Best Trailer for my 255 C-dory Tomcat
squidslayer
City/Region: El Sobrante
Vessel Name: ShirleyMae
Photos: Shirley Mae
PostPosted: Sat Jan 09, 2010 10:06 pm    Post subject: Best Trailer for my 255 C-dory Tomcat Reply with quote
What is the best type and brand Trailer for my 255 C-dory Tomcat?
I want on that is the easiest to launch and tow ect
any info would be deeply appieciated
DickE
255 Tomcat "ShirleyMae"
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Sat Jan 09, 2010 10:46 pm    Post subject: Reply with quote
Float On . Nothing compares .Can help with this .Pm if interested .
Marc
Wefings Marine Website
Since 1909
Mike...
Photos: Accelerando
PostPosted: Sun Jan 10, 2010 12:03 am    Post subject: Reply with quote
Marc
Agreed!
Check out the picture of mine by clicking on the link to the left.
mike
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sun Jan 10, 2010 7:56 am    Post subject: Trailer Reply with quote
Hi Dick,
With the exception of the rubbing of the knife edge, which appears to be an issue for all stock trailers (Bad Boy modified his for example), I've had a good experience with my Fast Load trailer.
Actually Mark, these are also made in your neck of the woods. http://www.fastloadtrailers.com/
Mine came with Kodiak brakes. I've never had any problems and it has been quite easy to load/unload the Tomcat alone with this trailer. I do like the idea of the tonque ladder (specifically for solo retrieving/launching) and will eventually add one to mine.
Captain Matt
squidslayer
Photos: Shirley Mae
PostPosted: Sun Jan 10, 2010 12:16 pm    Post subject: Trailer profile Reply with quote
Thanks for all the feedback
does anyone know which trailer from the ones mentioned in these posts or any others ..has the lowest to ground boat profile ?
The ones I seen in person like the Pacific Trailer triple axle has the boat towering way off the ground.
Also do you have to go with a triple axle to tow 10000lb+ Tomcat?
Thanks again
Dick
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Sun Jan 10, 2010 12:43 pm    Post subject: Reply with quote
Find Brent & Dixie on Discovery and follow their lead.
A lot of time and work went into a proper set up when the TC255 was about to hit the market. Others got close, but cut some corners to "save a few dollars" or offer a less exspensive trailer. You need to get this correct.
My opinion and I think a double/triple axle set up line is in the area of 6500 pound s, which the TC255 with twin anything and boat water loaded will exceed, so go triple axle. Also, be sure to look at electric over hydraulic brakes and a weight distribution hitch. The 3 items combined with proper trailer build will for sure give you a great trailer set up.
Also, may want to touch base with THATAWAY and other owners for a little "if I did it again" talk.
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
PostPosted: Sun Jan 10, 2010 10:54 pm    Post subject: Reply with quote
Although I agree with Pat on the weight distribution hitch, and if towing in the mountains, the electric over hyraulic, two axels are easier to handle and easily rated for the Tom Cat. My trailer is rated at 13,000 lbs (as I recollect) it is all in the wheels and tires. You do need 16" wheels, and again as I recollect 8 lugs. You can go lower with 15" wheels and a tripple axel trailer.
As far as low--you are not going to get "low" with a Tom Cat trailer. Put slicks on the front 8 feet of the bunks. It will go on and off easily.
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Mon Jan 11, 2010 11:43 am    Post subject: Slick Reply with quote
... Put slicks on the front 8 feet of the bunks. It will go on and off easily.
I did this last season to try to minimize the rubbing of the knife edge. I'll know how well it worked when I can lift the vessel off the trailer.
Page generation time: 0.0478s (PHP: 67% - SQL: 33%) - SQL queries: 21 - GZIP disabled - Debug on
