Has any one ever converted a roller style trailer over to a
Connie Fisher
Guest
PostPosted: Sat Feb 11, 2012 4:00 pm    Post subject: Has any one ever converted a roller style trailer over to a Reply with quote
Has any one ever converted a roller style trailer over to a bunk style trailer?
The 2004, 19’ I/we just purchased came on a tandem, EZ Loader, roller type trailer.
I/we have had both type trailers and much prefer the bunk style trailer.
Since this EZ Loader tandem trailer is a bolt together, my question is;
Is it economically feasible to convert a roller trailer to a bunk style or better to just but a new trailer.
Let me know.
Regards,
Ron Fisher
retnavy
City/Region: Hampton Roads Virginia
PostPosted: Sat Feb 11, 2012 9:26 pm    Post subject: Reply with quote
very easy to do and not too expensive either.........
texasair
City/Region: Cypress, Texas
State or Province: TX
Vessel Name: Bixby's Cub
Photos: Bixbys Cub
PostPosted: Sun Feb 12, 2012 1:12 am    Post subject: Reply with quote
Ron, I too prefer a bunk trailer. Our 22 came with a pretty rough EZ loader roller trailer (galvanized steel, not aluminum) It was a pretty simple matter to add the bunk supports where I wanted them and just weld them to the trailer frame. You have a pretty wide choice as to how many bunks and how you position them.
While I was at it I welded front and rear side guide bars with a 8-10' long carpet covered side board on each side to make loading a breeze.
The local steel supply has galvanized angle iron and square tubing in stock.
Since I had no plans of ever using the trailer for any other boat I had no reservations about welding the supports in place. After cleaning the welds I use a mil spec cold galvanizing compound called ZRC to seal them.
I have over 8 thousand miles on the trailer since the conversion with no issues.
Tex
richnkay
City/Region: Greenville
State or Province: SC
Vessel Name: Annalee
Photos: Annalee
PostPosted: Sun Feb 12, 2012 11:24 am    Post subject: Reply with quote
Ron,
I have been looking at replacing my rear side PVC marker posts with some side guides, either bunk or roller, I'm not sure which would be better. I have been on the West Marine web site and they have a great deal of trailer hardware available there. If you check them out you will be able to see whats there and get a good idea of what the conversion costs will be, doesen't look too bad if you order the parts and do the work yourself.
Rich
Where, then, lies the answer? In Choice. Which shall it be: bankruptcy of purse or bankruptcy of life? In other words, buy the boat!
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Mon Feb 13, 2012 12:55 pm    Post subject: Reply with quote
The EZ Loader roller and bunk trailers use the same frame, just bolt the different parts onto the trailer.
To change, sinply unbolt the U bolts holding the roller assemblies on the frame, and bolt on numk supports and bunks.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
Connie Fisher
Guest
PostPosted: Wed Feb 15, 2012 4:51 pm    Post subject: Reply with quote
Just received an e-mail from Rene Boyer, Sales and Parts, EZ Loader Midwest (800-323-8190 ext 27).
I called Rene with the trailer serial number/model number, she sent back along with the part numbers needed, an exploded assembly drawing for the bunk trailer as an assembly guide.
If I make the bunks here and buy lag screws at the hardware store, the only parts needed are two brackets at $7.45 each, so figure minimal shipping and that’s it.
All that is needed, is the two front bunk brackets (bolts to bunk/attaches to trailer), everything else needed is already with the trailer.
Of course the bunks at $69.85 each and lag screws at $.85 were also available, but to save on shipping etc., we will come up with those parts here.
Rene, made sure to tell me to NOT use treated lumber to make the bunks.
So now all I have to do, is find someone that wants the perfectly good roller set up that now exists on the trailer.
Regards,
Ron Fisher
retnavy
PostPosted: Wed Feb 15, 2012 5:00 pm    Post subject: Reply with quote
why dont you want to use treated lumber for the bunks? Did she say?
