OB motor smoking on startup- Thank goodness for the internet
BTDT
City/Region: Grand Lake Oklahoma
State or Province: OK
Photos: C-Lark
PostPosted: Mon Oct 17, 2016 2:03 pm    Post subject: OB motor smoking on startup- Thank goodness for the internet Reply with quote
Had some cold chills run through me when my outboard motors started smoking on first startup after several days of sitting. Went to Honda forums and found this response to my search:
"you are lowering your motors down to low after use and oil is running down into cylinders and getting past the rings. Leave motors up a bit so oil cannot drain down past rings .. at least leave them level................. not tilted back .................problem will go away"
I keep my Tomcat on a lift and for some unknown reason I had started putting my motors all the way down before entering the marina. I followed his/her instructions and sure enough....smoking problem gone.
How did I survive without forums, blogs, youtube, and search engines?
John & Vicki Clark
C-Lark Wine Down
Tomcat 255
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Fri Apr 14, 2017 8:13 pm    Post subject: TC255 WGT Reply with quote
Hi John!
Private Msg here:
Liked your pic of the transom backrest!
The only TC255 owners who have ever posted actual certified scale wgts for their rigs are me (first) and you and 1 other.
My Grand Totals on 3 Heavy Cruise Mode trips to Key West have been #18,050, #17,840, and #17,800 CAT Certified Scales, all at 1/4-1/2 full gas.
Un-hitched boat wgts all #11,000-#12,000.
Your pic is #13,000+ Grand Total Rig Wgt...what gives?
Over 250 Brats have looked at it, I hope it's right.
I just can't help but think you got a wgt on the 'trailer' on 1 scale while it was hitched up to your truck (add up to #1,200 hitch wgt).
I can't explain the remaining significant difference...can you?.
I'd be interested in your opinions. (I didn't look up the difference in 1500/2500 truck wts).
Hope to see you and Vicki at the Miss Gathering in Sept!
Happy Boating!
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
2024 Yamaha F150xsa x2
Fairbro
City/Region: Prescott
Vessel Name: Minnie Swann
Photos: Minnie Swann
PostPosted: Sat Apr 15, 2017 8:45 am    Post subject: Reply with quote
I spent many years wondering about that. This phenomenon was further mystifying in that only one of the twins did it. It must have sat a little lower. I always ran my motors full down around the docks too. I figured it gave me better control. Oh well, it kept me checking the oil regularly.
It's something in the water!
BTDT
Photos: C-Lark
PostPosted: Sat Apr 15, 2017 8:55 am    Post subject: Reply with quote
Only my port engine smokes if I leave both motors down Shocked
BTDT
Photos: C-Lark
PostPosted: Sat Apr 15, 2017 9:01 am    Post subject: Re: TC255 WGT Reply with quote
deleted - repeat post
BTDT
Photos: C-Lark
PostPosted: Sat Apr 15, 2017 9:05 am    Post subject: Re: TC255 WGT Reply with quote
gulfcoast john wrote:
Hi John!
Happy Boating!
That's exactly what I did. The boat and trailer are parked on a separate scale and together weighed 9300 lbs. Add 10% for tongue weight and the tow configuration is over 10K. My plan was to disconnect the truck but two semi's pulled up for the same scale.
Do you by chance know your float-on trailer weights? axle and tongue?
gulfcoast john
C-Dory Year: 2010
Photos: CAT O' MINE
PostPosted: Sat Apr 15, 2017 5:16 pm    Post subject: trlr Reply with quote
Float-On model 1431-txcbb, Ser # 1115163, GVWR 13,500, TRL WT 2,000, NET CAP 11,500, GAWR FRONT 6750, REAR 6750.
My tongue wgt runs 900-1200# (hitch rating 1200#) depending on what I stash in the boat vs the pickup bed. I did replace the std winch with HD model with lower gears for those summer 96 degree days with 98% humidity.
With EOH brakes controlled by DIRECLINK (has comm with truck engine ECM via OBD port) easily my best behaved rig ever.
I was trying to send a PM to you, not hijack a thread on a different subject...messed that up.
My engines don't smoke when down, but the stdbd one will sometimes drink a bit too much, esp on holidays. I think it may be the 'ducer/disturbed water issue.
Happy Boating!
BTDT
Photos: C-Lark
PostPosted: Sat Apr 15, 2017 6:08 pm    Post subject: Reply with quote
OMG- Getting old is not for sissies Shocked
I just checked my trailer data plate and didn't realize it included the empty weight of 2000. It is also the identical model to yours and with EOH.
Bottom line- When the four disc brakes kick-in on my boat trailer it really feels like I can stop faster than when my truck is empty.
Thumbs Up
Page generation time: 0.0324s (PHP: 65% - SQL: 35%) - SQL queries: 21 - GZIP disabled - Debug on
