Epoxy bonding to Gelcoat
Grazer
City/Region: Yukon
State or Province: YT
Vessel Name: C-Horse
Photos: Grazer
PostPosted: Fri Jan 31, 2014 10:07 pm    Post subject: Epoxy bonding to Gelcoat Reply with quote
Hello All.
I am looking at fastening a Scotty Sidewinder Rod Holder http://www.scotty.com/fishing-gear-equipment/rod-holders/sidewinder.htm to my cockpit gunnels on inboard side. The top screws will go into the cored deck and the bottom fasteners will be through bolted. I want to protect core by sealing with epoxy, so I am considering bonding the entire bottom of the trigger lock assembly to the gunnel. This would dramatically increase the strength of the attachment. My question is, should one simply rough up the gelcoat with some 60-80 grit sandpaper and then clean with solvent and bond with epoxy OR should the gelcoat be removed entirely down to the fiberglass before bonding with epoxy? This is the area I am talking about.
<img src="http://www.c-brats.com/modules.php?full=1&set_albumName=album1897&id=IMG_5495&op=modload&name=gallery&file=index&include=view_photo.php">
Grazer
Grazer
City/Region: Yukon
Photos: Grazer
PostPosted: Fri Jan 31, 2014 11:16 pm    Post subject: Reply with quote
Sorry, Here's the photo of what I proposing to do.
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Sat Feb 01, 2014 12:19 am    Post subject: Reply with quote
Don't know for sure, but is top of the gunnels really cored? I wouldn't have thought so. But it would be good to know. It looks like you've already drilled it so did you find foam or wood core in the drill leavings?
Testosterone Tales-Amazon.com
KG7RC
AstoriaDave
City/Region: Astoria
PostPosted: Sat Feb 01, 2014 3:30 am    Post subject: Reply with quote
Grazer, probably 5200 would be better in this application because it remains flexible in the event the gunnel expands at a different rate than the fixture. Epoxy is certainly strong enough. If you are wedded to epoxy, G-Flex would be the best choice. The 655-K kit should be plenty, and already has filler in it.
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=11151&productId=14902&langId=-1#.UuyweKjTnbU
Dave Kruger
Astoria, OR
PostPosted: Sat Feb 01, 2014 4:01 am    Post subject: Reply with quote
The gunwales (flat top area) on my 22 are cored with balsa (as is most of the deck). There are some cut-away views of an older (1990's?) 22 that also show the coring. I'll upload one to my album and then come back and attach it here.
williwaw
City/Region: Portland
Vessel Name: Williwaw
Photos: Williwaw
PostPosted: Sat Feb 01, 2014 11:23 am    Post subject: Reply with quote
I once had a drop of epoxy fall on my floor. After discovering it later I tried to pop it off but wound up taking the gel coat with it. So I would think you'll have no problems with adhesion if you just clean the surface. But know that whatever you attach will not come off again without a saw. If it were me, I'd probably go the 5200 route.
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sat Feb 01, 2014 12:28 pm    Post subject: Reply with quote
I had to remove something I had applied 5200 on, and was amazed at the strength of the bond.... I too would use 5200
I bought a tube of 5200 at Home Depot yesterday for $8.50
Joel
SEA3PO
Grazer
City/Region: Yukon
Photos: Grazer
PostPosted: Sat Feb 01, 2014 3:43 pm    Post subject: Reply with quote
Thanks for the responses. There is definitely balsa core in the deck of the gunnel. I am now rethinking my strategy of bonding the rodholder base to the gunnel, but rather gluing with 5200 since it can be removed at some point if needed. I will still set the screws in epoxy to seal the core and increase the strength of fastening. I would while the epoxy is curing, fasten the hardware with 5200. Is there any known issues with the two bonding agents (epoxy, and 5200) reacting negatively?
PostPosted: Sat Feb 01, 2014 4:40 pm    Post subject: Reply with quote
From the Scotty web site and your photo it appears as if you are going to mount this rod holder to the inside of the cockpit side deck, not the actual deck--as the outrigger mount is in the photo. The inside of the cockpit where you have your holes drilled should not be cored, although the deck part is.
Thru bolting should be very satisfactory--not screws. You don't need to route out core, and fill with epoxy if there is no core. 4000 or 4200 should be fine as a sealant. 5200 and epoxy is fine, just get rid of any amine surface blush. Use fender washers on the inside and this should be stronger than the wires of the rod holder.
Grazer
City/Region: Yukon
Photos: Grazer
PostPosted: Sat Feb 01, 2014 5:34 pm    Post subject: Reply with quote
Just to clarify, the top three holes do not go through where there is backing but rather into the cored deck area like in Sunbeams photo. The bottom three holes have access to the back and therefore can be through bolted. I would like to wet out the cored holes allow it to soak in, apply a thickened epoxy to the screw threads and fasten the hardware in. If I put 5200 on the back of the rod holder base, both adhesives will be uncured at the time of securing to the boat. Will they cure properly? May never know as I don't plan on taking it off to find out. Hopefully someone else has done something like this before and can comment on it success or failure.
PostPosted: Sat Feb 01, 2014 6:27 pm    Post subject: Reply with quote
As a caveat, I'm not familiar with the piece of hardware you are installing. With that in mind, a few thoughts:
1) If you are through bolting (and I would be, with backing plates), then you may only need a bedding compound to... well.. bed (i.e. guard against water intrusion). In that case a super adhesive such as 5200 may not add much except a lot of angst if/when you ever need to remove the item (it breaks, you want to upgrade, you want to re-bed, etc.). If you do want or need some adhesion to hold the thing on, then perhaps consider 4200, which, like 5200 is a polyurethane, but with a bit less adhesion than 5200. I have removed things bedded in 5200, so it is possible, but it's not fun.
