bridma
Vessel Name: Nomad
Photos: Nomad
Posted: Mon Aug 26, 2013 8:01 pm Post subject: Anchor/Running light |
Is it normal practise to have your anchor/running light connected at all times. Looking through the albums, it doesn't seem to be the norm.
I was out solo when I hit an unexpected fog bank, came up on me real fast. I switched on the running lights and then realised my anchor/running light is still sitting in the v-berth. I didn't want to leave the helm and go sort it out in case I needed to take evasive action to avoid a collision. Makes me think I should have it connected at all times for safety. BTW, I do not have radar.
Martin. |
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2783 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Mon Aug 26, 2013 8:10 pm Post subject: |
Martin, my two cents worth... Any time there is a real chance of weather or being caught out at night, hook it up. _________________ "And in the end, it's not the years in your life that count. It's the life in your years." - Abraham Lincoln |
colobear
Photos: C-Cakes
Posted: Mon Aug 26, 2013 8:51 pm Post subject: |
Putting the anchor/all around light up is part of our normal pre-launch procedure. Just takes a minute. I moved its clips from the vee berth to just above the cabin door so I can reach inside and get it with no trouble. I have turned it and other running lights on several times when visibility deteriorates, fog, heavy rain, etc. _________________ Patti and Barry
formerly C-Cakes, now
rving around N. America |
Joined: 02 Nov 2003 Posts: 21468 City/Region: Pensacola
Posted: Mon Aug 26, 2013 9:00 pm Post subject: |
We do not keep it up on the C Dory. Of course fog is rare in our part of the woods. I do keep the cap on the base however. _________________ Bob Austin
DuckDogTitus
Joined: 31 Jan 2013 Posts: 1034 City/Region: Gig Harbor
C-Dory Year: 1988
Vessel Name: C-Miner
Photos: Hemingway
Posted: Mon Aug 26, 2013 10:28 pm Post subject: |
I have it up all the time, mostly because I forget to take it down, but its convenient nonetheless  _________________ Dustin |
Posted: Mon Aug 26, 2013 11:56 pm Post subject: |
Mine is up if the weather or daytime dictates. Rarely have it out, but if the weather, visibility or daytime indicates. I do not like the idea of going up there out on the water so I am pretty careful about getting it up early, ahead of the need.
SleepyC  _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
Jack in Alaska
Joined: 17 Aug 2004 Posts: 1192 City/Region: Anchorage/Ninilchik
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
Posted: Tue Aug 27, 2013 3:34 am Post subject: Anchor light. |
Mine does not work????? Can not find the problem but will keep on trying.
Red/green work fine _________________ On the HIGH TIDE-II, wife Carolyn and I.....Another summer fishing on the HIGH TIDE II in the Cook Inlet at Cape Ninilchik, Alaska.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Bare hull & trailer sold in Nov. |
Webminer2
Vessel Name: "Sweet C"
Photos: Quiet Time
Posted: Tue Aug 27, 2013 8:33 am Post subject: Anchor light |
I did not know you could remove the anchor light. How do you take it down. Mine seems loose at times but I have never tired to take off. It makes getting the cover on hard at times and does seem to swivel like its loose. It works and there is cap for it on the dash. |
jennykatz
Vessel Name: Little Treasurer
Photos: Jennykatz
Posted: Tue Aug 27, 2013 8:47 am Post subject: anchor light |
I removed the one that came with our cc-23 and put a LED one that folds down when not in use . its in my photo album JIM _________________ retired 8/08 from UAL, still working pt tm
Posted: Tue Aug 27, 2013 9:43 am Post subject: Re: Anchor light |
Webminer2 wrote: | I did not know you could remove the anchor light. How do you take it down. |
If you have the same Perko fixture that the later model 22's have, then you'll see a black plastic ring at the base of the light pole (above the chromed base that's fastened to the boat). Unscrew this ring (it will stay captive on the pole) and then wiggle/pull the pole out of the chromed base (there are locating/contact pins, so pull straight up as much as possible).
After you have the pole/light removed, the black plastic cap that's (likely) screwed to the helm area can be fastened to the chromed base on the cabin top to cover the open socket. There may be a pair of black, U-shaped friction brackets somewhere on the boat for stowing the pole/light (mine are on the port side V-berth overhead).
Sunbeam |
DuckDogTitus
C-Dory Year: 1988
Photos: Hemingway
Posted: Tue Aug 27, 2013 10:04 am Post subject: Re: Anchor light. |
Jack in Alaska wrote: | Mine does not work????? Can not find the problem but will keep on trying.
Red/green work fine |
could it be corrosion on the contacts, either in the base mount, or the bulbs? |
