spuncopper
Joined: 02 Sep 2012 Posts: 196 City/Region: Camden/ Lake Wateree
State or Province: SC
Vessel Name: Sock Monkey
Photos: Sock Monkey
Posted: Sat Apr 12, 2014 4:21 pm Post subject: Racor 120 R-Rac-01 gas and water filter |
Hey gang. I just finished changing the filter element for a Racor 120Rac-01. The element part number S3240. Basically an easy project except, the plastic element bowl would not unscrew. I figured #1. Gotta be done. So if I end up destroying the bowl it can be replaced. #2. Have some fun and see why it won't unscrew.
I hacksawed through the old filter as close to the shoulder as I could. A close inspection showed I could now hacksaw just above the bowl lip. Once I had done this I used just a hacksaw blade and notched the threaded part of the filter element in two places. I used a flat blade screw driver to knock the notch out. The rest of the threaded plastic from the filter peeled out.
I used fine emery paper to clean up the "O" ring seat and any feathered plastic from the hacksaw. I then cleaned everything with mineral spirits and now had a useable and salvaged element bowl. Put everything together and checked for leaks. It worked.
Just thought I'd pass this along in case there are others out there where marine stores are not within easy distances. Be safe and boat safe. :lol: |
Joined: 02 Nov 2003 Posts: 20860 City/Region: Pensacola
Posted: Sat Apr 12, 2014 6:33 pm Post subject: |
Good idea. How long had it been between filter changes? Also did you lubricate the gasket when you put in the new element? _________________ Bob Austin
spuncopper
Photos: Sock Monkey
Posted: Sat Apr 12, 2014 7:23 pm Post subject: Racor |
It was changed a little over a year ago. After I cleaned everything up I "lubed" it with a very thin coat of petroleum jelly (Vaseline). The last time it was changed it was done at a marina so I don't know if a lube, if any, was used. |
Posted: Sun Apr 13, 2014 3:29 pm Post subject: |
Good, putting some grease on the rubber gaskets, is always a very good idea--recommended by Racor. I use a silicone grease. If your filter has other "O" rings they should be changed at the same time, along with a small amount of grease. |
