Mini manual pump to remove stern bilge back flow
primative
City/Region: Portland
Vessel Name: Primative
Photos: Primative
PostPosted: Sun May 12, 2013 6:59 pm    Post subject: Mini manual pump to remove stern bilge back flow Reply with quote
Tired of the hands and knees drill of sponge transfer to dry the aft bilge, I discovered a small manual pump at Harbor Freight that may prove to be handy, item #66418, called a Multi-use Transfer Pump.
I attached the "pick up" hose that came with the mini to the stern bilge pump in a vertical orientation with an elec. cable tie then routed the hose following the upward slope of the port fuel tank (I have the plastic 22 gal. tanks). The pump is small enough to fit in the fiberglass channel that forms the forward part of the motor well, same channel that routes the fuel line over to the tank selection switch. The pump then can be conveniently accessed without having to get under the motor well. The outlet hose I think can be stored in the same channel, though I have not worked this out. The hose is soft (maybe due to being fuel grade),and it was easy to get the pick up end/orifice in kissing-close contact to the aft sump surface for optimum pick up. To my pleasure, after pouring water in the sump to test, the amount of remaining water was easily picked up with a swipe of the sponge ~2-4 table spoons. This was done in the boat port laboratory so looking forward to field testing. Then there is the question of durability for this high end pump(: I admit I spent around 9 to 13 DOLLARS and may regret it very little.
Considering the commonality of the back flow thing, please let me know if you use something you like better.
Tom
(Primative)
PostPosted: Sun May 12, 2013 7:25 pm    Post subject: Reply with quote
Tom-
Sounds great!
How about some photos of the pump and installation? Thanks!
RobMcClain
City/Region: Summerlin, NV
State or Province: NV
Vessel Name: Freedom
Photos: Freedom
PostPosted: Sun May 12, 2013 7:27 pm    Post subject: Reply with quote
Tom, I bought this same pump a few months ago. I think it cost ~$4.95. At that price I didn't expect much but it actually works quite well. Just be sure the tube ends are pushed on tightly or they can pop off while in use. Not a major problem though. For the price it seems to be a worthy investment and it removes a lot of water quickly. I wish all boat equipment was this economical!
Rob
PostPosted: Sun May 12, 2013 9:07 pm    Post subject: Reply with quote
Jim on Wild Blue showed me the "tool" for the wet bilges in the 25 and they cost a buck at any dollar store. Wink We have two on board.
PostPosted: Mon May 13, 2013 1:34 am    Post subject: Reply with quote
I have a pretty good tool for that left over bilge water too. I got it at the other WM, (Walmart) for $4.00.
It is a turkey baster, with a rubber tip, works to suck up the small grit, (stuff) that shows up there too. Then I use the sponge. Nope, don't like to have to crawl down there either, so the baster works well with a bit of a hose extension 4-5 ".
SleepyCMoon
PostPosted: Mon May 13, 2013 6:27 am    Post subject: Reply with quote
You guys that can't stand a little water in a bilge sump must go nuts when it rains and your boats get wet all over! Rolling Eyes Cry
Don't pump it out, suck it up! Oh wait, that's what you're doing... You definitely would not be able to deal with the bilges on a Navy vessel! Mr. Green
Chester
City/Region: home
Photos: Chester
PostPosted: Mon May 13, 2013 11:26 am    Post subject: Reply with quote
Harvey, I like the turkey baster idea. Compact, lightweight and cheap!
primative
Photos: Primative
PostPosted: Tue May 14, 2013 5:13 pm    Post subject: Reply with quote
Joe
I looked again on how I might store it and noticed the pump shaft is already showing beginning corrosion. I knew by looking at it, it wasn't stainless but didn't expect corrosion that fast only using it in a few tests with fresh water at home. I put a little "super lube" synthetic grease on the shaft for now, but know this is just a temporary fix, and I will not be satisfied until I take it or tear it apart to see if I can replace the shaft with a stainless one. I'm in salt too often to ignore.I'm not at a storage phase yet, but will keep informed.
I do hope I can modify it as it seems such a good fit and function.
Rob
I knew I paid too much!!!
Localboy
You said Jim on Wild Blue showed you the "tool" and cost a buck at the dollar store. Did you mean the same pump as I'm trying or something else?
If I can't make modifications, I may go baster. Plus I could use it for duel purposes. Cooking birds or deck hands who question, etc..
PostPosted: Tue May 14, 2013 6:27 pm    Post subject: Reply with quote
There is a small Jabsco Parr hand pump which has been used for many years for this type of purpose. More expensive, but holds up to marine use for years. I have one which is many years old and still works fine. Maybe the tubing will fit one of these.
I have used for sucking bilges dry, one of the older diaphragm electric pumps--works like the hand ones, except can be permently installed.
primative
Photos: Primative
PostPosted: Tue May 14, 2013 7:03 pm    Post subject: Reply with quote
Bob
Looking forward to checking Jabsco pumps out.
Tom
Page generation time: 0.0571s (PHP: 64% - SQL: 36%) - SQL queries: 23 - GZIP disabled - Debug on
