Trailer-Lighting/dp/B07F5XQ8W1
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
KoolBrobrat
City/Region: Central
PostPosted: Tue May 23, 2023 7:33 pm    Post subject: Reply with quote
I plan to change all my lights to Led. Thanks for sharing!
Laugh, Live, and love!
Page generation time: 0.0446s (PHP: 70% - SQL: 30%) - SQL queries: 28 - GZIP disabled - Debug on
