TC255 and Floating debris
Jeanie P
City/Region: Alexandria
Vessel Name: Jeanie P - sold 11/08
PostPosted: Sat Jan 30, 2010 9:13 am    Post subject: TC255 and Floating debris Reply with quote
Even the most vigilant boater has hit floating debris. Most of the time it just rolls to the side of the hull.
With the twin hulls of the TC255, does any river debris get caught between the hulls ?
Allan
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sat Jan 30, 2010 9:51 am    Post subject: Debris Reply with quote
If you are on plane there is an open wind tunnel all the way through. I have gone straight over lobster buoys (not on purpose) without a sound or scratch.
If you are not planed off the aft section cups the water a bit.
Captain Matt
PostPosted: Sat Jan 30, 2010 10:12 am    Post subject: hull speed it would be a challege Reply with quote
Speaking of debris, coming across to Seattle on the ferry yesterday, I have never seen as much debris in the water as we did then. First 2 miles, you could have walked on the flotsam.
Even at hull speed it would have been a challenge, let alone the hair flattening Neutral eyelash curling Rolling Eyes breathtaking speed Mr. Green of the TomCat's.
PostPosted: Sat Jan 30, 2010 4:44 pm    Post subject: Reply with quote
If you are in enough debris to cause a problem with trappen under the wing deck, I would be worried about the lower units of the outboards.
We have run through moderate areas of debris, and had some go between the hulls with no problem, when on a plane. I would not worry much more about that than on a mono hull.
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Sat Jan 30, 2010 4:52 pm    Post subject: Re: hull speed it would be a challege Reply with quote
hardee wrote:
Speaking of debris, coming across to Seattle on the ferry yesterday, I have never seen as much debris in the water as we did then. First 2 miles, you could have walked on the flotsam. Harvey
Harvey, if I'm not mistaken the reason for all of that flotsam is because of the extremely high tides that we had a week ago. (The high tides were catching all the logs that have collected in the past on the shores and river banks). Jetty Island in Everett was covered by water more than I'd ever seen, and the Navy Ships in Everett looked as if they were almost resting on top of the dock. The amount of flotsam coming down the river was sooo bad that the Everett Marina had a small work boat dragging some of the logs that were caught on the "upriver" side of the vessels moored along the river at the marina.
Dave S.
"Sea Shift"
C-Brat #16
Page generation time: 0.0336s (PHP: 63% - SQL: 37%) - SQL queries: 18 - GZIP disabled - Debug on
