SGIDave
Joined: 16 Jun 2008 Posts: 228 City/Region: St. George Island
Vessel Name: Seadation - SOLD 09/2013
Photos: SeaDation
Posted: Sun Nov 08, 2009 12:55 pm Post subject: Rode: 3 Strand vs 8 Plait Brait |
Hello,
I have a Lewmar V700 windlass set up with a gypsy sized for 1/4" chain and 1/2" line. I currently use a 3 strand nylon rode with 20 feet chain. This is my first boat with a windlass; all I know about them is the "up" switch is supposed to bring the anchor up.
The chain will feed through the windlass fairly well. But the line...well, that's my problem. It frequently 'hangs' up and doesn't feed around the gypsy properly. It doesn't jump off. When someone goes below and 'helps' by pulling the rode gently into the anchor locker, it works fine. I've pulled all the line out and tried untwisting without improvement.
First question: would a "Brait" type line fall into the anchor locker more easily and improve the performance of my windlass? Or, is there something else I should try?
If I buy a new rode, which 1/4" chain is right? HT vs G4 vs ?
Is ACCO chain worth the extra money?
Is all 1/2" brait the same? Is Yale Cordage worth a premium price over other brands?
If anyone has switched from 3 strand to brait, have you noticed a difference in windlass performance?
/david |
Hayesie Daze
Vessel Name: Hayesie Daze
Photos: Hayesie Daze
Posted: Sun Nov 08, 2009 1:23 pm Post subject: |
I know exactly what you are talking about, had the same problem using the Lewmar Premium 8 plait rode. It is not a manufacturing defect, rather the distance between the windlass and the line in your anchor locker is less than the recommended 12" (the line doesn't have enough weight to keep adequate tension). I was going to replace the 8-plait with 3 strand as the local dealer put this in all of their C-Dory's prior to mine. Long and short, I was in the process of replacing and got distracted (kind of like this post) and left it outside for a few days and it worked fine. I think that I did not let the line adequately soak prior to installing, I have not had a problem since. Try soaking the line a bit longer than the recommended 2 hours, more like 24 hours.
As far as the chain goes, check the windlass instructions or Lewmar website, the HT 1/4" and G4 1/4" chains are completely different in lengths and may not feed properly. Hope this helps. |
Posted: Sun Nov 08, 2009 2:35 pm Post subject: Re: Rode: 3 Strand vs 8 Plait Brait |
SGIDave wrote: | Hello,
The 3-strand is fine, it's the drop distance and resultant weight/pull that's the problem. A stiffer, tighter three strand, like New England Premium 3-strand or perhaps the Yale or Sampson (no personal experience with them) can also help.
They're the same! G4 or G40 is Ht or High Test, as far as the marine industry is concerned. Proof Coil and BBB are much cheaper, weaker, and have different length links that won't fit your windlass. There are chains from grade 10 to 100 (theoretically), and even the grade 40 won't let you sand a man under the chain hoisted object. Some marine forms of Grade 70 offered by West Marine will also fit your windlass, but are more expensive, and the increase in strength (7750 vs. 9450 lbs. breaking strength), is not necessary.
YES-you know what you've got, and it won't corrode. Cheap imported chain can be poorly galvanized, and/or made of poor quality steel.
I'd always use premium grade anchor line. The cheap stuff is often soft, loosely woven, and therefore jams easily. One of the prime reasons to have a windlass is to avoid going up on the deck in dangerous conditions. Why have a problematic windlass and or rode that jams all the time ?
Can't answer this one, by Thataway Bob is familiar with the 8-plait, etc.
/david |
Good Luck, windlasses and rodes are a fickle lot!
Joined: 02 Nov 2003 Posts: 20866 City/Region: Pensacola
Posted: Sun Nov 08, 2009 9:27 pm Post subject: |
Although there are several High Test chains (system 7 for example, as well as 4)--G4 1/4" High Test, is the chain called for by the windlass manufactuer.
