De lamination in floor between fuel tanks?
island park
City/Region: Ft Myers
Vessel Name: Island Girl
Photos: Island Park (Name TBD)
PostPosted: Tue Sep 06, 2011 9:20 pm    Post subject: De lamination in floor between fuel tanks? Reply with quote
I have tried for hours to post a picture of my problem here with no luck so I hope that someone will help. I was cleaning under the dri-deck between my fuel tanks when I found an area that had the coating (gel coat?) flaking off. The area that was revealed looks to have wooden strips with the edges exposed. Could this possibly be the wood coring showing under a layer that is only the thickness of a couple of thick coats of paint? I have only had the boat since April and did not notice this before. Thank You, Paul
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Sep 06, 2011 9:23 pm    Post subject: Reply with quote
Maybe it is a piece of wood with gelcoat over it and intended for mounting your bilge pump
Brent Barrett
island park
PostPosted: Tue Sep 06, 2011 9:30 pm    Post subject: De lamination in floor between fuel tanks? Reply with quote
Brent. the area affected is about 12" in front of the bilge pump well.
BrentB
Photos: BrentB
PostPosted: Tue Sep 06, 2011 9:39 pm    Post subject: Reply with quote
sorry wrong guess
You need an album.
Do you have a Google email account? If so, post in your Google Photo album
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Sep 06, 2011 10:07 pm    Post subject: Reply with quote
BrentB wrote:
sorry wrong guess
You need an album.
If you get it in another album (Google - Flickr), get the image up on the screen and right click on it (Apple, PC should be similar) and select "Copy Image address" or something like it. Then in the CBrats thread click on the "Img" box, past the link, then click on "Img" again. That should put the photo in the comment.
island park
PostPosted: Tue Sep 06, 2011 10:53 pm    Post subject: De lamination in floor between fuel tanks? Reply with quote
No flickr or google account. Sorry, I wasn't prepared to post pictures, but I just discovered this problem earlier this evening.
PostPosted: Wed Sep 07, 2011 12:31 am    Post subject: Reply with quote
Paul wrote: "I was cleaning under the dri-deck between my fuel tanks when I found an area that had the coating (gel coat?) flaking off. The area that was revealed looks to have wooden strips with the edges exposed."
Paul-
Could it be a structure intended to box in the base of a battery box to keep it from sliding around?
Maybe someone didn't want to drill holes in the floor to attach the stainless strap fittings to cinch the battery box to the floor?
Probably 'homemade", and therefore not too durable, hence the delamination?
Just a guess, based on the description and the fact that folks often add a second battery in that location.
island park
PostPosted: Wed Sep 07, 2011 6:43 am    Post subject: Reply with quote
Joe, it doesn't appear as though anything was added. The area looks to be the same level as the rest of the cockpit floor. My inability to post a picture here is frustrating beyond words. Perhaps, I should try the Hull Truth or another site were I might be able to post a picture.
PostPosted: Wed Sep 07, 2011 7:59 am    Post subject: Reply with quote
Oh no, please don't be frustrated. Posting pictures is very easy. Most all the albums in the CBTech Library are set so any member who is logged in can upload pictures to them. Just choose the appropriate album and go for it. Now it is even easier for you - I made you your own album and linked it to your profile info. I also sent you the generic how-to PM about uploading pictures.
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Wed Sep 07, 2011 8:21 am    Post subject: ft myers naples area Reply with quote
where in ft myers do you live Im in n naples area I could help you post pictures I could meet you send me a pm or e-mail Jim I sent you a pm
Dreamer
Photos: Dreamer
PostPosted: Wed Sep 07, 2011 12:53 pm    Post subject: Reply with quote
Here's the foto
Dreamer- Sold 25 Feb. 2013
Wandering Sagebrush
PostPosted: Wed Sep 07, 2011 1:02 pm    Post subject: Reply with quote
Well that is interesting. From the photo, it appears that gelcoat/paint is flaking off to reveal stringers under a clear glass top coat.
Can you physically touch the wood? If not, and there is a good layer of glass, my suspicion is that there is nothing wrong. I sure hope that is the case!!!
PostPosted: Wed Sep 07, 2011 1:58 pm    Post subject: Reply with quote
If this is level with the rest of the floor, I suspect that there was one layer of mat or even chopper gun material, and some sprayed on gel coat. The boats are laminated in the mold, with gel coat, mat, roving / mat alternate layers on the bottom outside. Then the end grain balsa core, finally it should be a few layers of mat and cloth, or even a layer of roving. But on my C Dory 25, there were areas which were just one layer of mat--and then gelcoat.
My suspicion is that what you are seeing is the end grain balsa. However, the red stripes are a little puzzling to me. Can you easily stick a tooth pick or even an ice pick into the wood? Is the wood wet?
There aren't any stringers in the bottom of a C Dory 22. It is also possible that there is clear resin, and a layer of mat and cloth--and that the bottom was gel coat/paint which did not adhere well.
First we need to find out what the composition is--and then probably you will need to add another layer, and re-paint. You might even consider truck bed liner as the finish coat for the cockpit. It is essential that the wood be sealed.
BrentB
Photos: BrentB
PostPosted: Wed Sep 07, 2011 2:45 pm    Post subject: Reply with quote
Maybe you can remove more of the paint or gelcoat from the area and post addtl pics
best
cruiserlessvinny
City/Region: Suwanee
State or Province: GA
Photos: cruiserlessvinny (Name TBD)
PostPosted: Wed Sep 07, 2011 3:52 pm    Post subject: delamination Reply with quote
Not so sure this is delamination. It looks more like the gel-coat is flaking. Delamination typically describes a situation where the composite mat layers are separating or the entire composite assembly is separating from the substrate to which it was applied. Flaking is more cosmetic than de-lamination.
cruiserlessvinny
I have a classic Whaler. Now I think I want a cruiser. I'm so-o-o-o-o confused.
Page generation time: 0.0579s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
