Crab pots
PostPosted: Fri Aug 14, 2009 8:45 pm    Post subject: Crab pots Reply with quote
I took my 26 yr old son out for a day of father/son bonding. He was up from Vancouver and had never been on the boat. We headed out @ 0900 from Everett and dumped two pots in the small bay just to the east of Camano Island State Park @ about 1100. We decided to make the run to Coupeville to eat some lunch and let them soak.
Returned about 1430 and picked them up. Exactly the same bait in both pots, although the pots are different makes; the significance of which I will explain later.
Pot one=one male, too small to keep. Oh, well. Pot two=eleven crab (boy was my son EXCITED upon pulling it up!!!!)...but, only one keeper. Rolling Eyes Either JUST too small or females. Back they went. Based on the time, we decided to move, re-bait, dunk again and soak for one hour.
Pull at about 1530. Pot one=one undersized male (again Mad ). Pot two=eight crab; all BARELY undersized or female. Angry Confused Hmmmmmmm...pot one is less efficient at catching them. Why? Confused A quick look at each pot and my question was answered.
Pot one is a Willapa brand, I bought at Fisheries Supply for about $80. The design is, IMO, lousy. The wire mesh used to make the trap is bent up at the bottom of the gates, thus creating about a ~1" barrier to a crab trying to enter. It would have to get OVER the wire mesh to get in.
Pot two is a McKay brand I bought from a boat dealer in Everett for about $100. The entrance to the gates is flat to the bottom of the pot & thus the ocean floor. It also seems like it's a much better quality made trap. I posted pics in my album.
I'm going to cut the bottom wire off of pot one, remove the gates and lower and re-bend the gates so it's a smoother transition/entrance. My thinking is crabs walk on the bottom and creating a barrier, even a small one, is just making it harder for crabs to enter the trap. It seemed to be "proven" by my experiences yesterday, albeit it a very unscientific study.
I know Fred swears by the inexspensive folding traps (~$40) and I've seen what he & Robbi caught at Bellingham so now I'm regretting pot one (Willapa) I bought from Fisheries.
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Fri Aug 14, 2009 9:21 pm    Post subject: Reply with quote
Mark,
Yes, that is a poor design alright. I have always used the cheap Danielson ones. I almost always use fresh chicken pieces and/or salmon carcass. I also use those mesh bait bags and hang them from the top of the pot with a big stainless clip. Best place and cheapest is LFS fishing supply in Bellingham. The crabs can eat through the mesh bag and let more scent trail out and thus more crabs come in.
Looks like you did OK, we always soak for 1 hour, check and then adjust pot to a different area and depth close by if not catching.
Good luck, the modification should work fine.
Patrick
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
mrw90
City/Region: Bellingham
PostPosted: Fri Aug 14, 2009 10:21 pm    Post subject: Reply with quote
I would say that the measure of a good pot isn't really it's ability to catch undersized males and females. The basic design of the Willapa pot is pretty standard and will catch crab. Most crab pots that I've seen require the crab to climb an incline to get into the pot. Crab are pretty good at this, and if the large males are in the area, they'll get into this kind of pot. My suggestion would be to focus more on where to put the pots. The fact that there was no legal crab in either pot says that the location that you were fishing in is either not good, or more likely, has been fished out already.
nordicstallion
City/Region: Crescent City
C-Dory Model: 19 Angler
Vessel Name: Rylee Rose
Photos: Rylee Rose
PostPosted: Sat Aug 15, 2009 11:50 am    Post subject: Reply with quote
crab tunnels are enclined to keep them off the bottom and triggers from contacting the sand or soft bottom.small crab sqweeze by but larger ones cant pass.
rjmcnabb
City/Region: Pender Island (Southern Gulf Islands)
Vessel Name: Luna
PostPosted: Sat Aug 15, 2009 1:00 pm    Post subject: Reply with quote
Hi Brats,
A question about crab pot design, but not related to catching abilities until you see them drop through the bottom as you hoist the pot. Several weeks ago, my brother gave me a pot that looked to be ss rod, with a ss wire "knitted" cover. I had the pot continuously wet for a week or so off my marina dock, and it produced fairly well using canned catfood. Two days ago, I pulled it in and could see crabs fall out as it neared the surface. Half of the bottom was gone, with various pieces of wire hanging on. The pieces I found, and some of the remaining net all showed corrosion where the wires crossed over and around. The sites of breakage were quite sharp, I suppose because they were thinned by galvanic corrosion before they broke. Wire mesh on sides and top seem OK, but they could be a different kind of wire; they were not part of, or connected directly to, the bottom mesh. Also, one of four connectors welded between the upper and lower rings is severely etched and covered with heavy rust. Anyone ever experience something like this? I will try to replace the bottom with plastic or cordage mesh, and maybe bolt on a zinc. Any light on my mystery Idea would be appreciated, because I've hit the end of my ideas on electrochemistry.
Arrow Along that vein of thought, should I have zincs on my trim tabs?
