Ray C-80 sources
chromer
C-Dory Model: 19 Angler
Photos: Checkpoint II
PostPosted: Fri Nov 11, 2011 9:23 pm    Post subject: Ray C-80 sources Reply with quote
My Raymarine C-80 is showing a white screen of death. Anyone have a source on new ones ? I am watching Ebay etc..
Checkpoint II (SOLD 10/2020)
Alure Bertram 28
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Fri Nov 11, 2011 9:42 pm    Post subject: Reply with quote
You might check with Capt. Matt who has the Tomcat "Napolean". A search shows several happy C-brat customers
MartyP
PostPosted: Fri Nov 11, 2011 9:56 pm    Post subject: Reply with quote
http://seattle.craigslist.org/see/boa/2691011159.html
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
They are still selling them at a few places but I would not recommend paying a new price for such an outdated unit with all the other devices available for a similar price.
http://www.google.com/products/catalog?hl=en&safe=off&q=c80+rayarine&gs_upl=1630l7286l0l7451l16l12l2l0l0l0l244l1742l2.6.3l13l0&um=1&bav=on.2,or.r_gc.r_pw.,cf.osb&biw=1569&bih=777&ie=UTF-8&tbm=shop&cid=17404297827270113507&sa=X&ei=vN-9TtO1L6TiiALawLz9Ag&ved=0CGkQgggwAA
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
PostPosted: Fri Nov 11, 2011 10:16 pm    Post subject: Reply with quote
Try one more thing before you write it off: turn off all power to the unit by shutting off the batteries. On occasion, our E-80 will not shut down properly (seems to take the right "timing" on holding the off button), and I either get the white screen, or the screen goes black, but you can still see a faint glow of light around the rheostat button. It takes removing all power from the unit to get it to shut down properly and then it starts up fine.
Good luck. I know there are plenty of newer, fancier, sleeker models out there, but I really like my Raymarine.
http://captnjim.blogspot.com/
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Fri Nov 11, 2011 10:22 pm    Post subject: Re: Ray C-80 sources Reply with quote
Are you sure it's the display, and not a component that is the problem? We had a bad GPS puck that took us down. The guys at Rodger's Marine Electronics here in PDX helped me find the issue.
chromer
PostPosted: Sat Nov 12, 2011 1:34 am    Post subject: Reply with quote
Thanks for all the wonderful advice, I will go look at it more tomorrow.
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Sat Nov 12, 2011 10:42 am    Post subject: Try the master reset Reply with quote
I had this happen in the middle of Jackson Lake this past summer. I called the Raymarine people and they told me there is a master reset that you can do...re-boot may be a better word. It consisted of holding down the gray soft button on the bottom left of the console for several seconds. I'm not talking about the power button, but either the left most gray soft button or perhaps the one next to it. The whole think jumped and jived, and came back up and has been fine since. Yours may be the same problem as I experienced, maybe not. Ray marine said it happens on "rare" occasions, usually because one of the gray buttons, will stick and confuse the computer after several minutes. He Also said to check FIRST that I had no other buttons binding in their little holes.
Testosterone Tales-Amazon.com
KG7RC
C-dore
City/Region: Marysville
Vessel Name: C-dore'
Photos: C-dore
PostPosted: Sat Nov 12, 2011 11:10 am    Post subject: Reply with quote
Had this happen to me also some how it got changed to night on the screen and the brightness was to low to see it. Some how I got it back to the day screen.
Peter_BDA
City/Region: Bermuda
C-Dory Model: 22 Classic
Photos: Luna-Sea
PostPosted: Sat Nov 12, 2011 11:59 am    Post subject: Reply with quote
If you need a new one, check these guys out-I have always bought my electronics from them including a C80 on my last boat and the Garmin for my C-Dory.
http://www.consumersmarine.com/
Peter
Peter Aldrich
Bermuda
Sea Angel
Photos: Sea Angel
PostPosted: Sun Nov 13, 2011 6:59 pm    Post subject: Reply with quote
I had the same problem after 5+ years without any previous problems.
I tried the usual power off-on cycle, but it did not work.
I pulled all the connectors from the rear of the C80 display,
sprayed the male and female contacts of the connectors with electronic
contact cleaner/lubricant and --
I reseated the connectors a couple of time before I re-applied power.....
This worked and has continues to work after 6 months without a hitch.
A cheap fix, if it works.
Art
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
Page generation time: 0.0433s (PHP: 63% - SQL: 37%) - SQL queries: 25 - GZIP disabled - Debug on
