PROJECT-A-PALOOZA!! - V-Berth Access and Mods
Goto page 1, 2, 3  Next
Ray
City/Region: Pamlico River
Vessel Name: Seaweed
Photos: Seaweed
PostPosted: Tue Dec 09, 2014 8:15 pm    Post subject: PROJECT-A-PALOOZA!! - V-Berth Access and Mods Reply with quote
I made a few mods to the V-Berth to make it more useable.
I started with a small inspection hatch at the center of the forward bilge. I cut out a circle the right size for a hatch:
There was about 2 gallons of NASTY water in there:
After cleaning it all out, installed the inspection hatch:
No need to clean up - there was more to do!
Next I cut 3 access holes in under the cushions. For those that are interested, my boat (2007) had no foam or anything underneath - just air. This is actually the "after" photo - I didn't take an in-process photo as I cut them Crook
I epoxied the edges of the edges of the exposed wood after cutting.
After cutting the holes, I scuffed up the fiberglass edges underneath and also some aluminum strips that I rounded the coners on. And epoxied them in to support some lids (screws came later):
PVC tube sections make GREAT clamps. You can adjust the strength by how wide you cut each slice of the tube -- skinny ones for light pressure, fat ones for strong. I make use of a huge bucket of these all the time for various projects:
I used 1/2" plywood for the lids. I cut and rounded over a hole in the middle for removing, and then painted with Brightsides ("Hatteras Off-White is a VERY close color match to the interior gelcoat, BTW). I drilled and installed some flush-head screws and nuts into the epoxied aluminum strips also.
While I had my head down in there, I glassed and painted a couple of mounting cleats to the hull sides:
Then I mounted some hooks on them to hang stuff up out of the way of the storage junk down below. I have a row of hooks on each side for spare dock lines, bucket, etc.
Also "while I was in there", I mounted two home made LED lights to the aft bulkhead underneath:
They help illuminate all the junk down in there when it is dark:
I put a flush-mount switch for the lights right at the corner under the cushion (where there is no pressure to accidentally turn on):
It was all really easy to wire up being all locally right there at the helm power location.
This was a very useful project and gave us a TON of new storage space!
Ray
Lollygaggin
City/Region: Kelowna
PostPosted: Tue Dec 09, 2014 8:44 pm    Post subject: Reply with quote
My hat's off to you for coming up with these ideas and implementing them. Looks great. You'd think the factory would have thought of this. Thumbs Up
PostPosted: Tue Dec 09, 2014 8:51 pm    Post subject: Reply with quote
Love it, Ray, this is a "must do." The only thing I don't know is whether the 2005 CD25 has foam down there or air...hoping for air but betting on foam. I love the plywood covers instead of Bomar hatches (which I was planning on). Your plywood covers will be flat, not like "The Princess and the Pea" that we would get with Bomar hatches!
Pandy Girl
City/Region: Westfield, NC
Vessel Name: Pandy Girl
Photos: Pandy Girl
PostPosted: Tue Dec 09, 2014 11:08 pm    Post subject: Reply with quote
Looks great, looks like you are doing a good job. Hope to see you all in the future. Very good Pics. Jim & Sandy
Pandy Girl
BRAZO
City/Region: Full-time Travel
State or Province: NV
Vessel Name: Meyer Meyer
Photos: BRAZO
PostPosted: Tue Dec 09, 2014 11:16 pm    Post subject: Reply with quote
Very impressive!
2008 CD22 Twin 50hp
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Tue Dec 09, 2014 11:22 pm    Post subject: Reply with quote
What did you use to cut the circle for the inspection plate, and how far down is the hull? Kind of curious what I might find in there as well. I put a bomar in the forward area and it is full of foam, really nasty foam. I like your hatches much better than my bomar. After doing one I decided not to do another.
PostPosted: Tue Dec 09, 2014 11:39 pm    Post subject: Reply with quote
Nice write-up! I did a similar project on my 22 this summer and have been meaning to post about it (I went to Powell right afterward, and I guess I forgot). I really like the improvement!
Another good paint match tip (which I got from Carpy) is that Pettit's "Easypoxy" in "off-white" color is a virtually perfect match for the "white" C-Dory gelcoat (equivalent paint to Interlux "Brightsides")
I like the lights Thumbs Up
PostPosted: Wed Dec 10, 2014 12:42 am    Post subject: Reply with quote
Really nice, job and write-up with good pix. Thanks for sharing that.
Ray
Photos: Seaweed
PostPosted: Wed Dec 10, 2014 5:36 am    Post subject: Reply with quote
lloyds,
I used a dremel tool and spiral bit (well, several of them!) to cut the circle out after drawing with pencil where to cut.
The hull is somewhere between 4-6 inches below this level, if I remember correctly.
Hope this helps,
Ray
nordicstallion
City/Region: Crescent City
C-Dory Model: 19 Angler
Vessel Name: Rylee Rose
Photos: Rylee Rose
PostPosted: Wed Dec 10, 2014 11:48 am    Post subject: Reply with quote
That's some very impressive work you've done there. A question... Is there no flotation ( foam) in your boat at all?
PostPosted: Wed Dec 10, 2014 1:48 pm    Post subject: Reply with quote
My '08 CD22 had the factory installed hatches in the berth area. There was no foam.
One thing I noticed was even with the hatches these areas are so air tight that when I got the boat in '12 the original paint inside was still tacky and had that fresh paint smell. Stuff the PO put in the bins ended up with paint marks on them.
After leaving the hatches open over a winter the paint finally dried.
PostPosted: Wed Dec 10, 2014 2:56 pm    Post subject: Reply with quote
Pat, our 2007 had no foam either. Like the idea of the LED lights but since electrical is not my strong suit, I'll KISS it w/ a flashlight.
SGIDave
City/Region: St. George Island
Vessel Name: Seadation - SOLD 09/2013
Photos: SeaDation
PostPosted: Wed Dec 10, 2014 2:59 pm    Post subject: Reply with quote
Hello Ray,
I like what you've done with your boat. Very WELL DONE modifications. AND you have the ability to communicate pertinent details well with your posts. That helps all us C-brats.
My question: Do the plywood hatch covers "rattle" when the boat is underway? There appears to be no fasteners holding them in place. Perhaps simple gravity and the berth mattress lying on top of the covers is adequate. I REALLY like the simplicity of the plywood vs factory-made covers.
Your other mods are very nice too.
Keep on Modifying!
david
PostPosted: Wed Dec 10, 2014 3:29 pm    Post subject: Reply with quote
I can't speak to Ray's specific covers, but I've had many boats with similar style access in the settees or berth flats (albeit with wooden support cleats) and they have never made any noise (and if anything on a sailboat can make noise while you are off watch trying to sleep... it WILL). This is a common way to make locker tops in sailboats, btw.
Grazer
City/Region: Yukon
State or Province: YT
Vessel Name: C-Horse
Photos: Grazer
PostPosted: Wed Dec 10, 2014 3:47 pm    Post subject: Reply with quote
I agree with others that your mods are great, and thanks for sharing.
I was wondering about the water you uncovered. Any further insights as to how or why the water got in there? There's the anchor locker drain theory and the long screws securing the brass keel strip and penetrating the hull theory.
Page 1 of 3
Page generation time: 0.0684s (PHP: 70% - SQL: 30%) - SQL queries: 28 - GZIP disabled - Debug on
