Anita Marie
Joined: 01 Nov 2003 Posts: 826 City/Region: Oak Harbor
Vessel Name: Anita Marie
Posted: Wed May 23, 2012 11:58 am Post subject: VHF blowing fuse when transmitting |
I kept blowing the 3 amp main fuse when I try to transmit on my VHF radio. When I replaced it at the dock it worked even at 25 watts. When we were underway it immediately blew again. I checked to make sure the antenna plug was tight.
What would be a good way to check that it was either the radio or antenna? Would just disconnecting the antenna be a good way?
Fred |
Will-C
Vessel Name: Will-C
Photos: Will-C
Posted: Wed May 23, 2012 12:09 pm Post subject: VHF blowing fuse when transmitting |
I would not transmit without an antenna hooked up to the radio as I think I have heard not to do that. I think there is a meter called an swr meter for checking an antenna's condition. It goes inline inbetween the radio and the antenna. Usually bad antenna connections are the problem if the antenna does not appear to have physical damage. Also check the microphone cord for breaks or cracks. You could use a 12v battery to power your radio while connecting to another boaters antenna. That ought to tell you something.
ghone
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
Posted: Wed May 23, 2012 3:19 pm Post subject: |
Hi Fred can you trace to where you pull power for the radio? It should be at a buss bar running as direct as possible to the battery. It may be that it is attached to the alternator charging post and could be seeing a spike over the fuse capacity |
Joined: 02 Nov 2003 Posts: 21469 City/Region: Pensacola
Posted: Wed May 23, 2012 9:36 pm Post subject: |
Although 3 amps theoretically is the "correct" size fuse, almost all VHF's use 5 to 6 amp fuses. There are reasons that the radio draws more than 3 amps at 25 watts. Try a 5 or 6 amp fuse. Although I agree that you should not transmit without an antenna, there are protective circuits which will shut down the final output transisters, and prevent damage. _________________ Bob Austin
sawmilldon
Joined: 07 Aug 2007 Posts: 40 City/Region: Camano Island
Photos: sawmilldon (Name TBD)
Posted: Wed May 23, 2012 10:04 pm Post subject: VSWR check |
A VSWR meter goes in between the transmitter and antenna. It has a switch in the middle, with two positions.
In the forward position it tells you how may watts you are transmitting, in the reverse it tells you how many watts are reflected back at the radio. Hopefully the answer to #2 is not much. A high reflected power indication points to a bad antenna or damaged coax. _________________ Uniflite 27 Sportfisher |
Anita Marie
Posted: Wed May 23, 2012 10:10 pm Post subject: |
Bob, I will try a bigger fuse. The radio has been working for 7 years with not problems. I was wondering, it has a device that allows the AM/FM radio to share the antenna when not transmitting. I believe it shunts the radio when you transmit. Could this be the culprit? |
Posted: Wed May 23, 2012 10:20 pm Post subject: |
Yes, it is possible that this may increase the current draw. I try and avoid these combo antennas. I have seen a number of boats which come with the 3 amp fuse, and it blows--then a 5 amp works fiine. |
Wefings Dealer
Joined: 29 Nov 2005 Posts: 2086 City/Region: Panhandle
Photos: Cruise Ship #4
Posted: Wed May 23, 2012 11:16 pm Post subject: |
I would check your ground connections . A loose one may increase current draw.
Marc _________________ Wefings Marine Website
Since 1909 |
