Radar units.
redcrest
City/Region: Norther MN
State or Province: MN
PostPosted: Thu Aug 06, 2009 12:25 pm    Post subject: Radar units. Reply with quote
I can not find much discussion on the different Radar units C-Dory owners are using. Can someone direct me to the area or form if it has already been discussed.
PostPosted: Thu Aug 06, 2009 12:59 pm    Post subject: Reply with quote
Did you look in the ELECTRONICS FORUM?
Three hundred and sixty two different threads.
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Thu Aug 06, 2009 1:32 pm    Post subject: Radar units. Reply with quote
Redcrest,
Most use either Raymarine with a multifunction display or Furuno's 1715 standalone unit linked to a chartplotter with a nema 0183 protocol as many want an to see an radar overlay on a chartplotter. Some don't like all their eggs in one basket. Others want redunancy in case one unit breaks. I myself an waiting to see how the new broadband radar plays out. Lowrance/Northstar Simerad all offer it. It is instant on uses a lot less power and does not emit as much potentially unhealthy emmisions from the radar dome. Others use JRC which does a good job and is a little cheaper to purchase. Garmin is thought to be the easiest to use chart plotter and they offer multifunction units in a variety of sizes and configurations which offer radar as an option. I have a 4208 with the sonar and am going to add a Garmin fuel management option. Rumor had it the Raymarine was in some sort of finiancial trouble but I can't confirm that. Furuno is the undisputed best and the most expensive. Garmins radar was generally not well thought of but the new HD versions are supposed to be better. I myself want to wait and see what shakes out. My current needs don't call for it, but trips to the Northwest in the future certainly will. Some thought might be given to purchasing fom someone that can help or guide you with the install not just the drop dead best price. I hope this helps. good luck.
D.D.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Thu Aug 06, 2009 1:57 pm    Post subject: Radar Reply with quote
I noticed this is your first post, welcome to C-Brat's. What model C-Dory do you have?
The available interior space may influence the unit you choose. I recall anecdotally that we are using pretty much everything between us including Furuno, Raymarine, Garmin, Northstar, Lowrance, etc.
Captain Matt
redcrest
PostPosted: Thu Aug 06, 2009 2:24 pm    Post subject: Radar Reply with quote
I am in the process of putting together a 22 foot crusier, I will be retiring in early May of 2010 and plan on having purchased one by then.
Sarge
City/Region: Edmonds
Vessel Name: Sea Badger
Photos: Gigi
PostPosted: Thu Aug 06, 2009 4:19 pm    Post subject: Reply with quote
My advice is simple...get radar!
I happen to have a Garmin 4208 with a Garmin radar and I'm very happy with it. My previous boat had a Raymarine radar and I was quite happy with it.
Fog can sneak up on you and having radar is very comforting. It's not foolproof and you need to use it enough to have confidence in it, but I can't see boating without it anymore.
Best of luck in figuring out how you want to set up your boat. Personally, I think planning is half the fun!
-Sarge
2001 2150 Bayliner, sold
2007 CD25, sold
2007 Harbercraft Kingfisher 2850, sold
2011 Stabicraft 2250SC, sold
2011 Eastern 18cc
Blog: http://theseabadger.wordpress.com
View user's profile Send private message Visit poster's website AIM Address
jlastofka
City/Region: Vista
Vessel Name: Bossa Nova
Photos: Bossa Nova
PostPosted: Thu Aug 06, 2009 4:26 pm    Post subject: Reply with quote
I have the new Garmin HD radar with my 15" Garmin chartlotter and I like the combination a lot. It also includes a fishfinder sonar that's nice. I have paper charts and a handheld GPS for backup so I don't think worrying about "all the eggs in one basket" is a problem. Having all the major stuff in one box saves a lot of clutter in a small boat.
Having handheld radio and GPS backups powered separate from the boat is good practice I think.
This is my first radar experience so I can't compare, but it's easy to use and I've run it in good weather to learn what stuff looks like. I've also used it in fog a couple times and it sure is nice to have an idea of what's out there instead of running blind.
PostPosted: Thu Aug 06, 2009 4:47 pm    Post subject: Reply with quote
I would wait until the boat is delivered until you put in Radar. There are rapid changes in electronics--especially Radar. Broad band has some real advantages, as Dave Deem noted. So Far Navico is the only one with it on the market. From what I have seen it is very impressive at short ranges (up to 3 miles) where you run radar 90% of the time.
Where you boat and how you boat will determine if you use Radar. I have used Radar for over 30 years, and perfer a separate display. I have the Furuno 1715, with a 7" monochrome dispay. Yes, all eggs in one basket is not a good idea. I have two chart plotters, two separate Depth finders (one a fish finder) and one radar. (I also have paper charts and a hand held GPS).
Read Panbo.com--this is Bell Ellison's (was electronic's editor for Motor Boating). Also read the electronics section of "the Hull Truth"--it can get a bit confusing, but there are some very good people there.
I suspect that other manufactuers will have broad band radar by next spring, and that AIS will be much more "Plug and Play"--and perhaps a little cheaper. AIS is another tool, if you are running in fog or at night.
Westfield 11
City/Region: Woodland Hills
PostPosted: Thu Aug 06, 2009 7:05 pm    Post subject: Reply with quote
You might want to look at the new broadband type units. They claim higher resolution, lower power draw and much lower radiation hazard.
Not a C-Dory owner but a lover of the forum and the spirit of adventure found here. This is the best small boat cruising resource I have found to date. The travelogues are very inspirational and a great reminder of why we go down to the sea in ships (or small boats).
seabeagle
City/Region: Farmington Hills
Vessel Name: Sea Beagle II - Sold 4-19-12
Photos: Sea Beagle II
PostPosted: Thu Aug 06, 2009 9:20 pm    Post subject: Reply with quote
I'm using a Garmin 5208 system. Very happy here. Got a few pics in my album of the setup.
I am the 125% I work so the 99% don't have to.
http://www.youtube.com/SeaBeagleII
Page generation time: 0.0325s (PHP: 64% - SQL: 36%) - SQL queries: 23 - GZIP disabled - Debug on
