Bilge pump and wiring
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
PostPosted: Mon Nov 07, 2011 1:31 pm    Post subject: Bilge pump and wiring Reply with quote
My bilge got something stuck in the impeller that prevented it from running when I hit the manual on switch. It fried the fuse (10A) which I can replace, but should the pump still be ok after this? From the dash light it looks like it might have been turned on for >30s seized before the fuse burnt.
Second, the wiring for the pump seems hacky. It's got regular (non-waterproof) wire nuts in the starboard hatch and in the bilge 6" away from the pump. These wire connections were wrapped in some black tape that didn't seem water resistant either. I know there are "waterproof" wire nuts but I'd prefer to use something like a waterproof inline crimp splice that can be cleanly wrapped with thick self-sealing electrical tape stuff (don't know what it's called).
Sorry for multiple threads but it's probably better for future reference to keep topics separate, right?
Thanks!
PostPosted: Mon Nov 07, 2011 5:38 pm    Post subject: Reply with quote
Clean out the pump suction, put in a new fuse and try it. Hard to tell from here! Rolling Eyes
ferret30
Photos: Lily Pad
PostPosted: Mon Nov 07, 2011 6:23 pm    Post subject: Reply with quote
Ok, maybe I wasn't clear. I know I can test out the pump myself. What I meant was:
Even if the pump still works after cleaning it (which I did) and replacing the fuse, should it be trusted? The boat only has a single bilge and this one was turned on while stuck for >30s until the fuse burnt up.
hambone
PostPosted: Mon Nov 07, 2011 7:05 pm    Post subject: Reply with quote
If in doubt change it out. That's my motto. But that's just me. Smile
H Wink
Hawg Hunter Productions.
C-Nile
City/Region: Connecticut
State or Province: CT
C-Dory Year: 2012
Vessel Name: Betty Ann
Photos: C-Nile
PostPosted: Mon Nov 07, 2011 7:16 pm    Post subject: Reply with quote
Two year's ago, I had a 5-amp fuse for the bilge go bad, but it passed a continuity check! When I put the voltage meter on it, it would only allow about 6 volts to pass -- not 12. Essentially, the metallic element was corroded, and it would not allow the bilge pump to operate. After replacing the fuse, everything worked fine, so I agree with Sea Wolf that to be safe, just replace it.
Rich
Marinaut 215 - "Betty Ann" Sept-2011
CD 16 Cruiser "C-Nile" Sold 06/2011
ferret30
Photos: Lily Pad
PostPosted: Mon Nov 07, 2011 7:18 pm    Post subject: Reply with quote
Yep, I found a RuleMate manual online, and I don't currently know which pump it is (the boat is stored 15 miles away) but the recommended fuse size is 1.5A or 2.5A. The installed fuse was 10A! Might be good to keep a replacement on board at least! Actually, I need to dig around a little since I think the boat may have come with a spare...
If my driveway wasn't off of a 15% inclined street I'd keep my boat in my driveway and work on it anytime!
Thanks guys
ferret30
Photos: Lily Pad
PostPosted: Mon Nov 07, 2011 7:23 pm    Post subject: Reply with quote
Rich
Are you saying to replace the pump or the fuse? I was thinking of replacing the pump since it was powered so long while the fuse burnt, but your message is making me think you're talking about just replacing the fuse.
In my case the 10A fuse (too big according to the RuleMate instructions) is definitely burnt and the plastic part of the fuse is deformed.
Dreamer
Photos: Dreamer
PostPosted: Mon Nov 07, 2011 7:29 pm    Post subject: Reply with quote
f-30,
Drop by Fisheries Supply in Seattle and get some of These They'll keep water out of your connections.
Dreamer- Sold 25 Feb. 2013
ferret30
Photos: Lily Pad
PostPosted: Mon Nov 07, 2011 7:37 pm    Post subject: Reply with quote
Dreamer wrote:
f-30,
Perfect. I suspected there was an ideal connector. Time to get rid of some big wads of tape and wire nuts!
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Mon Nov 07, 2011 7:59 pm    Post subject: Reply with quote
I once owned a boat where the connector of choice was wire nuts, and the fastener of choice were sheetrock screws. Ugh. The things some guys do....
If the pump runs, I think you may be okay, but if you have doubts, replace it for the peace of mind. A few hundered bucks for new pump and connectors is better than lying awake at night!
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
C-Nile
C-Dory Year: 2012
Photos: C-Nile
PostPosted: Mon Nov 07, 2011 8:30 pm    Post subject: Reply with quote
I believe the Rule 1100 specifies a 5 AMP fuse. By having a 10 AMP fuse in place, it allowed 10 AMPS of current to the motor windings, creating a lot of heating, and possibly melted the windings' insulation coatings. So it is best to replace the motor, and insure that the fuse you use is the one specified by the manufacturer. If you had a 5 AMP fuse in place, and the motor seized, you might have gotten away with not replacing the pump, but at 10 AMPS, you're taking a chance in using the old pump.
I apologize for the confusion I caused on my previous post.
Thanks!
Rich
PostPosted: Mon Nov 07, 2011 8:53 pm    Post subject: Reply with quote
Just because there's a 10A fuse in place that burned out doesn't mean that 10A went through the motor windings. The motor (when working properly) will only draw the amount of current that 12V through the motor windings will allow - in this case < the 1.5 or 2.5 A or 5A fuse that Rule specifies (it's hard to tell what Rule really specifies from the above collection of posts). The purpose of the fuse is NOT to protect the pump but rather to protect the wiring to and from the pump. If a 10A fuse blew, it suggests a leak to ground someplace in the wiring system as opposed to burn pump windings. Given the brief description of the less than quality wiring job that the previous owner did, my bet is that the pump is just fine. I'd replace any connectors that look bad with proper marine connectors and assure that marine grade wiring was used. A bilge pump should be able to run many, many minutes without burning up (>30s is not a problem).
20dauntless
Photos: Retriever
PostPosted: Mon Nov 07, 2011 9:03 pm    Post subject: Reply with quote
I'd keep the pump, fix the wiring, and then add a second bilge pump.
ferret30
Photos: Lily Pad
PostPosted: Mon Nov 07, 2011 9:04 pm    Post subject: Reply with quote
Hi Roger, I believe the pump was seized and powered for >30s, not running dry. It has run fine until this weekend and I verified by hand that something was keeping the impeller from spinning. When I tested it, I turned the pump on with the manual override on the console and it lit up for 30s or more but the pump was silent because it was stuck. at least tours that's what I'm thinking.
Papacorn
City/Region: Pincher Creek
State or Province: AB
PostPosted: Mon Nov 07, 2011 10:20 pm    Post subject: Reply with quote
Contrary to what others have said here, I would assume the pump saw 10amps. An electric motor that has voltage applied is almost a dead short (limited only by the winding resistance which is not a lot) until it starts to turn and then the counter electromagnetic force reduces the current flow. If you hang up a downrigger ball , you blow the fuse because the motor won't turn.
The pump , if working, is likely OK but you seem worried about it, so for a few bucks buy another and take a load off your mind.
Page generation time: 0.0659s (PHP: 58% - SQL: 42%) - SQL queries: 28 - GZIP disabled - Debug on
