Wiper for center window on Tomcat?
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Wed Sep 02, 2009 11:13 am    Post subject: Wiper for center window on Tomcat? Reply with quote
I'm looking for suggestions/ideas on adding a wiper to the center window. Has anyone ever added a center wiper?
Captain Matt
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Wed Sep 02, 2009 12:06 pm    Post subject: Reply with quote
Watching this thread with interest as I am interested in doing the same.
Doryman
M/V Lori Ann
Anacortes, WA
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Wed Sep 02, 2009 12:09 pm    Post subject: Reply with quote
http://www.marinco.com/productline/wiper-kits
Marc
Wefings Marine Website
Since 1909
Doryman
Photos: Lori Ann
PostPosted: Wed Sep 02, 2009 12:12 pm    Post subject: Reply with quote
Marc, will that unit pivot up as the window is opened?
PostPosted: Wed Sep 02, 2009 12:15 pm    Post subject: Reply with quote
I remember some posts where it was done.
Just mount it centered above the window.
The arm will fold up when the window is opened, and come back down when closed.
Don't have the time to search it out for you, but I know the thread exists.
Might have been done on a 25 or a TC, but doesn't matter, as long as there's room to mount the motor above the window.
Consider both the inside and outside components of the motor, shaft, and arm to decide if it fits.
Wanted to do it on my 22, but would have had to cut out a section in the front of the electronics shelf to accommodate the motor body, and move some components. Decided I don't use the wipers enough to justify the effort involved.
Grumpy
City/Region: Whidbey Is
Vessel Name: Kingfisher II
Photos: Kingfisher
PostPosted: Wed Sep 02, 2009 12:20 pm    Post subject: Reply with quote
Warren,
Ask Les what he puts on the Rossies. Ours pivots out to horizontal and comes back by itself (mostly). Its a pantographic arm. The opther two have fresh water washers as well Thumbs Up Thumbs Up
Merv
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Wed Sep 02, 2009 12:45 pm    Post subject: Wiper Reply with quote
From Marc's link it looks like we have the "1000/heavy duty" models on the Tomcat. I will verify the next time I'm out and explore more closely what would be involved in terms of mounting.
Part of the process would be in deciding where/how to wire the switch. I would prefer one switch for all wipers. Having two side by side (as offered stock) is no big deal but having a third would require some thought. In my case I usually need just a burst of wiper (from rough water spray) and seldom need constant wipers.
Thanks for the replies!
Dreamer
Photos: Dreamer
PostPosted: Wed Sep 02, 2009 1:16 pm    Post subject: Reply with quote
Matt, Warren,
Funny you should mention this project. We always come home with a list of things to do to the boat over the winter. Right up top is a center window wiper and fresh water washers for all front windows. It will be interesting to see who drills the first hole! Whoever it is, take lots of photos.
Dreamer- Sold 25 Feb. 2013
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Wed Sep 02, 2009 1:40 pm    Post subject: Reply with quote
We had the factory install a center wiper on the last Tomcat we sold. Same motor and arm as the side windows, and works great.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Wed Sep 02, 2009 2:32 pm    Post subject: Wiper Reply with quote
Dreamer wrote:
Matt, Warren,
The fresh water rinse would also be nice...let us know what you find for options.
Wefings
Dealer
PostPosted: Wed Sep 02, 2009 2:40 pm    Post subject: Reply with quote
AFI sells that too..........
WET ARMS
Marc
PostPosted: Wed Sep 02, 2009 5:22 pm    Post subject: Reply with quote
Don't forget to use "Rain-x" on the windshields regularly. Salt water beads up just like fresh. The washer would be nice, if you just get a little spray on the window and want to get the salt off. So far we have avoided putting a 3rd wiper or the washer on, and just use Rain-X.
Dreamer
Photos: Dreamer
PostPosted: Thu Sep 03, 2009 2:03 am    Post subject: Reply with quote
Bob,
Right you are about Rain-X. However, we found that in a light spray or foggy drizzle, the water doesn't bead up as well as in a downpour or at high speed. Last month, we found many times when we wished we could have just sprayed down the front windows. We thought of you when visiting Sutherland Bay in August.
Levitation
City/Region: Hemlock
C-Dory Model: R-25 Tug
Vessel Name: CHARLOTTE ANN
PostPosted: Thu Sep 03, 2009 7:49 am    Post subject: Reply with quote
Be aware that many of the wiper systems for boats are not designed to have the wiper arm lifted away from the glass like an automobile wiper - i.e. flipped out... Doing so stretches the hold down spring and the wiper loses much of its ability to bear down on the glass leaving the wiping streaky... There was a lengthy article in Passagemaker on this issue...
Now, if the wiper(s) discussed here are designed to have the arm flipped out, then you are good to go...
denny-o
Page generation time: 0.0485s (PHP: 65% - SQL: 35%) - SQL queries: 27 - GZIP disabled - Debug on
