Kicker on a Tomcat
Beflyguy
City/Region: Anderson Island
Vessel Name: Seven Please
Photos: Seven Please
PostPosted: Wed Sep 15, 2010 6:39 pm    Post subject: Kicker on a Tomcat Reply with quote
Has anyone put a kicker on a Tomcat? I have a 6hp Suzuki and I was thinking of using it as a kicker and also a motor for the dinghy but I wonder how it would fit between the twins.
Brian
Seven Please
2009 TC255 2010 175 Suzukis
Anderson Island WA
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Wed Sep 15, 2010 6:54 pm    Post subject: kicker Reply with quote
Why when you have 2 motors if you want a 4-6 hp for a dingy fine but a kicker ??
YOu could run one engine and put a trolling plate to slow down if thats what you have in mind for fishing etc
Beflyguy
PostPosted: Wed Sep 15, 2010 7:02 pm    Post subject: Re: kicker Reply with quote
The boat does troll fine as it is but I am told that many people use a kicker to save wear and hours on their main engines and that made sense to me. Also since I want to have the motor on board for the dinghy, why not mount it an the rear where it is accessible for transferring to the dinghy. There it is out of the way and if it's mounted there, why not use it for trolling or in an emergency? (major electrical failure or the like)
PostPosted: Wed Sep 15, 2010 7:19 pm    Post subject: Reply with quote
I might want to do the same thing. If I recall, I think Bob Austin made a board that slipped into the dive ladder mounts and was able to mount the kicker to that. Depending on how the Tomcat trolls on a single engine, I might want a kicker mounted in the center of the bracket (probably needs to be a long shaft kicker for that). Also, it would be nice if it could be steered via a remote control. I might consider looking at a solution using a generator and a bass boat like electric motor for trolling.
After I posted this - I did some looking around in Bob's photo album - here's a link to the pages showing some pictures of his kicker mounting plate.
PostPosted: Wed Sep 15, 2010 7:47 pm    Post subject: Reply with quote
Get yourself a bucket, preferably galvanized steel (or heavy plastic) and hang it from about a 20'' line attached to either the port or stbd stern cleat. Throw it over when you want to troll. Run the opposite engine at idle, you'll slow down fine. A lot cheaper than a kicker, and the bucket is useful in other ways too.
PostPosted: Wed Sep 15, 2010 7:56 pm    Post subject: Reply with quote
Yes - but I troll A LOT. I think trolling on a kicker that costs $1-2k might be a lot cheaper than trolling on a single 135 when you put 1000-2000 hours on it.
PostPosted: Wed Sep 15, 2010 8:03 pm    Post subject: Reply with quote
Concur... But if there are trolls out there, I don't go... Mr. Green
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Wed Sep 15, 2010 9:31 pm    Post subject: YES Reply with quote
I have a sweet kicker! It's a 150HP Suzuki that will plane off Napoleon even with the other engine off. Cool
Captain Matt
Beflyguy
PostPosted: Wed Sep 15, 2010 11:42 pm    Post subject: Reply with quote
Roger,
Yes, that's the idea. Since the waterline when at rest or at slow speeds is only 10-12" below the top of the motor bracket, a short shaft should be fine. I was picturing something somewhat permanent off to one side so the ladder could still be used.
Something like this.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Thu Sep 16, 2010 11:23 am    Post subject: Reply with quote
Brian,
I am wondering if a 6 hp kicker is enough to effectively troll a Tomcat... Any wind at all, and my guess is you're going to be going down wind with little ability to do much else. We have an 8 hp Honda on our CD 22, and in wind, I find it does not have the poop to easily keep the boat under control. Once the bow falls off, I either have to gun the kicker (a lot) to correct, or change course. Gunning the engine means that most of the time my kokanee rig pulls off down riggers.
Offshore, we almost always end up using the main engine to troll.
Steve
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Thu Sep 16, 2010 12:07 pm    Post subject: Reply with quote
There is a local Tom Cat that has done this. As I recall he has an 8 or a 9.9 on a permanent bracket that raises and lowers the motor into the water. Obviously he loses the factory swim step.
He is not on this site, as far as I know. Next time I see the boat I will try to get a photo.
Doryman
M/V Lori Ann
Anacortes, WA
TWO-DAWGS
City/Region: Kingston
C-Dory Year: 1997
C-Dory Model: 24 Tomcat
Vessel Name: TWO-DAWGS
PostPosted: Fri Sep 17, 2010 6:52 pm    Post subject: Reply with quote
My TomCat is a 1997 with twin Honda 90s. I have trolled with my 90's, switching back and forth to balance the hours, for 13 years. I have so many hours I don't even look anymore. I change the oil regularly, grease the fittings, lube the prop shaft, and do an annual replug, and that's about it. They run perfect, use no oil, and I believe they will run until I cannot stand them anymore and want something cooler just for the heck of it. I think the newer Hondas are even better. I would not worrry about wear and tear very much. These outboards like to be used, and I'm sure even the new larger ones will troll just fine. Happy fishing. TWO-DAWGS.
Steve AKA TWO-DAWGS
1997 TOMCAT 24
Doryman
Photos: Lori Ann
PostPosted: Fri Sep 17, 2010 7:08 pm    Post subject: Reply with quote
When I wanted to be able to troll very slowly with my twin 40s on the 22 or twin 150s on the Tom Cat, someone (I think it was Les at EQ) suggested that I run one motor in forward and the other in reverse. I am not sure he was serious or whether there are drawbacks to doing this, but I thought it was an interesting idea, assuming that gas consumption is not an issue. Thoughts?
Beflyguy
PostPosted: Fri Sep 17, 2010 7:19 pm    Post subject: Reply with quote
I'm sort of looking at this as a place to store the dinghy motor but available to use for trolling as desired. If I position it just right (4-6" higher than in the photo) it may not need to be raised at speed.
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Fri Sep 17, 2010 7:28 pm    Post subject: Reply with quote
Charlie-Here's the Fremont (Seattle) troll with his trolling motor in his left hand.
MartyP
Page generation time: 0.5327s (PHP: 15% - SQL: 85%) - SQL queries: 28 - GZIP disabled - Debug on
