Fuel-filler grounding on 22 Cruiser
Goto page 1, 2, 3  Next
PostPosted: Thu Jan 24, 2013 11:41 am    Post subject: Fuel-filler grounding on 22 Cruiser Reply with quote
Hi folks,
In the thread I have going for my upgrade projects, the subject of grounding metal fuel fills came up. Although I have a call in to ABYC to clarify, it is definitely looking like the (original) metal fuel fills on my 22 Cruiser should be grounded. (I removed them earlier this year and found no evidence that they were ever grounded. There was nothing attached to them but the fill hose.)
I understand from reading how to attach the grounding wire to the fuel fill, but I'm not sure where to attach the other end (electrical is not my strong suit). My boat is not bonded, but (of course) it does have two negative battery terminals. There is also a negative bus bar. I also have a shunt (for battery monitor) although I'm thinking grounding is not a load so that shouldn't matter (?). Or maybe there is some other/better place to ground them.
Also if anyone already knows the appropriate wire size, that would be great. I see the resistance figure it has to be above, so I guess I could calculate it - but since this has probably been done hundreds of times on other 22's, maybe someone already knows?
PS: Here is the relevant passage from ABYC's H-24
24.15 FUEL SYSTEM GROUNDING
Each metal or metallic plated component of the fuel fill system and fuel tank, which is in contact with the fuel, must be grounded so that its resistance to the boat's ground is less than one ohm. Wire ends shall not be clamped between the fill pipes and hose.
PPS: This discussion started as a tangent in another thread (that was not specifically about fuel fills). It's here in case anyone wants to read it:
http://www.c-brats.com/viewtopic.php?p=232878#232878
Emurph8
City/Region: South Jersey
State or Province: NJ
C-Dory Year: 1990
Vessel Name: Murphy's Law
Photos: Emurph8 (Name TBD)
PostPosted: Thu Jan 24, 2013 11:56 am    Post subject: Reply with quote
Before I removed my metal fills and old tanks there was a white wire attached to a bolt on the fill, it went front there to the fuel selector switch and then terminated at the bolt that went through the hull and mounted the outboard. So essentially it was grounded to the motor and the water? I intended to install new all plastic fill/vent combo which would not need to be grounded. But since receiving these have decided not to use them and am putting back the stock metal fills.
Emurph
PostPosted: Thu Jan 24, 2013 11:59 am    Post subject: Reply with quote
Interesting. I anticipate filling at gas stations along the way, at least part of the time, so the motor(s) would not be in the water. However, maybe it works because the motor's electrical wiring is connected to the electrical system? But then if that's the case, why would they "bother" to attach to an engine fastening bolt, when the electrical system is probably easier, and the wire(s) would be in a less exposed location?
I hope to hear more input in this thread.
Bill K
City/Region: Toledo
State or Province: OH
Vessel Name: NIC'L PIC'L
Photos: NIC'L PIC'L
PostPosted: Thu Jan 24, 2013 12:00 pm    Post subject: Reply with quote
Please remember that some of the wire colors have been changed for boats.
My bonding wires are white. 1981 non C-Dory
I would have to go up to the boat and look, but am pretty sure the bonding wires are connected to a mounted anode on the bottom of the boat with a through bolt that the bonding wiring is connected too.
Bill Kelleher
PostPosted: Thu Jan 24, 2013 12:02 pm    Post subject: Reply with quote
I believe bonding wires (at least on bigger boats) are green now.
I don't know if your system would work on a non-bonded boat though (mine is not bonded); I wouldn't think very many 22 Cruisers would be bonded (?)
Edited to add: Well at least I'm not the only one who is confused. Here is a blog post that shows some CG info as well as excerpts from Jamestown's and Moeller's pages. It sounds like a stranded, green, 10-12 gauge wire from the filler to.. the negative battery terminal... maybe. They mention the outboard but only because it will be in contact with the water. I anticipate plenty of times I will be filling with the boat on the trailer and not in the water at all, so that doesn't sound good. There's too much to quote here, but it's at this link:
http://boatbuild.wordpress.com/2010/07/12/grounding-a-plastic-gas-tank/
There are some interesting additional thoughts in the comments to the post. Excerpts:
"Thank you for using my diagram to illustrate grounding of the fuel tank and metallic fuel fittings...
It is unfortunate that I included the word “bonding”. Bonding is a completely different term related to a system for preventing galvanic corrosion and has nothing to do with grounding. Grounding is the correct term and is used for electrical systems. The two are often confused. Even I and the USCG did it. Mea culpa, since I helped write the USCG Boatbuilders Hand Book....
