Raising trailer tongue higher than standard jack
Goto page 1, 2, 3  Next
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Wed Mar 16, 2011 5:12 pm    Post subject: Raising trailer tongue higher than standard jack Reply with quote
I park my 22 on a slight downward slope. The standard tongue jack does not crank up far enough to tilt the boat back to drain the cockpit. I would appreciate any suggestions for tools or methods to get the tongue higher, for storage. I have done it by jacking it up, sticking a board vertically under the tongue, retracting the jack, putting a block under the jack, jacking further, etc., but it is a pain.
Doryman
M/V Lori Ann
Anacortes, WA
B~C
City/Region: Bend
Vessel Name: Blue~C
Photos: Blue~C
PostPosted: Wed Mar 16, 2011 5:55 pm    Post subject: Reply with quote
I use the same method but use a jack stand, they're handy to have around if you're working on brakes. Here is a quality chinese built set-
http://www.walmart.com/ip/Torin-Jacks-3-Ton-Jack-Stand-Pair/14560047
Ken
1999 22' boaterhome
PostPosted: Wed Mar 16, 2011 6:11 pm    Post subject: Reply with quote
John Deere.
B~C
City/Region: Bend
Vessel Name: Blue~C
Photos: Blue~C
PostPosted: Wed Mar 16, 2011 6:12 pm    Post subject: Reply with quote
that just aint sporting
Doryman
Photos: Lori Ann
PostPosted: Wed Mar 16, 2011 7:03 pm    Post subject: Reply with quote
I looked into jack stands at the NAPA store here but I saw two problems with them: (1) as you said, you still have to go through the multi-step process of using the tongue jack as an intermediate -- basically this works the same as my board approach; and (2) the ones I saw at NAPA (and I think also these WalMart ones) do not extend up enough.
What I want is some kind of a lifting jack that will get the tongue up to its final height in one fell swoop. Maybe such a beast does not exist and I will have to continue with the multi-step process, perhaps improved with jack stands on boards or blocks.
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Wed Mar 16, 2011 7:27 pm    Post subject: Reply with quote
I tried to find something like a taller jack but no luck. So I do the multi step process.
PostPosted: Wed Mar 16, 2011 7:29 pm    Post subject: Reply with quote
How about using two tongue jacks--one for the first lift--and then the second one with a block under it? I have used the jack stand when necessary, but two tongue jacks work faster and easier. I like the heavy duty jack stands without a wheel--just a metal foot. These can be adjusted for height--and may not even need a block. One jack stand on each side of the tongue.
ghone
City/Region: Nanaimo
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
PostPosted: Wed Mar 16, 2011 7:33 pm    Post subject: Reply with quote
Hi Warren, Fulton makes a drop stand without the wheel. that may be good. It is Fulton # 1412000173 or West Marine sku 7869910. it will do a 2500 lb tongue weight. It has no wheel just a plate. I doubt this will be an issue as tandem trailers can't be muscled about anyway with a wheel. This Fulton has a 28" travel with a pin at the bottom end to help lift. I bet this guy will get you going. Cheers George
PostPosted: Wed Mar 16, 2011 7:45 pm    Post subject: Reply with quote
Careful how high you jack the tongue end up, without checking that the other end has the OB's up for clearance. I have used about a 6" wooden block with a single jack stand, but you might have more slope than I did. If you are getting it up that high, might want to use a couple of jack stands to set the trailer frame down onto, back on the frame towards the trailer axels, just incase.......
Doryman
Photos: Lori Ann
PostPosted: Wed Mar 16, 2011 8:24 pm    Post subject: Reply with quote
Bob, good idea but I think I would get some strange looks at the ramp. Might be worth it, though. Thanks!
Hi, George -- that looks like the jack on my Tom Cat! I will have to see if the 15" of travel as shown on the WM catalog page compares to the current jack. I should think it would be. Thanks!
SENSEI
City/Region: Stanwood
Vessel Name: SENSEI
Photos: SENSEI and SERENITY
PostPosted: Wed Mar 16, 2011 8:38 pm    Post subject: Reply with quote
Hey Warren
here is a company that make a hi lift jack
http://www.hi-lift.com/hi-lift-jacks/index.html
they work well but need to block the wheels well so that the trailer wont go side ways. lift with this jack and then put block under the trailer jack and let down on it.
Roger on the "SENSEI"
1993 22 Cruiser (sold 2014)
1983 22 Classic (sold 2017)
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Wed Mar 16, 2011 9:01 pm    Post subject: Reply with quote
I too have to park my boat on a down hill slope. What I do is use a 3 ton floor jack to raise the tongue high enough to slip a box of criss cross 4x4s that I made under the tongue jack. Works fine for me. And with the tongue weight it would take 4 men and a boy to lift it off to try and steal it.
Chuck
Bootleg Hooch
Dreamer
Photos: Dreamer
PostPosted: Wed Mar 16, 2011 9:26 pm    Post subject: Reply with quote
Warren,
I carry a shop type jack for possible tire changes on the truck or trailer.
It works well for raising the trailer tongue to insure drainage from the bilges. I have an aluminum one that I found at Costco.
Dreamer- Sold 25 Feb. 2013
Doryman
Photos: Lori Ann
PostPosted: Wed Mar 16, 2011 10:31 pm    Post subject: Reply with quote
SENSEI wrote:
Hey Warren
Hey, I had one of those on my Jeep! Works well as a come-a-long, too! Great suggestion. I like Spike and the other Roger's floor jack suggestion, too.
PostPosted: Thu Mar 17, 2011 2:11 am    Post subject: Reply with quote
Roger beat me to it. hi lift jack. dont' leave the hard top with out one. Wink
Page 1 of 3
Page generation time: 0.0727s (PHP: 69% - SQL: 31%) - SQL queries: 28 - GZIP disabled - Debug on
