Replacement vinyl window seal
colvosview
City/Region: Gig Harbor
Vessel Name: C-heeto
PostPosted: Tue Jun 21, 2011 12:22 pm    Post subject: Replacement vinyl window seal Reply with quote
I took my 87 22' Angler to a glass shop because the seal in center front window is distorting and pulling loose somehow. They called and asked if I could get a new seal from the factory, which I figure is pretty unlikely, but I also figure it's very likely that someone here will have a suggestion! Anybody dealt with this before? My wife wants to cruise to a Ruston Way restaurant for her birthday on the 29th, and we don't need this delay!
Thanks in advance.
David S
Gig Harbor, WA
PostPosted: Tue Jun 21, 2011 12:34 pm    Post subject: Re: Replacement vinyl window seal Reply with quote
Thanks in advance.
Call the factory. I bet you they'll help out. Or email Scott Boysen <Scott@TritonMarine.us>.
colvosview
PostPosted: Tue Jun 21, 2011 12:52 pm    Post subject: Reply with quote
Thanks, Roger. I'll give it a try.
PostPosted: Tue Jun 21, 2011 3:02 pm    Post subject: Reply with quote
I have pulled all of the gaskets on my windows and clean them. Unless its torn or really hard their is not reason to replace it. Just pull it out and clean it and the slot it was in. Then whip it down with armor-all or similar product and replace it. you will end up with a small gap in the seal but I just filled it with silicone or 4500 and let dry. really easy to do. just use a butter knife and some 409 or Windex to push it back in.
Peter_BDA
City/Region: Bermuda
C-Dory Model: 22 Classic
Photos: Luna-Sea
PostPosted: Tue Jun 21, 2011 3:22 pm    Post subject: Reply with quote
Your window may have come from Diamond Seaglaze can also send you replacement rubber moulding as well. I recently purchased some new track from them and they were very helpful.
www.diamondseaglaze.com
Peter
Peter Aldrich
Bermuda
PostPosted: Tue Jun 21, 2011 3:23 pm    Post subject: Reply with quote
Contact Diamond Sea Glaze. They manufacture the windows and are a source of the gaskets:
26995 Gloucester Way
Langley, B.C.
Canada V4W 3Y3
Phone: (604) 607-0091
Or: 1-800-770-0455
Fax: (604) 607-0092
e-mail: info@diamondseaglaze.com
A good gasket maker can most likely make you a similar gasket--assuming that you have a rubber and gasket maker locally. Pensacola, FL has one.
colvosview
PostPosted: Wed Jun 22, 2011 11:46 am    Post subject: Reply with quote
Thanks, everyone!
Page generation time: 0.0304s (PHP: 64% - SQL: 36%) - SQL queries: 20 - GZIP disabled - Debug on