... Actually the USCG regulation you cite does not apply to boats with outboard motors, but the industry standard, published by the American Boat and Yacht Council, ABYC, does, and that is what the industry uses."
And (finally someone addresses filling the tanks at a land-bound gas station):
"I might add that there are two reasons for grounding the fill to the tank and the boats ground. One is the static issue, but the other far more critical one is your boat needs to be in gound to ground contact with the fuel pump nozzle when filling the tank. The marine fuel pump ashore or on the dock, or at an auto gas station, is grounded to earth and there is a ground wire built into the hose that connects the nozzle to ground. All gas stations have warning signs telling you to make sure the nozzle is fully inserted before you started pumping gas. This is so any static in the system gets discharged to ground ( and in this case I litterally mean ground, or earth, as they say in the rest of the world)
So it is vital to make sure the system on the boat is connected, Otherwise you may get a spark jumping from the fill to the pump nozzle."
Note that I'm still not sure what to actually DO, but I'm reasonably sure my fills should have been grounded originally, and that I should figure out where to ground them now. Not positive, but just reasonably sure....
Bill K
City/Region: Toledo
Photos: NIC'L PIC'L
PostPosted: Thu Jan 24, 2013 12:11 pm    Post subject: Reply with quote
You are out of my area of knowledge as I have a big boat now and have never had a trailered (sp) boat.
I am having to downsize am am very serious about C-Dorys. Smile
Bill Kelleher
How would the anode grounding system work if the boat was not in the water though? It seems like the time the fills would need to be grounded would be when one is actually filling the boat, and the expectation would (or at least should) be that there would be times one would be filling when the boat is on the trailer and not in the water.
PostPosted: Thu Jan 24, 2013 12:30 pm    Post subject: Reply with quote
[quote="Bill K"]You are out of my area of knowledge as I have a big boat now and have never had a trailered (sp) boat.
[quote]
Well thanks for your input, and if you decide on a C-Dory then happy shopping Thumbs Up
It seems as though many of the diagrams "count on" the fact of one having an electrical fuel sender, which I don't have. Hopefully either someone here who is "in the know" will chime in, or else I'll get a call back from ABYC (or both!).
Emurph8
C-Dory Year: 1990
PostPosted: Thu Jan 24, 2013 1:08 pm    Post subject: Reply with quote
My original setup, which I'm pretty sure was factory, did have fuel sending units in the grounding set up. And yours did not have sending units or grounding wires. So maybe they are not needed? I'm anxious to find out. I sure don't want to make a mistake on this job.
PostPosted: Thu Jan 24, 2013 1:10 pm    Post subject: Reply with quote
Generally "grounding" is between the fuel fill, metal fuel tank, and in some cases the fuel hose. In many C Dorys the tanks are plastic, and thus cannot be directly grounded--but the fuel gauge, if installed may be. The proper place for termination of the "ground" in this case--more of a bonding wire tie in, would be the engine bolts. A few boats do have either an anode plate, or proper ground plate, but not most C Dorys.
In either case, there is no real ground, unless you have a wire that you can connect to "earth" when you are pumping the gas on land. That would be ideal, but not done. Generally the bonding of the nozzle is adequate, as it touches the rim of the metallic fuel fill fitting.
Good practice is to touch the nozzle to the outside of the fuel fill fitting before inserting the nozzle, to dissipate any static electricity present in the system...Then insert the nozzle, and begin pumping fuel.
It is not ideal--but what we have to deal with.
Bill K
City/Region: Toledo
Photos: NIC'L PIC'L
PostPosted: Thu Jan 24, 2013 1:15 pm    Post subject: Reply with quote
Now that I think about it when fueling a gas engine airplane there is a wire from the earth that is clamped to the airplane before starting to fuel.
Bill Kelleher
PostPosted: Thu Jan 24, 2013 1:32 pm    Post subject: Reply with quote
I just got a call back from Brian at ABYC. Here's what I got from the conversation:
1) The boat being outboard or inboard powered is not really a distinction so much as it is that the boat has permanently installed fuel tanks with fills.
2) The metal fills need to be grounded.
3) Oftentimes, the fuel tanks are metal (or have senders) so the builder can simply run a wire from the fills to the tank (to ground the fills). Since my (our) tanks are plastic, this isn't an option. On the other hand, the plastic tanks also don't need to be grounded; it's just the metal fills that need to be.
