100 percent gas and E10
DoryLvr
City/Region: Cape Charles
Vessel Name: Litl' Tug
Photos: Litl' Tug
PostPosted: Thu Oct 29, 2009 1:53 pm    Post subject: 100 percent gas and E10 Reply with quote
At my new home on Virginia's Eastern Shore, I have found a gas station that sells pure gas, no ethanol at all. Does anyone know if it would be a problem to add this gas to a tank with E10 in it? Are there any issues by using pure gas in an engine that has run E10? If I do use pure gas and then go on a trip in the boat and have to use E10 there, is that an issue? I would love to use the pure gas to eliminate the hydroscopic problems associated with E10 but am worried that changing horses midstream is not a good idea.
Tivo Romero, CWO2, USCG (Ret)
DoryLvr
16' Cruiser - Litl' Tug (SOLD)
"The art of seamanship is never allowing yourself to get in a situation where you have to know anything about the subject."
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Thu Oct 29, 2009 2:06 pm    Post subject: Reply with quote
If you can get E0 gas, use it!
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
jhwilson
City/Region: Mitchell County
Vessel Name: Placid C
Photos: Placid C
PostPosted: Thu Oct 29, 2009 3:04 pm    Post subject: Reply with quote
My Honda mechanic says that ethanol is added to pure gasoline to make E-10 after the production of the two components. He believes that many times more than ethanol than the 10% mixture requires may be added since the mix is not handled very precisely. If that is true then your mix which would be less ethanol than 10% would be fine I would think.
I'm certainly no chemist however.
Harper
Pat and Harper, Mitchell County, NC
PostPosted: Thu Oct 29, 2009 3:40 pm    Post subject: Reply with quote
While cruising, we have bought E10 where pure gas wasn't available... never had an issue with going "back and forth" (other than some water in the fuel one time in NY state). I try to avoid the ethanol when possible.
http://captnjim.blogspot.com/
Matt Gurnsey
Dealer
PostPosted: Thu Oct 29, 2009 3:44 pm    Post subject: Reply with quote
By E0 I mean E Zero- zero Ethonal.
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Fri Oct 30, 2009 8:33 am    Post subject: Reply with quote
Just use a stabilizing product all the time and you will be fine . We like PRIG
Marc
Wefings Marine Website
Since 1909
Page generation time: 0.027s (PHP: 61% - SQL: 39%) - SQL queries: 19 - GZIP disabled - Debug on
