cooking with wallis
bcarli
Vessel Name: Soulmate
Photos: Soulmate
PostPosted: Sat Jul 30, 2005 4:29 pm    Post subject: cooking with wallis Reply with quote
hello all,
we just brought "Soulmate" home a few days ago. She is our new c-dory 25. We will keep her in friday harbor. I tried to use the wallis stove, I am using kerosene. It ran for 15 minutes and the burner wasn't even hot. It would be afternoon before I could get my morning coffee at this rate. Are we doing something wrong? Stove seems pretty simple. Turn the on switch on and turn the temp. knob to hi, what else is there?
thanks
bill & chris
Helen O
City/Region: Cathlamet
Vessel Name: Helen O'
Photos: Helen O'
PostPosted: Sat Jul 30, 2005 6:30 pm    Post subject: Reply with quote
Bill & Chris
Obviously your wallas didn't ignite. Somethings wrong. Seeing as how your boat is so new, I'd take it back to the dealer and let him figure it out.
It should only take a few minutes for it to get hot.
Larry S
Helen O'
KenMcC
State or Province: NM
Photos: Vivien C
PostPosted: Sat Jul 30, 2005 8:06 pm    Post subject: Reply with quote
If it was the first time you used the stove, it may have initiated the shutdown cycle before the kerosene made it all the way to the burner. Normally, it takes two tries to get the fuel pumped all the way through a dry fuel line. If the stove doesn't ignite in a minute or two, it will automatically shut down.
Try it again, listening carefully for the click-click-clicking of the fuel pump. If the pump is working, your second try should get the fuel to the burner. It should ignite in about one minute, and in the next minute or so, the little red light should come on steady. If the red light starts blinking, it means it's again going into shutdown mode. Look and see if the fuel line is full (no visible air bubbles). If it looks like the fuel still hasn't fully filled the line, wait for the complete shutdown cycle (the red light goes out). Try once more. If that fails, then the factory needs to know.
Good luck.
Ken
PostPosted: Sat Jul 30, 2005 10:03 pm    Post subject: Reply with quote
Also if you flip the on off switch too many times the computer gets lost. unplug the power from the switch board. its on the right side near the bottom of the green board. then after 5 mins plug it back in. I have several bad starts with my wallis and one two trips to the dealer in seattle. last weekend I took the whole thing apart. Now it wortks fine. you can also adjust the fuel flow but I would have to show you or take pic's of it.
PostPosted: Sat Jul 30, 2005 10:14 pm    Post subject: Reply with quote
Sheesh. What do you expect for twenty four hundred bucks? Hot coffee too?
All good tips you're getting here. those thing are very tempermental. It's kind of like they have a personality, and you have to get to know them in order to get along with them. But once you see eye to eye with the thing, you'll be mighty glad you have it.
And remember that the left side burner gets way hotter than the right side, so start your coffee perking on it and then slide it over. Also you have to have a flat bottom coffee pot.
bcarli
Photos: Soulmate
PostPosted: Sun Jul 31, 2005 2:08 am    Post subject: Reply with quote
thanks for your input. I think something is really not right with the unit and I will call the factory on monday. I see white smoke ( I think its unlit fuel) drifting down from the right side of the burner when I open the cabinet and look in. Also there is no exhaust blowing out of the side thru hull vent. The right burner never even gets warm and the left one barley gets warm while I'm sitting there wondering if the fumes are getting to me because it sure smells.
we were already to take off this weekend but without coffee in the morning its day trips until we get this figured out. Also what seems like the exhaust fan on the bottom of the unit just blows into the cabinet wonder if the factory could have vented the wrong fan
thanks everybody for your input
bill & chris
Otter-BelleHavenMarina
City/Region: Alexandria
Vessel Name: Otter
Photos: Otter
PostPosted: Sun Jul 31, 2005 9:44 am    Post subject: Reply with quote
That does sound like its worth having the installer check it out. Would just add one thing in case you missed it in other threads about the Wallas: on mine I've learned to turn it on (1) with the engine running and (2) with the knob turned all the way to the highest heat level. Once its going it will work fine and you can adjust the heat to wherever you want it.
Hope they clear up your problems!
Tom on Otter
bcarli
Photos: Soulmate
PostPosted: Wed Aug 03, 2005 11:40 am    Post subject: wallis Reply with quote
Hi
thought I would up date anybody that was ready about our wallis woes. On our boat the galley is lowered about 3 inches so we can have seating over the sink and stove this lowered the bottom of the stove so when we went out in some rough conditions water made its way through the exhaust vent and into the burner. We turned the thru hull gooseneck from horizontal to facing up and will add more exhaust hose so we can loop it . After taking it all apart yesterday we got the stove working great. its all just a learning curve. After being a life long sailor it sure is nice to get somewhere at 20 knts. javascript:emoticon('CoolSmile')
CoolSmile
bill & chris carli
friday harbor. wa
Luna C
C-Dory Year: 2019
Vessel Name: Panthera
Photos: Luna C
PostPosted: Fri Aug 05, 2005 3:00 am    Post subject: Reply with quote
I have the lowered galleytoo, I'd love to see some pics of yours. Get out that digital camera and get a photo album going!!!
Now with Panthera 255 TC
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Fri Aug 05, 2005 9:01 am    Post subject: Reply with quote
Bill, is your boat the nice new green one at Friday Harbor, new Wm dingy on top? Kate and I spent the night up there last Sat. Walked over to say hi to the pround owner, but you had stepped off the dock.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
bcarli
Photos: Soulmate
PostPosted: Fri Aug 05, 2005 1:42 pm    Post subject: Reply with quote
yes thats "soulmate". next time you are in friday harbor give us a call 378-0302. we are really enjoying our new boat and we think the c-dory is a great boat. perfect for cruising here and north, look us up next time your in town. that goes for all you c-dory folks
Page generation time: 0.0485s (PHP: 65% - SQL: 35%) - SQL queries: 24 - GZIP disabled - Debug on
