Vortex Lubrication System Hubs
BRAZO
City/Region: Full-time Travel
State or Province: NV
Vessel Name: Meyer Meyer
Photos: BRAZO
PostPosted: Mon Jul 18, 2011 12:23 pm    Post subject: Vortex Lubrication System Hubs Reply with quote
I'm planning to change my trailer bearings/hubs to the oil bath version, but then I came across the Vortex Lubrication System Hubs. They are maintenance free for 6 years or 100,000 miles.
Anyone have experience with these?
http://www.tiedown.com/avortex.html
2008 CD22 Twin 50hp
PostPosted: Mon Jul 18, 2011 12:43 pm    Post subject: Reply with quote
Design, schematic etc looks just like Superlube hubs. Caps are different though.
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Mon Jul 18, 2011 4:45 pm    Post subject: Reply with quote
The difference between the Vortex and the Superlube is that the Vortex is a sealed system with the cap in place, where the Superlube has a rubber cap in place that isn't water tight.
I would be concerned with the aftermarket version that an owner would be tempted to "add just a bit more grease" and blow the seals out of the system.
In any event- used properly, these look interesting. The advnantage to the Superlube style spindles is that you can easily check the grease and add more as needed.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Mon Jul 18, 2011 5:37 pm    Post subject: Vortex Lubrication System Hubs Reply with quote
My trailer has the superlube spindles. If you keep them full of grease there is no place for water to go. I replace the seals every year along with the tin caps and rubber covers. I deal with salt water mostly and see no water contamination. I think the idea with the Voltex style is that on the after market version you only add grease when the threaded cap if off. Add grease with cover on yeah momma something has to give. I think the threaded cap is the only real difference in between the oem version of superlube and the new Voltex version.
D.D.
Page generation time: 0.0378s (PHP: 63% - SQL: 37%) - SQL queries: 17 - GZIP disabled - Debug on
