fiberglass fuel tanks/ethanol
dembr
City/Region: Seattle/Decatur Island
Vessel Name: C-Song
PostPosted: Sun Dec 13, 2009 1:57 pm    Post subject: fiberglass fuel tanks/ethanol Reply with quote
Marine surveyor reports apparent presence of fiberglass fuel tanks on a 2000, 22 foot cruiser and identifies the risk of harm to the fuel lines/motor due to ethanol-blended fuel.
Did C-Dory put fiberglass fuel tanks in their boats? Some reports on ths subject at BOATUS seem to indicate problems in 70s vintage boats but perhaps newer resins don't break down.
Engine mechanic reports engine in good shape.
Comments and responses appreciated.
PostPosted: Sun Dec 13, 2009 3:42 pm    Post subject: Reply with quote
dembr-
This has not been a problem in C-Dorys, as far as I can remember.
Most of the tanks installed have been Mollner brand polyethylene tanks, and the most common problems have been with sedimentation crud breaking loose with the ethanol, and a variety of problems otherwise, but noting out of the ordinary.
If you look in the Library Forum, you can find the Fuel Systems area of discussion that details the problems that have occurred.
Nice having you among the C-Brat crew!
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Sun Dec 13, 2009 9:52 pm    Post subject: Reply with quote
But if you are one of those looking for good deals on those older Grand Banks and some other "larger crusing trawler boats..." older house boats and the like..... ya might just slow down and make sure those older fiberglass tanks and been thru the R&R stage of life.
Have a friend who went thru this and it was a spendy experience at best.
Corn is food, not fuel.
Life is good.
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
PostPosted: Sun Dec 13, 2009 10:21 pm    Post subject: Reply with quote
Here's the photo of Rod's gas tanks in his boat.
I told him in a PM that I thought these looked like the standard later model Mollner polyethylene tanks, but couldn't be sure, as mine are different on my older '87 model Cd-22.
What do you all think?
PostPosted: Sun Dec 13, 2009 11:26 pm    Post subject: Reply with quote
That looks like one of the standard tanks, but it is hard to tell from the pic. If the boat does have fiberglass tanks they were likely installed after the fact. I do not believe C-Dory ever used fiberglass for tanks. When I replaced the tanks in my CD22 with the latest style of molded plastic tanks it cost about $500 for the kit, so if the surveyor is sure they are glass and should be replaced, that will work for a negotiating price.
dembr
Vessel Name: C-Song
PostPosted: Mon Dec 14, 2009 12:01 am    Post subject: Reply with quote
Thanks guys. Really appreciate the info. Looking at buying this boat - but it's too far away for me to go see it.
PostPosted: Mon Dec 14, 2009 12:37 am    Post subject: Reply with quote
You bet! I hope it all works out for you. You took the right first step with the surveyor. Look at the For Sale forum and the Marketplace Reference forum on here to get some price comparison ideas.
Best of luck! We're glad to have you with us.
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Mon Dec 14, 2009 11:49 am    Post subject: Reply with quote
Has it crossed anyone's mind that maybe...just maybe....the survayor doesn't know the difference...between plastic and fiberglass. And that a second openion is in order.
Mike Taylor
330-936-1030
PostPosted: Mon Dec 14, 2009 12:25 pm    Post subject: Reply with quote
Mike-
Yes, we discussed that, but early on while we were still sending PM's back and forth.
Still a possibility, of course!
Interesting thought:
How much experience with boats does a surveyor have that can't tell a fiberglass from a polyethylene fuel tank? Rolling Eyes
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Mon Dec 14, 2009 2:02 pm    Post subject: Reply with quote
Ours is a 2000 CD Cruiser has polyethylene tanks and looks very similar if not identical to this photo. With the tanks being in the shade in this photo its hard to tell for positive.
PostPosted: Mon Dec 14, 2009 3:09 pm    Post subject: Reply with quote
I doubt they are fiberglass but if they are things could be worst. With c-dory you could just pull them out and order new ones. Little bit of money but not much work. On a lot of older boats, big and small, glass tanks are built in and you are not able to pull them out, you have to cut them out or line them with something.
Ethanol is not good for your motor in any way shape or form. Today’s fuel nozzles are just too small to allow the water that attaches to the ethanol to pass. So far I have not had a lot of trouble but I always run the motors dry and I run the tanks dry whenever I can. This does not allow water to build up over time.
Washington only has 5% ethanol right now but the governor is working to get it to 10 to 15%.
If ethanol saves 5% in emissions but gives you 15% less fuel effeminacy (numbers very) are you really saving anything? I hope that someday in the near future politicians stop forcing us to subsidize farms with ethanol sells.
Corn is food not fuel, and not even good food at that. I quit eating corn all but two to three times a year. And I only eat the corn from Rogers’s farm.
PostPosted: Mon Dec 14, 2009 6:50 pm    Post subject: Reply with quote
I would seriously doubt that a 2000 C dory had fiberglass tanks, since all of the others have poly tanks.
As for a Surveyor not knowing the difference. Definately. I have seen a lot of surveyors who were not worth a hoot, and were unqualified. The marine surven industry is poorly regulated and there are a lot of incompetent surveyors...and there are a few good ones.
How did you find the surveyor?
dembr
Vessel Name: C-Song
PostPosted: Mon Dec 14, 2009 8:07 pm    Post subject: Thanks Again! Reply with quote
Appreciate all the responses. Great group.
I am checking with seller to see if they are original tanks. I don't want to badmouth the surveyor but I do have some questions about his conclusion (hence the post!); and that's as much as I'll say here....$400 later.
Again, thanks for taking the time to review and comment.
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Mon Dec 14, 2009 8:55 pm    Post subject: Reply with quote
Had you considered the surveyor may have had some relationship with ethanol?
Many of us in the marine industry do.........
Marc
Wefings Marine Website
Since 1909
PostPosted: Tue Dec 15, 2009 12:39 am    Post subject: Reply with quote
Marc
Beer Beer Beer Cocktail Cocktail Cocktail Beer Beer Beer Cocktail Cocktail Cocktail Beer Beer Beer
Funny! (But also true!)
Joe. Laughing Laughing Laughing
Page generation time: 0.0488s (PHP: 69% - SQL: 31%) - SQL queries: 28 - GZIP disabled - Debug on