Connie Fisher
Guest
PostPosted: Wed Feb 15, 2012 5:33 pm    Post subject: Reply with quote
Rene made sure to caution me about using treated lumber for the bunks, with a following comment that the chemicals in treated lumber is/are not friendly to fiberglass/paint etc.
Regards,
Ron Fisher
retnavy
PostPosted: Wed Feb 15, 2012 6:51 pm    Post subject: Reply with quote
but arent you wrapping the bunk lumber with carpet? I would think the treated lumber would last longer, not sure what is on my trailer but now I have to know
Connie Fisher
Guest
PostPosted: Wed Feb 15, 2012 7:48 pm    Post subject: Reply with quote
All I’m sharing is what I was told by the factory Tech/Rep.
Yes, the bunks that we will make up, will be covered with carpet, I’ll choose untreated Douglas Fir, which will last longer than I will.
Regards,
Ron Fisher
retnavy
PostPosted: Wed Feb 15, 2012 7:59 pm    Post subject: Reply with quote
My lumber choices on the east coast at a big box store are kind of limited so I would have just naturally gravitated towards psi treated wood due to cost. There are various hardwoods out there that are supposedly impervious to rot etc that would be a good choice also if they were not so expensive.
PostPosted: Wed Feb 15, 2012 9:30 pm    Post subject: Reply with quote
I rebuilt my bunk trailer, new bunk boards, carpet and Stainless hardware. I took off treated Doug Fir. The boards were still pretty good but the holes had worn through where the lag bolts were. I could lift the boards up off over the bolt tops. No more lag bolts. I bent the tops over into an inverted "L" shape and then routed a slot to sink them into so that they would not turn when tightening the nuts. Worked great.
Connie Fisher
Guest
PostPosted: Thu Feb 16, 2012 9:14 am    Post subject: Reply with quote
I know that everyone may have their own reasoning about whether to use treated or untreated lumber for trailer bunks.
So I e-mailed Rene and ask her to again please advise and clarify the EZ Loader factory recommendations on material used to fabricate their trailer bunks and here is what I received in return.
“We advise not to use treated because the chemicals in the boards can damage the hull of your boat.”
I/we will follow the factories direction/s and not use treated lumber for trailer bunks.
Regards,
Ron Fisher
akc-dory
City/Region: Fairbanks
PostPosted: Thu Feb 16, 2012 12:48 pm    Post subject: Reply with quote
Thanks Ron for starting this thread. We may want to convert our roller trailer.
I've noticed some small depressions on the hull where the boat sits on the rollers.
Does anybody have any dimensions on where to place the bunks in relationship
to the centerline of the bottom of the boat -- distances apart ? And length ?
We have a 16' Angler, which spends too much of its time sitting on a trailer.
Right now our closest roller is 18" forward of the transom, and from the sound
of things it may be better to add more support near the transom
Connie Fisher
Guest
PostPosted: Thu Feb 16, 2012 2:38 pm    Post subject: Reply with quote
I was really surprised to find that almost all of the parts needed to make the conversion from a roller type trailer to a bunk type trailer were already there, the only parts needed (besides the bunks, which we will make here) were two each of one bracket (less than $20.00).
In fact the exploded parts drawing that EZ Loader sent (via e-mail) answered all assembly questions, with the final adjustments being made at the last minute/s to match the particular boat.
Maybe the maker of your boat trailer will be as helpful as EZ Loader was.
However another solution, once upon a time, several boats ago, I purchased a 16’ Lund fishing boat and was very unhappy with the roller style trailer, the best way to solve that problem was to buy a new trailer, sell the old one on ebay, and move on.
Never regretted that decision, the immediate gratification of being shed of an annoying problem, justified the cost.
Let us know how this works out for you, since I believe many could be asking the same questions.
Come see us at the Mississippi River C-Brat Gathering in Dubuque, Iowa.
Regards,
Ron Fisher
Page generation time: 0.0471s (PHP: 51% - SQL: 49%) - SQL queries: 22 - GZIP disabled - Debug on
