Cruising at anchor
Goto page 1, 2, 3  Next
Roy & Dixie
City/Region: Silver Springs
Vessel Name: C Way
Photos: C-Way
PostPosted: Sat Nov 16, 2013 9:38 am    Post subject: Cruising at anchor Reply with quote
Monday we departed Daytona for a short 2 day cruise down the ICW to the south tip of Merritt Island, then back north up the Banana River, with a return through the Canaveral barge canal to the ICW north back to Daytona. The forecast called for a passing cold front with 20-40 percent chance of rain. As we reached the south tip of Merritt Isl. the forecast called for strong winds reaching gale force out of the N to NE. We anchored on the SE side of the Eaugallie causeway in 9 ft. The storm hit about 0200hr with the 35-40 K winds. By morning waves could be seen crashing against the north side of the causeway and sending water 20 ft into the air. We had only a light chop developed by the winds anchored close to the causeway, but felt every bit of the wind. Each evening as I bring the ships log up to date, I reset both my GPS receiver's trip odometers to 0mi. It was evident that we, nor any other boats would be underway in that part of Fla that day. We sat and watched my boat speed reach as high as 1.9mph as I sailed on the anchor. I figure I had @ 60 ft anchor line out to have 5/1 scope. I have @ 5ft chain on a 18lb Danforth anchor, which has never failed to hold. After 36 hr, we had traveled over 26 miles at an average speed of 0.7 mph. Our 2 day cruise turned into 4 days. We returned home with 1 can of chicken soup 1 slice of bread, and powered tang with which to make happy hr screw drivers.
When you come to a fork in the road, take it.
It's not the destination that is important, it's the trip.
"C-Way" Silver Springs, FL
PostPosted: Sat Nov 16, 2013 10:01 am    Post subject: Reply with quote
Roy and Dixie-
What was your gas mileage on your trip at anchor? Laughing
Quite a ride! CoolSmile
PostPosted: Sat Nov 16, 2013 11:37 am    Post subject: Reply with quote
In general, people who haven't been to the Southeast don't realize how severe those northern cold fronts can be. Before we took our trip around the East Coast, we thought that Florida was sunny, with an occasional thunderstorm in the summer. Boy, were we wrong. There's a lot of weather that passes through the Southeast in the fall and winter. And you have to find a safe spot.
Glad everything held. How was it sitting in a C-dory for a day and half, listening to the wind?
I spent a couple of weeks in Titusville Marina, whilst Judy visited her mother in Nevada. No storms like that, but we saw a Space Shuttle launch.
Sea Angel
Photos: Sea Angel
PostPosted: Sat Nov 16, 2013 11:46 am    Post subject: Reply with quote
Roy & Dixie;
I enjoyed your "tale of the hook". Sounds like you had a good seaman's eye throughout your 'stay'. It sounds like your food plan was also very efficient.
I went back to your album and also enjoyed your photo journal of the ICW trip north.
Art
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
PostPosted: Sat Nov 16, 2013 2:18 pm    Post subject: Reply with quote
I noticed the same thing: much sailing around at anchor (although I did not keep track of the mileage Very Happy). I got in the habit of putting out a second anchor at an angle to the first (i.e. a V out forward) and then tying the rodes together just forward of the roller*. Still sailed more than I'm used to, but it was much reduced (and tying the rodes together kept them from chafing on the roller ears).
(I realize this is probably already in most people's bag of tricks.)
*Ultimately I don't plan to use the roller as my anchor fairlead, but I don't yet have an alternative set up.
PostPosted: Sat Nov 16, 2013 2:48 pm    Post subject: Reply with quote
Sounds like you need more chain.
Roy & Dixie
Vessel Name: C Way
Photos: C-Way
PostPosted: Sat Nov 16, 2013 3:07 pm    Post subject: Reply with quote
On the cruise ship Dixie and I ran, we used an anchor arrangement much as you describe. Even though almost 200 ft in length, the ship would sail badly on one anchor. Due to the weight of the ship, the anchor would be jerked loose often as it was turned by the wind to sail back in the opposite direction, especially in the Caribbean and Bahamas during the winter when the winds would blow 20+ mph 24/7. We anchored out most nights and would set one anchor, then power slowly 90 degrees across the wind, playing out double the required scope, lower the second anchor, then pull 1/2 the first anchor chain back in. This put a lot of strain on each anchor, but it was a steady, static strain, not one that was changing angle and jerking every few minutes. Our wind direction was almost always constant, so it worked well for us. I only had one anchor on the CD, but I sure thought about how nice two would have been.
Roy & Dixie
Vessel Name: C Way
Photos: C-Way
PostPosted: Sat Nov 16, 2013 3:36 pm    Post subject: Reply with quote
I have considered going to all chain, but then I would want a capstan and a way to clean the mud from the chain as I haul it in. With the line, I can haul it in by hand, shake it in the water as I do so to clean off any mud, and clean any mud off the anchor by pulling and dropping the anchor at the water surface a few times. Manual, but simple and reliable. After a few hours, the anchor line was black from the rubber chafed off the roller as the line slid back and forth, but there was no chafe of the anchor line. I simply paid out a few inches of line a couple of times. Since I anchor in mud or sand most of the time, I have not had a problem with the line at the anchor end being chafed or cut by coral or rocks so far.