Rod
Rod & Jane; Victoria 18 sloop (Vickie) - gone; Islander 26 Bahama sloop (Callisto) - gone; WW Potter 19 sloop (Spring) - gone; Com-Pac 16 sloop (Bummer II) - gone; Nimble 24 yawl (Chatelaine) - gone; Nimble Vagabond cruiser (Loligo) - gone; C-Dory 22 Cruiser (NoddyBleu) - gone; Com-Pac 19 sloop ('Winkle) - gone; San Juan 24 sloop (Loligo^2) - gone; C-Dory 16 cruiser (Luna); Catalina Capri 18 sloop (Later)
mrw90
PostPosted: Sat Aug 15, 2009 3:06 pm    Post subject: Reply with quote
A couple of thoughts. First, the pots I use are stainless and sound pretty much like the one you were using. Mine do have a large piece of zinc that screws onto a threaded post that is part of the frame. I think that if you can repair your pot, you will want to add some sacrificial zinc to the system. Second, since you mention that you were crabbing in or around a marina, I would guess that there is a fair amount of stray current in the water from one of the surrounding boats. If you keep your boat in the water, watch anything metal below the waterline and check your zincs frequently.
rjmcnabb
Vessel Name: Luna
PostPosted: Sat Aug 15, 2009 8:20 pm    Post subject: Reply with quote
Thanks mrw90,
Now I know what the threaded boss on a bottom cross-bar is for. The trap is nicely made, but I concluded that thing was just part of a recycled piece of metal used to make the frame. The really rusty spreader (turns out there are six, not four) is third farthest (or third closest, I guess) from the threaded boss. Question Any significance to that??
Thieves' Bay is a very nice marina (private, and I think you could refer to it as rural,) but the slips have neither power nor water service; I suppose that electrolysis is not great, although galvanic corrosion still exists, as ever.
Rod
bmacpiper
Vessel Name: Big Blue
PostPosted: Mon Aug 24, 2009 1:51 pm    Post subject: Re: Crab pots Reply with quote
Hey localboy,
I've fished both the inexpensive folding ones, and both styles of McKay pots. If you look at McKay's website, you'll see that they have a "fast fisher" and a "no escape" version. The fast fisher is the one you described--the gates swing all the way to the bottom. The no escape has a ramp that they walk up, then a gate, and it's nearly impossible for them to get back out. The cheap folding pots are the same design as the fast fisher.
I've talked to the guys and gals at McKay several times about the pots, and they will basically tell you that the fast fisher is for when you're soaking for an hour or two, since the crab can get in faster/easier, and the no escapes are for longer soaks, i.e. overnight. My own experience has been that when the fishing is hot, it doesn't matter which style--the crabs will find their way in.
I will say, however, that I have numerous experiences of crabs getting out of the fast fisher pots. I always leave crabs in the pots to attract other crabs with their noise, and I have had several times where a pot has exchanged all the crab over the course of a 4-6 hour soak (based on gender, and rock vs. dungy). I am totally certain that crabs can move in and out of the fast fisher style pots fairly easily, so if you're using them, you'll want to check often.
We use four no-escape pots these days, both for the security of the crabs, and because they have a second door for wrangling the crabs that makes things a lot easier. The folks over at McKay really stand behind their stuff as well.
Have fun!
bmc
bmc
"Do it today, you may not pass this way again!"
2005 16 Cruiser, "Natural Blue", sold 2009
2004 19 Angler, "Crush", sold 2012
2007 22 Cruiser, "Big Blue", purchased 2012
Fishhawk
City/Region: Bon Secour
State or Province: AL
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon Aug 24, 2009 2:37 pm    Post subject: Reply with quote
Can any of ya'll out there offer any sage advice about blue crabbing on the gulf coast?
Types of traps and where to buy them, best bait, etc;
I would also like to know if blue crab traps can be fashioned from wood or plastic and if so are there plans/drawings for those traps?
This is an informative thread for me. thanks all.
Capt Dan
"We intend to alleviate global warming's effects of raising ocean water levels by removing enough fish to counteract it all! "
PostPosted: Mon Aug 24, 2009 4:00 pm    Post subject: Re: Crab pots Reply with quote
I wanted this version, but at the time they were sold out. I then, foolishly, bought the lousy one on the spur of the moment when I was down @ Fisheries.
Makes sense.
I'm going again on Saturday and plan on checking often, moving if necessary etc.
We use four no-escape pots these days, both for the security of the crabs, and because they have a second door for wrangling the crabs that makes things a lot easier. Have fun!
bmc
Gonna probably buy one more McKay WITH ramps (The Admiral will love THAT). Assuming I don't lose them or more realistically, they get stolen, I should have them a long time due to their quality.
Got one more stupid question; I was told that once a large starfish moves into the trap you won't catch any more crab. Is this true or an old crabbing myth?
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Wed Aug 26, 2009 1:24 am    Post subject: Re: Crab pots Reply with quote
Did you add weights to these McKay pots? If so, what and where?
Doryman
M/V Lori Ann
Anacortes, WA
PostPosted: Wed Aug 26, 2009 11:08 am    Post subject: Reply with quote
The crappy crab pot I have is weighted with ~10" pieces of ~5/8" rebar zip-tied to the bottom and coated against rust. Simple.
Doryman
Photos: Lori Ann
PostPosted: Wed Aug 26, 2009 11:17 am    Post subject: Reply with quote
What did you dip the rebar into to coat it?
PostPosted: Wed Aug 26, 2009 6:12 pm    Post subject: Reply with quote
Warren, the re-bar was installed by the manufacturer of the black trap I bought from Fisheries. It's sold as a "weighted trap". It appears to be some sort of black paint, not a vinyl coating; but it is just regular old steel re-bar.
Page generation time: 0.0471s (PHP: 68% - SQL: 32%) - SQL queries: 27 - GZIP disabled - Debug on
