Kicker Fuel Supply
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Sat Sep 05, 2009 1:10 pm    Post subject: Kicker Fuel Supply Reply with quote
Bought a 6 hp Tohotsu kicker for our CD-22. Would like to run it off the existing fuel tanks with the main motor. Can I simply tee into the main motor fuel line on the downstream side of the primer bulb, or is there a better way to go? I could not find any previous thread on the subject. Thanks in advance.
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Sat Sep 05, 2009 1:58 pm    Post subject: fuel sep Reply with quote
If you have a water /fuel seperator that will have extra hose fittings for a small outboard. If you dont have a water sep get one
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Sat Sep 05, 2009 2:18 pm    Post subject: Reply with quote
I checked the fuel/water separator and it does have a second outlet for a kicker. Problem solved. Thanks for the tip. Once again, the value of this website...
PostPosted: Sat Sep 05, 2009 5:18 pm    Post subject: Reply with quote
I would put a manual shut off valve on the fuel water separater where you take the kicker fuel supply off. That prevents any possible air induction from the suction of the main engine. Many kicker supplies have a 3 way valve. Taking from the filter is an excellent idea. Personally I would want a separate priming bulb. Another thought is to carry a portable tank, since failure of the primary engine is often fuel related.
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Sat Sep 05, 2009 7:05 pm    Post subject: Reply with quote
Good ideas Idea
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Sun Sep 06, 2009 10:33 am    Post subject: Reply with quote
A better idea is not to tie your kicker to the same fuel supply as your main engine - crappy fuel in one tank COULD disable both engines. If you want your kicker to be a backup for your main engine keep EVERYTHING separate. JMOO.
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Mon Sep 07, 2009 12:58 pm    Post subject: Reply with quote
Toyman- Makes sense. My thinking was to ultilize the convenance of running off the main tanks, but still carry the portable tank with it's own supply hose/primer. If the main system failed, it would be a quick unplug, plug-in the portable tank, re-prime and start.
Chris Bulovsky
City/Region: Washburn
C-Dory Year: 1998
Vessel Name: SCOUT
Photos: SCOUT
PostPosted: Mon Sep 07, 2009 3:48 pm    Post subject: Reply with quote
YES.
Motors are stupid they don't know where the fuel come from.
Mine is like that. However each motor has its own squeeze bulb.
No troubles yet.
Chris
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Tue Sep 08, 2009 2:44 am    Post subject: Reply with quote
This past spring I ran into the same problem when installing a new kicker. Where to get a fuel source. To expedite it I just "T-ed" into my large engine line but kept the bulb in the new engine line also. After using it that way for awhile it dawned on me that any kind of fuel problem would "bugger up" both engines Not good.
As my boating season is over I will park it as is. But in the spring I plan on replumbing it all so I can unplug the kicker and plug it into a separate tank.
My 200 hp Honda fuel supply is fixed at the engine end. It has no quick connnect. I do not like that as it does not allow me to use an emergency hose or separate tank if trouble occurs. That will be solved in the spring also.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Gratitude
City/Region: Costa Mesa
C-Dory Year: 1992
Vessel Name: C Pelican
Photos: C Pelican
PostPosted: Tue Sep 08, 2009 12:32 pm    Post subject: Reply with quote
If you have the room, I suggest both the T from the main tank, and a separate 3 gallon tank. Why? I had to get towed when I got contaminated gas in my main. Neither motor would run.
Gratitude is one of the shortest lived emotions on the face of the earth. Make the time to thank others for their help and kindness.
Page generation time: 0.0258s (PHP: 75% - SQL: 25%) - SQL queries: 23 - GZIP disabled - Debug on
