Autopilot TC255 Needed?
jritsema
C-Dory Year: 1994
Photos: jritsema
PostPosted: Wed Mar 02, 2016 4:27 pm    Post subject: Reply with quote
Thanks for that tip Tom. That is new to me, and actually very important in this decision.
John, you should know that I work for the Fed and we have your number.
Naaaa. Just kidding. You should visit us in MI (Michigan) some time. Actually, I'm a retired "eye" guy.
This website is fun and very interactive and informative.
Jeff
PostPosted: Wed Mar 02, 2016 6:47 pm    Post subject: Reply with quote
The autopilot on Journey On is a Raytheon, 10 years old and I allow you to classify it as old or new. However, when it's in autopilot mode and I turn the wheel, the pump works like heck to prevent the boat from turning.
That is different from what Tom Elliot says, so please check. It's simpler/cheaper to build one which doesn't allow for a wheel input, so please check.
PostPosted: Wed Mar 02, 2016 6:48 pm    Post subject: Reply with quote
starcrafttom wrote:
I often hear or read that people , who do not have auto pilots, are worried about "grabbing the wheel in time" . Modern auto pilots do not require you to turn them off to turn the wheel. the function goes by different names on different brands but at anytime you have the auto pilot engaged you can just grab the wheel and turn in and the boat will turn until you let go , then the auto pilot with reengage and go back to its heading or course. No buttons to push in that instant that you see a log.
Tom, I hope you are right, about being able to just grab the wheel and turn. that may be the case with some auto pilots, may most, but last Spring (2015) I replaced my RayMarine AP with the new EV-1, and to my knowledge, I have to turn it off, (hit the "standby" button), to control the boat with the wheel. Otherwise the wheel will spin freely on the helm, after a bit of a catch, but the boat goes where Charley (my Auto Pilot) wants it to go.
If there is a setting I can do to make it do as you describe, I would love to know because it would actually be like the cruise control on the car: (step on the gas or step on the brake.)
That would be a good feature, so be sure and check with the seller to see if it is actually there, especially if you are counting on that to be part of your AP function.
SleepyCMoon
PostPosted: Wed Mar 02, 2016 7:14 pm    Post subject: Reply with quote
I agree with Harvey and Boris. I can grab the wheel and get a little movement but the helm manually operated pump is then competing against the autopilot electronically operated pump. There's no connection between my helm and the autopilot that lets it know I've turned the wheel. E.g. it's not like cruise control on a car where hitting the brakes disengages cruise control. I need to disengage the AP to get good control from the helm. Moreover, with a Tomcat (especially at speed), even without the AP, maneuvering is not a rapid as in monohull. The cat's don't heel over when you turn so you don't get the extra advantage of tipping the hull in the water to aid with the turn. Rather the boat turns more like it's on rails. I've found that I need 2-3 times as much distance in which to turn to avoid an object in the water relative to my previous 22. That took a bit of getting used to and requires more vigilance than on a monohull (especially with a cruise speed of 1.5x the 22).
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Wed Mar 02, 2016 8:40 pm    Post subject: Autopilot TC255 Needed? Reply with quote
Garmin auto pilots have what they term Shadow Drive. It allows you take over the wheel without having to switch to standby and when you are done steering it returns to the previous heading.
D.D.
PostPosted: Thu Mar 03, 2016 1:46 am    Post subject: Reply with quote
Now I remember why I hate raymarine. Their manuals suck. Its called the jog steer function on raymarine and garmin calls it shadow drive and I cant find what simrad call it. On the raymarine, which I have had, you just turn the wheel FAST. It will not work if you are just moving the wheel slow or just 20 degrees. Grab the wheel and spin it. Boat with JOG off course. when you let go it will go right back to your course. The Garmin will , depending on function, will either go back to course or stay on new course. This has started by raymarine, as far as I know, in 2000 to 2004 time frame. I have used it a thousand times.
PostPosted: Thu Mar 03, 2016 3:36 am    Post subject: Reply with quote
Tom, Thanks for that info. I may not have tried to spin the wheel, far enough, or hard or quick enough. I will be trying that next time out. It does make sense as a safety factor.
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Thu Mar 03, 2016 10:54 am    Post subject: Reply with quote
Just as Tom describes, I've made quick turns to avoid debris many times, while our Raymarine S1000 auto pilot is engaged. I installed this unit & have used it since 2005. Raymarine has now replaced it with other models such as the one Harvey has on board & think it likely that feature remains.
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Thu Mar 03, 2016 11:00 am    Post subject: Reply with quote
My TR-1 Gladiator has what is called shadow drive, this allows me to grab the wheel and override the AP at any time, when I let go of the Wheel it goes back on course.
As soon as I round the brake water the AP is engaged, love it!
Boatless for now but looking
Page generation time: 0.0385s (PHP: 65% - SQL: 35%) - SQL queries: 22 - GZIP disabled - Debug on
