Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Wed Jun 01, 2011 11:52 pm Post subject: 12v question for the gurus |
The 2 Raymarine E-80s on my Tom Cat have been increasingly been refusing to play nice with each other (not recognizing the master/slave relationship, spontaneously rebooting, etc.) The guy who sold them to me (very knowledgeable vendor) told me there were two possibilities that I should investigate as low-hanging fruit:
1. Update the software in both MFDs, and
2. Replace the Raymarine SeaTalk (Ethernet) hub as it has been problematic on several of his installations.
It's #2 that I need help with. I was advised that any good 8-port hub should work. I purchased a D-Link unit that received a great many 5-star reviews. It has an adapter that is marked 5v, 1.2 amps. I can plug the hub into 110v from my inverter but I would prefer to run it off the boat's 12v system and not be dependent on the inverter.
I need to know if it will harm anything if I wire the hub directly to 12v power. My vendor says he routinely wires hubs with 9v adapters into 12v without problems. Is the same true for a 5v device? Is some sort of adapter needed?
I'm trying to avoid going to the vendor and paying for a service call.
M/V Lori Ann
Anacortes, WA
Larry H
C-Dory Year: 1991
Photos: Nancy H
Posted: Thu Jun 02, 2011 12:19 am Post subject: |
Try a google search on '12 volt to 5 volt adapter'.
I got lots of hits. _________________ Larry H
A C-Brat since Nov 1, 2003
jkidd
Joined: 23 Oct 2006 Posts: 1668 City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
Posted: Thu Jun 02, 2011 2:30 am Post subject: |
You could just build a voltage divider circuit with couple of resistors and connect your power leads across the resistor that measures 5 volts. Or you could use a potentiometer and just adjust it till you get 5 volts. Or you look at other brands that already run off of 12 volts. I don't think you can just hook the 5 volt one up to 12 volts it would just burn up. If it were 9 volts you might get away with it. _________________ Jody Kidd
KE7WNG
Northern, Utah
potter water
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
Posted: Thu Jun 02, 2011 10:10 am Post subject: Don't mess about with this |
Definitely find a high quality 12 volt to 5 volt converter. There are sooooo many ways to go wrong doing it any other way. You've already said that things are flaky. This would not be the time to Rube Goldberg something together to make the replacement you have in mind work to cure a prior flaky bug. You could easily introduce a new weirdness into the system. _________________ You can tell a man his wife is ugly, but never ever criticize his dog, his gun, his truck or his boat.
Testosterone Tales-Amazon.com
KG7RC |
centerisland
Joined: 19 Feb 2007 Posts: 336 City/Region: Mercer Island
Vessel Name: Lulu
Posted: Thu Jun 02, 2011 11:53 am Post subject: |
USB voltage is between 4.75 V and 5.25, so any automotive USB adapter should give you the right voltage.
Upon reflection, probably not enough current for your application _________________ 36' Little Harbor Whisperjet - Lulu
44' Custom F/C Trawler - Refugio - SOLD
CD22 - Curlew (ex-SeaDNA) - SOLD by Les! |
Larry H
C-Dory Year: 1991
Photos: Nancy H
Joined: 02 Nov 2003 Posts: 21357 City/Region: Pensacola
Posted: Thu Jun 02, 2011 1:25 pm Post subject: |
First try the hub you purchased with its own 110 V to 5 volt adaptor at the dock or on the trailer, to be sure it is working properly.
Then go to Radio Shack and get a 12 volt DC to 5 volt DC adaptor. Pay attention of polarity of the plug--you will also take your hub and adaptor to double check the amount of power necessary -1.2 amps-, polarity, size of plug (both external diameter and internal diameter). Finally wire this into the 12 volt system--again being careful about the 12 volt polarity (center of the cigarette type of plug is positive). I would wire it in, and use the same circuit you use to turn the RayMarine gear on and off with. Since you are replacing a hub, the current draw should be approximately the same, and a fuse size change will probably not be necessary.
One thing I would do before that, however, is to spray some contact cleaner on the cable end fittings, and the current hub. Disconnect and connect several times, then wipe the contacts clean with a soft rag. Then spray a small amount of corrosion block on the terminals. I would also check all of the 12 volt connections. Clean them, spray with corrosion block. It is quite possible that just minor corrosion (you may not see it) on the connectors and a slightly low voltage can cause the entire problem. _________________ Bob Austin
centerisland
Vessel Name: Lulu