4) The engine may be used for grounding, but really it all comes back to the negative in the electrical system (which the engine is attached to).
5) I said "So okay, I can use 12 gauge, stranded, green wire, and run it from each of my fuel fills to my negative bus?" He said yes, and reminded me that after setting it up I can check the resistance, which should be less than 1 ohm (of course what I'll do is "test wire" it and check the resistance before finalizing it).
I hope this helps and that I didn't misquote anything; I just got off the phone with Brian so hopefully it's all still clear in my head.
PS: Interesting that - from all evidence I can find - C-Dory did not ground the fills when my boat was built. Do others with 22 Cruisers have grounded (metal) fills? (I'll be grounding mine when I reinstall them.)
Emurph8
C-Dory Year: 1990
PostPosted: Thu Jan 24, 2013 1:51 pm    Post subject: Reply with quote
Thanks for the research! That's what I will be doing also
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Thu Jan 24, 2013 1:53 pm    Post subject: Reply with quote
Basic physics of this whole issue needs to be kept in mind. At least the way I view it. (I'm no brain surgeon, but I am a rocket scientist).Smile
If the nozzle of the fuel hose is at a different electrostatic potential than the fuel fill area, be it metal or otherwise, then there will be a discharge between the two causing a spark. The reality is that the gas station and its pumps and its hoses and nozzles will likely be at a different electrostatic potential than your boat whether it is on a trailer or in the water. If the fueling station is on the water, and the pump nozzle system is grounded in the water and your fuel filler is grounded to any metal that is in the water, then it is likely that your electrostatic potential will be equal and there will be no discharge when the nozzle hits the filler opening.
On dry land with the boat on a trailer, then unless you clamp a ground from the pump and nozzle system to the metal of your filler, then there will likely be a significant difference in electrostatic potential. The boat and the trailer and the pump system are two different static systems and unless you physically connect them, there will be a difference in potential.
In the airplane world, that difference is taken care of by the fueling system having a separate grounding line and clamp that is clamped onto the airplane engine before the fueling nozzle is brought to bear on the fueling port.
I think that boat fueling would be safest if that was the case. But, you won't find such separate grounding connections in typical automotive or marine fuel operations. A poster above indicated that he grounds the station nozzle to the metal filler before inserting the nozzle. That is to me the only useful way to deal with the whole grounding issue. If the nozzle and the fuel filler is at the same electrostatic potential, then there is simply no issue of concern.
All that said, I have wire grounded my fillers to the engine/electrical system ground on the boat as a belt and suspenders solution.
Good luck with the mumbo jumbo of the various certification and standards organizations.
Testosterone Tales-Amazon.com
KG7RC
PostPosted: Thu Jan 24, 2013 2:25 pm    Post subject: Reply with quote
It sounds like you really have a good understanding of the issue and lots of practical experience.
I'm not worried about the "mumbo jumbo" (I doubt anyone will be checking my boat for compliance), as much as I want to have things as safe as reasonably possible for myself and those around me. To that end, I sought info.
From what the ABYC fellow told me (and they are all about guidelines, not "laws from on high" - I find them to be reasonable and helpful), what happens when you fill the tank is that fuel swirls around, and that this combined with the plastic tank can cause static electricity, which can make a spark, which can ignite the gasoline vapors. From what I understand, grounding the fills dissipates the static and thus mitigates the hazard.
I guess not having the fills grounded doesn't mean sure explosion, because my boat had 50 hours on it when I bought it, so I imagine it had been filled through the ungrounded fillers; but it does sound like grounding them is the way to go, and it doesn't seem very difficult, so I believe I will.
potter water
City/Region: Logan
C-Dory Year: 1997
Vessel Name: Poopsy
PostPosted: Thu Jan 24, 2013 3:29 pm    Post subject: Reply with quote
All I can say is that hundreds of CD's are out there with plastic tanks that the gas splashes around in and I'm not aware of any of them blowing up grounded or un-grounded. So, I'd add the wires if for no other reason than a picky insurance company finding an excuse not to pay up on a boat fire without regard to the reason for the fire. I'd never trust a wire that is installed out of sight and out of mine (And possibly broken at one end of the other), to save me from any kind of fire. I think there are probably laboratory controlled experiments or a few unusual situations that prove the theory of possible static discharge causing grief, but in practical terms, ground the nozzles against the fill port before inserting into the port and you should be good to go.
Page 1 of 3
Page generation time: 0.0656s (PHP: 72% - SQL: 28%) - SQL queries: 28 - GZIP disabled - Debug on