Roy & Dixie
Vessel Name: C Way
Photos: C-Way
PostPosted: Sat Nov 16, 2013 3:40 pm    Post subject: Reply with quote
Sea Wolf wrote:
Roy and Dixie-
If I had not reset my trip odometer and let that mileage add to my mpg calculations, my overall average would have been great on a 200 mi trip.
PostPosted: Sat Nov 16, 2013 4:25 pm    Post subject: Reply with quote
While far from an all-chain rode (which is what I am used to from other boats), I have 25' of chain. The boat still sails at anchor (especially on only one). I'm thinking it's just something that happens with a boat that is light, has no keel, and has quite a bit of windage.
(In contrast, the large, heavy, full-keeled sailboat with all chain sat still as a church at anchor most times.) (But then that was not trailerable, and could not sneak into half the "skinny" spots my 22 can Thumbs Up)
AstoriaDave
City/Region: Astoria
PostPosted: Sat Nov 16, 2013 5:45 pm    Post subject: Reply with quote
Sunbeam,
Surprised yours sails. Five to one rode? Kind of anchor and weight?
Anchoring in the lower Columbia, with tidal reversal, common to lose a little ground on a 180 degree reset, but we have coarse sand, most places. Folks around here seem to use more chain than I see described on C-BRATS, but 25 feet would be typical for 22 foot OB cruisers.
Does not sound like a kellet would help you.
http://cruising.coastalboating.net/Seamanship/Anchoring/Kellets.html
Dave Kruger
Astoria, OR
PostPosted: Sat Nov 16, 2013 5:56 pm    Post subject: Reply with quote
AstoriaDave wrote:
Sunbeam,
Really? Is it uncommon with these boats? I was thinking it was par for the course, just considering the boat design compared to a heavy, keeled cruiser.
For the primary, I have a 15# Manson Supreme anchor, 25' of 1/4" G4 chain, and 200' of 1/2" 8-plait rope. The secondary is a ~11# Bruce clone, with 20' of 1/4" chain and around 250' of 1/2" three-strand nylon.
The times I was anchored during a wind event (waited out a few on Powell). I probably had around 6-to-1 scope or more. I don't have my rode marked yet, so that's an estimate. Water depths (there were two or three different anchorages) varied from about 12' to 20'. I add 4' of depth to cover the distance from the water's surface to the roller, and then figure scope from there. I would say I had around 125' to 150' of rode out on each anchor (in a V).
I never budged, in terms of dragging - even when there were some decent waves coming through the anchorage - but did sail a fair bit (much less with the two anchors out and the rodes lashed together). In fact, the Manson would generally bring up a good bit of the bottom as compared to the Bruce clone.
I'm still inclined to think it's just a characteristic of the boat, but I'm open to more experienced opinion since I still have relatively little experience with the 22. My reasoning is that there is really no "traction" in the form of a keel, the boat is really light, and there is quite a bit of windage with the pilot house (I remember that lighter sailboats with more rope than chain would sail a lot more than we would, with a heavy boat, full keel, and all chain).
PS: Perhaps the wind on Powell is more variable (direction wise) than someplace with more trade-wind like winds - that may account for some of it.
primative
City/Region: Portland
Vessel Name: Primative
Photos: Primative
PostPosted: Sat Nov 16, 2013 6:09 pm    Post subject: Reply with quote
Roy and Dixie,I am wondering if setting a stern anchor to prevent swinging was an option for your situation?
I use a small danforth, aluminum type made by Fortress for this sometimes. It doesn't take as much room as anchors go, and is light.
Tom
(Primative)
PostPosted: Sat Nov 16, 2013 7:05 pm    Post subject: Reply with quote
The C Dory is very likely to sail at anchor. So are many other boats. In the right conditions my full keel, 35 ton ketch would sail significantly at anchor--the Cal 46 would sail at anchor--about 18 tons and modified keel. Fin keel sailboats sail at anchor--as do most motor boats. The kellet will not help--unless it is very heavy--heavier than you would want in this size boat. You can try riding to two bow anchors. A stern anchor may help to some degree.
anchorout
City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
PostPosted: Sat Nov 16, 2013 9:05 pm    Post subject: 50 ft Reply with quote
I just swapped out the 15ft of chain that the boat came with, for 50ft plus 200ft 1/2" nylon. In the shallow anchorages that we have down here, it makes a world of difference. The boat tries to skate sideways, but is dragged up short by the chain dragging on the bottom.
As for muddy chain, I use to have a cylinder like chain brush that hooked onto the boat hook and did a great job of cleaning the chain as it was brought in. Think I bought it at WM.
As for the second anchor off of the stern, it works well as long as the tide or wind doesn't turn and set you across the waves. This always happened to me at 2:00 A M. Sea anchor, same deal.
Page 1 of 3
Page generation time: 0.0497s (PHP: 71% - SQL: 29%) - SQL queries: 28 - GZIP disabled - Debug on
