Steering Wheel Replacement
Swee Pea
City/Region: Bath
Vessel Name: Swee Pea
Photos: Swee Pea
PostPosted: Sun Jul 17, 2005 10:31 am    Post subject: Steering Wheel Replacement Reply with quote
Before I decide to replace the steering wheel on my 22'Cruiser, are there any "tricks"? Do I need a steering wheel puller? Also, shaft diameter so if I decide to replace it, I get the correct fitting wheel.
Thanks in advance.
Swee Pea
B~C
City/Region: Bend
Vessel Name: Blue~C
Photos: Blue~C
PostPosted: Sun Jul 17, 2005 11:34 am    Post subject: Reply with quote
A puller would be in order, once the wheel is off you'll find a standard 3/4" tapered shaft. I swapped mine out for a smaller Boaters World white plastic jobbie. The old wheel wasn't to eager to give up it's post but a two jaw puller convinced it. I sure like the smaller wheel
Ken
1999 22' boaterhome
PostPosted: Sun Jul 17, 2005 1:20 pm    Post subject: Reply with quote
Some of he standard type replacement wheels are of larger diameter than the original factory supplied ones. If you go for a larger diameter wheel, it will decrease the clearance between your thighs and the wheel. Check the current fit out and compare the present diameter wheel you have with the replacement wheel. Can you accommodate the larger one? Joe.
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sun Jul 17, 2005 6:42 pm    Post subject: Reply with quote
A little marine grade grease on the taper will help get it off easier next time. Wink
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
dogon dory
Vessel Name: DogOnDory
PostPosted: Sun Jul 17, 2005 10:48 pm    Post subject: Reply with quote
PostPosted: Sun Jul 17, 2005 11:22 pm    Post subject: Reply with quote
Dan-
Was the 12'' diameter the OEM on your old boat? I've never seen a 12" wheel on a CD! My original 13 1/2" was replaced with a 14 1/2" which seemed a bit tight at first, but better in the long run. Joe.
dogon dory
PostPosted: Sun Jul 17, 2005 11:45 pm    Post subject: Reply with quote
Swee Pea
City/Region: Bath
Photos: Swee Pea
PostPosted: Mon Jul 18, 2005 6:15 am    Post subject: Steering wheel replacement Reply with quote
Thanks for all the input. As always, it is best to ask the group first before proceeding. I will measure, borrow a steering wheel puller, and proceed. Laughing
Swee Pea
Page generation time: 0.0672s (PHP: 39% - SQL: 61%) - SQL queries: 21 - GZIP disabled - Debug on