2) If you really are just wanting to bed, then you can consider other products with other properties. Polyurethane is good, and has a fair bit of adhesion, but the white can yellow with UV. Polyether (3M4000) is not supposed to yellow (I haven't been using it long enough to know for sure). I also don't know the numbers for its adhesive properties, but I would think it would probably come in around the same or maybe a bit less than 4200 (just a guess though). Butyl stays pliable for a long, long time, and is easy application and clean up, but is less adhesive. And so on.
3) Back to part of your original question: Asking about bonding to gelcoat. One thing I think about if I'm going to bond something to gelcoat is... what kind of strength does it need? Because gelcoat, while it is bonded to the fiberglass substrate, doesn't have a "really strong" bond to it. In other words, if you bonded something like a stud to a small area of gelcoat and then pounded on the stud, it would just break the gelcoat off of the substrate. I did some "experiments to destruction" comparing Weld Mount studs glued to gelcoat, to fiberglass substrate (after grinding off gelcoat), and a metal angle screwed into the core. The studs glued to the substrate (without gelcoat) were a lot harder to make fail than the ones just glued to gelcoat (they stuck to the gelcoat but the gelcoat broke off of the fiberglass substrate.
That's not to say I never bond anything to gelcoat; but it depends on what kind of force it's going to withstand, plus how much of the gelcoat surface area is involved (more is less likely to crack off than less).
PostPosted: Sun Feb 02, 2014 11:12 am    Post subject: Reply with quote
If you age going to put screws into the cored area--I would over drill, and under cut the fiberglass. You are not getting any strength from the screws into the core in any case, unless you are going to put a plug of epoxy, which is larger in the area behind the fiberglass than the hole. Just dipping the screws in epoxy, will not give them any more strength--the epoxy will come off the screw as you put it into the hole. Some people will use a machine screw, and tap the epoxy plug with a tap, instead of using screws.
If you want adhesion, the best is gong to be the 5200. But most likely you are not going to keep the boat forever, and someone in the future may want to remove this fitting.
My experience with 4000 is that it does not yellow in over 2 years sun exposure. The shear strength is close to 4200 the shear strength is much different in various materials.--but you can look it up in the 3 M spec sheets.
Grazer
City/Region: Yukon
Photos: Grazer
PostPosted: Sun Feb 02, 2014 1:27 pm    Post subject: Reply with quote
Thanks Bob. I thought of that already and was hoping to get away from the backcut/epoxy plug technique. In reading West Systems manuals it refers to the epoxy plug as a technique to repair striped or oversized holes (as well as waterproofing the core). As for new holes, the basic technique for mounting hardware is described below with advanced mounting after (which is the technique I think you are describing but with an undercut behind the glass laminate).
Perhaps the advanced mounting method will work as you mention, but again I would want the back of the rod holder bracket to be sealed with a water proof flexible adhesive. If the epoxy plug cracks or the screw backs out there maybe room to allow moisture to access the core, hence the additional need for the sealant. The clamping pressure using the screws and machine bolts will hold it all together while things cure.
PostPosted: Sun Feb 02, 2014 2:46 pm    Post subject: Reply with quote
One thing to notice on the WEST System fastener bonding graphic is that the "just wet out the hole" screw method is shown on a door hinge, which is probably not going into thinnish fiberglass. They refer to wetting out the fibers, so it's not specific, but I imagine something like a door hinge being mounted to a thicker wooden door jamb. In that application you are taking a method that will already work fine (wood screws into deepish wood fibers) and just making it better.
Personally, I'm not a fan of screwing into fiberglass (i.e. with tapered screws). It just never seems that satisfying, and if you need to remove/replace (re-bed, send out for repair, etc.) it's getting worse each time you re-fasten with them. I like to overdrill, fill, and then tap for machine screws. That's not to say the method they illustrate with hinges won't work, but it wouldn't be my choice.
Grazer wrote:
... but again I would want the back of the rod holder bracket to be sealed with a water proof flexible adhesive. If the epoxy plug cracks or the screw backs out there maybe room to allow moisture to access the core, hence the additional need for the sealant. The clamping pressure using the screws and machine bolts will hold it all together while things cure.
If you get a chance, I would like to see what the hardware is you are attaching. Reason is I can't visualize what you are saying about wanting to seal the back of the bracket (do you mean the underside of the top? or the backing block? Reason I ask is that I don't like to seal backing blocks, myself).
Edited to add: Okay, I went to the link. Looks like it comes with its own "built in" backing block. I was thinking "well the side of the gunwale is not even cored," but I guess the upper three holes are going "sideways" into the deck core, aren't they. Those are ones I would want to overdrill/fill/tap. Will you have to make your own backing block (that is shorter, heightwise)?
I would slightly wonder how the lower fastener area would handle any force (flex) but you can probably get a good idea of that by giving it a "yank test." (I also don't really know how much force would go on this piece of hardware.
Thataway:
Good data on the polyether and UV, thanks. I've only had some in use for around 9 months and most of that time it has been out of the sun.
Page generation time: 0.0517s (PHP: 68% - SQL: 32%) - SQL queries: 27 - GZIP disabled - Debug on
