Horse before the cart or Air Cond wont fit in the window
JGrider
City/Region: Laplace
State or Province: LA
Vessel Name: Jeannie's VOO DOO
Photos: Jeannie’s VOO DOO
PostPosted: Thu May 19, 2011 12:42 am    Post subject: Horse before the cart or Air Cond wont fit in the window Reply with quote
I have been asking all of my newbie questions to Thataway. I dont want him to get tired of my questions before I even get the chance to say Hi in person. I have a lot of questions. So I need to bother the rest of you guys out here too.
I bought the Air conditioner from Home Depot just like Comfy Dory but I did not see that the Compass was to high to let is slide into the front window. I'm new at this and I do not want to start putting holes in my boat before I look at all of my options. If I move the compass is the hole easily filled as good as new? The only place I see to put it back would be next to the drivers window and to put it there I would have to move the chart plotter a little to port, left I think. Any suggestions floating around out here?
John & Jeannie Grider
Jeannie's VooDoo
Home port: LaPlace, Louisiana
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Thu May 19, 2011 5:29 am    Post subject: A/C window Reply with quote
We had the same problem with our cd-22 .We ended up moving the gps plotter closer to the starboard window and moved compass make sure you have some space between compass and gps or windshield wipers Look at my Duck album picture 26 shows the compass on port side I eventually put the compass on starboard and moved gps
You can fill holes in with epoxy or just put in S/S skrews in holes . and wait for one of your friends to fix the small holes
The A/C is worth a few small holes for sure .
Tad and Toby Jackson
City/Region: Merritt Island
Vessel Name: Comfy Dory
Photos: Comfy Dory
PostPosted: Thu May 19, 2011 7:56 am    Post subject: Reply with quote
John,
On the Comfy Dory, we have a Garmin 498 that is mounted on the dash above the steering wheel. Our compass sits to the right of that nearer to the window and the dash under the front window is clear. Repair small holes with white Marine Tex...very easy and you only have to make up small amounts at one time. Buy yourself a square drive screwdriver for removing the bottom of the window braces where they attach to the inside of the window frame...that allows you to open the widow far enough for the AC to slide through.
What kind of generator are you going to use for the AC?
Tad
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Thu May 19, 2011 9:45 am    Post subject: Reply with quote
Remove the compass and keep a good handheld available if one is needed. There has been some discussions lately on the usefulness of this classic device and with your chartplotter already in place. I would call it a backup and keep it handy but tucked away. We have a huge impressive compass mounted in the position you speak of and I would have no qualms ripping it off it there was a conflict. Heck, I may take it off regardless. And just for a point of reference, I have taught regional classes on wilderness navagation for the last 10 years to first responders and recreationalists so I do know the value of the device. But I also have two chartplotters active on my boat at all times and would carry and nice handheld or something like the one below if I were to remove the mounted version we have now.
http://www.thecompassstore.com/rx11y.html
Or a dash mount could be used?
http://www.thecompassstore.com/v572.html
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Thu May 19, 2011 10:04 am    Post subject: Reply with quote
I wish i had your problems,that is needing an air conditioner on my boat.It must really get hot there, i seldom if ever have the need to use an air conditioner even in my truck.Good luck fixing your air conditioner. Tug
smittypaddler
City/Region: Neenah, Wisconsin
Vessel Name: Na Waqa
PostPosted: Thu May 19, 2011 10:14 am    Post subject: Ritchie Explorer Compass Reply with quote
I have a Ritchie Explorer compass mounted on the flat surface just aft of the front window. It sits on a pedestal, and is removable with a click of a button. I remove it, and also my radar screen, when I want to put in my air conditioner. Here are some photos when the a/c is installed:
http://smittypaddler.com/cds/cdc/fl11/d110318.htm
This has been edited. The original post had a bad link above.
JGrider
PostPosted: Thu May 19, 2011 10:30 am    Post subject: Horse before the cart or Air Cond wont fit in the window Reply with quote
Everyone agrees, so the compass will get moved today. I did not buy a generater. My brother-in-law is giving me one but It looks and appears to be like the Honda 2000. I do not know the brand but I know it is about $300.00. I have a great brother-in-law.
Although the weather here has really been great lately I know what is coming in a month or so. If I expect my Jeannie to spend much time with me I know it has to be comfortable, atleast to sleep. I will keep everyone updated on the cheap generater.
JGrider
PostPosted: Thu May 19, 2011 11:33 am    Post subject: Horse before the cart or Air Cond wont fit in the window Reply with quote
Thanks Smitty for the repaired link. I need to look at my compass better and see what model I have before I move it to another location,
patrick and linda
City/Region: somerset
State or Province: KY
C-Dory Year: 1986
Vessel Name: "Fan-A-Sea"
Photos: Misty Seas
PostPosted: Thu May 19, 2011 3:46 pm    Post subject: Reply with quote
my first time drilling into fiberglass really concerned me. now i cut, saw and drill with no problems. actually fiberglass is very forgiving. matching up gel coat can be a little challenging but like everything else, take your time and you should have no problems.
recently i removed fishing rode holders that were attached by screws, to the sides of the cockpit in the boston whaler i recently purchased. there were 18 screw holes which needed filling. i bought marine tex (white) followed directions and started filling in the holes. keeping the filler inside the holes was challenging but after a while i managed to get enough to stay in each hole. after the compound dried i sanded with 180 and then 220 grit, then touched up with gelcoat, polished and the result looks good, not perfect but ok. i am approaching the age that ok is acceptable! i must be maturing.
post pictures of your completed project when finished.
best regards
pat
PostPosted: Thu May 19, 2011 5:52 pm    Post subject: Reply with quote
Whoa, hey wait a minute, You don't have to remove the compass and move the plotter screen. Shucks, you don't even need to mount the AC, just move to the PNW and enjoy the greatest natural air conditioning in the country Wink Rolling Eyes Rolling Eyes Disgust Laughing
Hey, we are having our first 4 day stretch of sunny in 180 days and should be over 70 today. Spring is here.
PostPosted: Thu May 19, 2011 6:48 pm    Post subject: Reply with quote
Damm it Harvey!! they are going to hear you and it will start raining again. SHHHHHHHHH. Evil or Very Mad
PostPosted: Thu May 19, 2011 7:02 pm    Post subject: Reply with quote
Sorry Tom, it's been saving me from watering my rhubarb Embarassed Embarassed Embarassed
PostPosted: Thu May 19, 2011 7:52 pm    Post subject: Reply with quote
I would keep the compass. There are times when it is necessary, and a good back up. Also compensate it after it is moved, so it is accurate. The proximity of the chart plotter and radios etc may cause some deviation.
I do occasionally use marine tex--but gelcoat is better. After applying marine tex--it is harder to get a good gel coat repair.
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Thu May 19, 2011 7:53 pm    Post subject: Reply with quote
hardee wrote:
Sorry Tom, it's been saving me from watering my rhubarb Embarassed Embarassed Embarassed Harvey
Never, Ever have I watered rhubarb.....I've even mowed it down flush with the turf and it still thrives! If I were that resilient, I know I could continue cruising on my C-Dory another 100 Years! Smile
Dave S.
"Sea Shift"
C-Brat #16
PostPosted: Thu May 19, 2011 11:52 pm    Post subject: Reply with quote
Dave,
I have no doubt you will be around much longer than my rhubarb Thumbs Up Thumbs Up
Page generation time: 0.0489s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
