Tilt Motor Replacement
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Thu Jan 21, 2010 2:36 pm    Post subject: Tilt Motor Replacement Reply with quote
Anyone have advice on the tilt motor replacement on a Honda BF 75. It looks to me like I'll have to disconnect the tilt tube/steering control, lift the motor, then unbolt one side of the transom flange and slide it over to access the 4 bolts attaching the tilt motor?
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Thu Jan 21, 2010 11:07 pm    Post subject: Reply with quote
Hate it when you have to answer your own post. This is only a 1/2 hour project. All you have to do is disconnenct the main hydraulic cylinder from the motor, then the whole hydraulic system will swing out far enough to access all for tilt motor mounting bolts.
Page generation time: 0.0287s (PHP: 56% - SQL: 44%) - SQL queries: 15 - GZIP disabled - Debug on
