Water Under Berth
LesR
City/Region: St. Louis
State or Province: MO
Vessel Name: Intuition
Photos: Intuition
PostPosted: Fri Oct 14, 2011 3:05 pm    Post subject: Water Under Berth Reply with quote
We've had our 25 for two blissful years, and today I cutout holes for hatches in the berth.
Good news: there's no foam to dig out.
Bad news: there was a good gallon of water sloshing around in there
Based on what I've read previously, the anchor locker is my first guess for the culprit, and I should be able to easily verify if it's the cause.
Alternatively, I assume it could be the brass keel guard.
Any other possibilities or things I should be checking?
Thanks for all the wonderful help and information here!
- Les
PostPosted: Fri Oct 14, 2011 3:44 pm    Post subject: Reply with quote
Oh, boy. We have an '07 too, so I'll be watching this.
I did remove the brass keel guard after Karl posted his issue w/ it popping out & leaking. I cleaned the holes & plugged them w/ thickened West Marine epoxy and installed a Keel Guard.
PostPosted: Fri Oct 14, 2011 6:10 pm    Post subject: Reply with quote
Other possible places, rub rail fastenings, bow pulpit fastenings, any hull penetrations above the waterline forward of the helm station. If it were below the waterline, you'd have had a lot more than a gallon!! Disgust
LesR
Photos: Intuition
PostPosted: Fri Oct 14, 2011 6:43 pm    Post subject: Reply with quote
After a little more troubleshooting this afternoon, the anchor locker is at least part of the issue. After drying our the hull forward of the bulkhead, I poured about a cup of water into the locker via the hause pipe (don't have a windlass).
As I've heard previously, the drain for the anchor locker is about a half inch higher than the bottom of the locker. Feeling against the aft section of the locker, the joint feels ragged, as if it's not well sealed.
Sure enough, the water began to collect against the bulkhead below the berth.
We normally have a cover over the boat, but have certainly spent enough time out in the rain for that much water to collect.
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Fri Oct 14, 2011 6:53 pm    Post subject: Reply with quote
I had a leak in my water pump under the rear dinette seat and the water would collect under the v-berth. I found it when I couldn't figure out where the water was coming from on the floor while we were under way. The water tank on the 2005 is under the v-berth so I figured the water tank was leaking. I cut a hole so I could see the water tank in the center bulkhead and then cut a hole in the floor where I installed a hatch (left over from hatch replacements on my old 22). When I cut the hole in the floor in the v-berth it became apparent that it wasn't the water tank, but was coming from somewhere toward the stern. I backtracked and found a small leak on the outlet of the pump that could only be felt and not seen. The water flowed down toward the center of the boat under the custom floor and collected at the low spot under the v berth. The low spot when the boat is on the trailer is under the v-berth. When underway the water flowed from the v-berth back toward the stern and came up through the floor because the bow was higher.
Tightening a hose clamp solved the problem.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
PostPosted: Fri Oct 14, 2011 7:15 pm    Post subject: Reply with quote
Hi Les,
Looks to me like you have the likely suspects. Our boat was the first of the 2007 models, and it, too, had the leak under the v-berth. Our cause was the bad drain in the anchor locker. We also have foam under our v-berth... so, it's hard to know exactly how much water soaked up in that foam.
We also had a leak from the port rubrail that made its way behind the head compartment and onto the cabin floor. I removed the rubrail, resealed it, and that took care of that problem.
Good luck with the projects... once you get 'em done, the boat stays pretty water-tight... well, except for those hatches on aft cockpit floor. Rolling Eyes
Les Lampman
Dealer
City/Region: Whidbey Island
PostPosted: Fri Oct 14, 2011 7:24 pm    Post subject: Reply with quote
Jim,
Did you ever see Hank Brooks' solution for the aft cockpit hatches (he had Sea Skipper)? If not the photo album may still be here. If that's not the case I can try and recreate the fix.
Les
Les
www.marinautboats.com
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Fri Oct 14, 2011 9:21 pm    Post subject: Reply with quote
Was it the aluminum brace added to the underside Les?
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
PostPosted: Fri Oct 14, 2011 9:31 pm    Post subject: Reply with quote
Hi Les,
Yes, I did see those photos and visited with Hank before he sold Sea Skipper. He gave me some good tips when we ordered our boat. I haven't done anything with our cockpit hatches... yet.
PostPosted: Fri Oct 14, 2011 10:04 pm    Post subject: Reply with quote
Here's the relevant photo and Hank's text explaining it.
From_Sea_Skipper_Album_Hank_ wrote:
Batteries are installed below the deck hatches to keep weight low and free up storage space in transom - house bank shown. Solenoid operated battery switches are remotely controlled from the helm station. Truss mounted to underside of deck hatch improves seal by preventing ends of hatch from springing upwards. The truss is designed to bend the ends of the hatch downward about 1/16" which flattens out when dogged closed.
Les Lampman
Dealer
PostPosted: Sat Oct 15, 2011 2:25 pm    Post subject: Reply with quote
That's the information I was referring to! Thanks for finding and posting that.
Hank told me it worked out very well for him and I was quite concerned with it since we had mounted the batteries below the deck.
Les
Page generation time: 0.0381s (PHP: 68% - SQL: 32%) - SQL queries: 24 - GZIP disabled - Debug on