The 8 plait may work slightly better, but as Joe says, the fall, and weight are critical. You can also go down to 7/16" 3 strand. If your 1/2" 3 strand is very stiff, it may be part of the problem. Consider soaking it in fabric softener, and see if that will make it a bit more supple. _________________ Bob Austin
marvin4239
Joined: 06 Feb 2007 Posts: 1165 City/Region: Jacksonville Florida/Wilmington NC
Vessel Name: C-FLE II
Photos: C-FLE II
Posted: Mon Nov 09, 2009 9:45 am Post subject: |
I had a similiar problem when my rode was new. Following the boards advice (probably Bob's) I soaked my rode in a 5 gallon bucket of diluted fabric softner and it made a pretty significant difference. I now try to do it about every six months. _________________ marvin |
Posted: Mon Nov 09, 2009 1:54 pm Post subject: |
Anchor rope can either be too stiff, or too soft.
One refuses to get a grip with the gypsy or to bend and go down the entry into the locker (or to pack tightly once there), the other simply jams in the gypsy's teeth or somewhere else.
Good quality rope is the best starting place from which to begin, then adjust your rope if you can with fabric softener or salt water soaking and use.
Another approach is to use an all chain rode, or at least a major portion of it, as the chain behaves wonderfully w/o some of the problems of rope. With chain in the sprocket (gypsy), there's no slippage, it always falls and stores tightly in the locker, and it hangs down vertically overboard in light winds, minimizing the boat wandering around.
However, it's very heavy, very expensive, and, while the canter of the moderately tensioned chain has some nice deadening/shock absorbing qualities, a nearly fully tensioned chain rode stops very abruptly when it goes bar-tight, putting quite a shock load on the boat and hardware. Having some rope in the system following the chain adds some elastic cushioning back into the system.
All chain won't work for many, but having 50-100 feet of chain followed by 150 or more feet of three strand nylon has it's advantages and can multiply your anchor's holding power considerably by making sure the pull on the anchor shank is virtually horizontal.
More discussion of the all-chain rode HERE.
Joe. |
Posted: Mon Nov 09, 2009 2:27 pm Post subject: |
Just a comment on letting a boat ride to "all chain" or even chain from the windlass to the anchor, and not using any rope to back it. You need to have some shock absorption. I use lighter nylon rode, than the primary--for example on the C Dory I would use 3/8", with either a chain hook or a rolling hitch around the chain, to a cleat. Generally 20 to 30 feet is enough to avoid shock loading the chain--and it takes any load off the windlass. |
SGIDave
Photos: SeaDation
Posted: Mon Nov 09, 2009 7:23 pm Post subject: |
Thank you all for your thoughtful replies and comments.
I will try soaking my current line in fabric softener. I also like the idea of extending my chain...the boat tends to run better with someone up in the vberth anyway, so more weight (chain) up front might be a good thing.
/david |
Posted: Mon Nov 09, 2009 9:24 pm Post subject: |
We usually have enough chain, that when the load in on the windlass, that we are pulling on the chain. Down here in Fl, it is rare to anchor in more than 10 feet or water, so 30 feet of chain is plenty. In the PNW, i would consider more chain--50 to 100 feet. |
Wefings Dealer
Joined: 29 Nov 2005 Posts: 2086 City/Region: Panhandle
Photos: Cruise Ship #4
Posted: Mon Nov 09, 2009 9:59 pm Post subject: |
Dave when you figure out the best combo , swing by and we will have Allen do one of his patented, aircraft quality, safety wiring jobs !BTW its blowing steady 20 with 32 MPH gusts and light rain . SGI is looking good right now !
Marc _________________ Wefings Marine Website
Since 1909 |
SGIDave
Photos: SeaDation
Posted: Tue Nov 10, 2009 1:25 pm Post subject: |
Wefings wrote: | Dave when you figure out the best combo , swing by and we will have Allen do one of his patented, aircraft quality, safety wiring jobs !BTW its blowing steady 20 with 32 MPH gusts and light rain . SGI is looking good right now !
Marc |
Hello Marc,
I really like Allen. You've got a treasure in him. He was great when I had my fuel tank pickup problem last summer. I'll be needing help rigging a kicker on Seadation... sometime. I hope Allen is available for that job.
Glad to hear IDA was a weather nonevent.
/david |
