Sneaks
Joined: 06 Jun 2004 Posts: 2020 City/Region: San Diego (Encinitas)
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
Posted: Mon Aug 03, 2009 11:37 am Post subject: Oil analysis applies to our diesel tow vehicles!!! |
Byrdman wrote: | SNEAKS: I am interested in your oil sample remark... Seems ol Uncle Sam has used oil samples on stuff for years....yet, in our civilian rides, we just dump gallons of more than likely fine oil with each oil change. Even some neat after market kits for more oil filters and oil sampling. I need to know more on this as Ol Blue is over the 100,000 mile mark now. Just seems that changing filters, adding oil to replace filters oil, and an oil sample would get a bit more use out of the oil... Your thoughts?
Byrdman |
Pat, I first was exposed to oil analysis on submarines. We changed oil in our four (4) big diesel engines only when the analysis showed it was time to change. It was also invaluable as an early indicator of engine trouble because one could determine if bearings were failing long before getting stuck at sea with a seized engine.
When I bought my Duramax (used) I was concerned as to the true condition of the engine, so after a long RV trip I contacted Blackstone Labs got a sample kit and sent it in for analysis. Much to my delight, the analysis showed that compared to other Duramax engines, mine had a better than normal rating and I could extend my oil replacement schedule.
The whole process (at that time) cost me less than $20. A year later, my neighbor (who drove a SOB diesel truck) was intrigued and I gave him a sample bottle to send in. He found his turbo was generating way too much metal wear and it was ending up in his oil. It took several trips and a long battle with Ford, but they eventually replaced his turbo. He wouldn't have had a leg to stand on if his turbo failed after the warranty ended...! Interestingly enough, Ford sealed his oil fill, wired his oil drain and in general made sure any work done on that engine while they were going through a "second opinion" exercise, was done only by Ford and only in their specified facility.
If I owned a diesel powered boat you can bet your biggest asset I'd do oil analysis regularly. Easily done, a wealth of knowledge, and cheap.
Don |
Posted: Mon Aug 03, 2009 11:48 am Post subject: |
We did (and still do, I think) the same thing on big gas turbines and diesels on surface ships! An invaluable tool!
K4KBA |
Bill Uffelman
Joined: 06 Nov 2006 Posts: 334 City/Region: Las Vegas
State or Province: NV
Posted: Mon Aug 03, 2009 2:19 pm Post subject: |
In addition to oil samples, we had magnetic plugs on the gear boxes as a quick tell tale of looming trouble.
Bill Uffelman
Looking out on Areys Pond
South Orleans MA for another day |
Byrdman
Joined: 06 Nov 2003 Posts: 3320 City/Region: Cumberland River, Clarksville,
Photos: FreeByrd and C-Byrd
Posted: Mon Aug 03, 2009 2:29 pm Post subject: |
Thanks Sneaks!
Going to do some looking about a bit on this topic. Very interesting.
Byrdman _________________ Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
Never Deny Yourself The Pleasure of Helping Others. |
Doug & Fran
State or Province: AB
Vessel Name: Squirt Two
Posted: Tue Aug 04, 2009 11:30 pm Post subject: magnets |
I've been putting small, cheap, rare earth magnets on the oil filters on our cars/trucks. Dunno if it makes any difference, but the magnets are cheap and should collect any ferrous type material in the filter.
Doug _________________ Doug & Fran
Squirt Two |
denny-o
Posted: Wed Aug 05, 2009 8:23 am Post subject: |
Oil analysis is a topic I have followed for decades for my business vehicles and my airplane (it has not been an issue for my sailboats)... Roughly every 5 years I get concerned and go over the latest information... And each time I decide not to do it...
Now what is economical and prudent testing for a multi million dollar turbine in a warship does not apply to me...
The issues are:
1. Does oil analysis save me more money than it costs?
2. If an engine is showing elevated this or that, am I going to spend $6K/$18K on an overhaul (truck/airplane) just in case?
My experience and my conversations with people who use oil analysis is that it does not predict sudden breakage - a timing chain snapping, etc. - only elevated wear rate of bearings, cams, etc... My personal experience has been that an experienced operator will sense a problem with an engine long before it results in stoppage - change in temperatures, vibration, noise, etc...
What I do to supplement being alert is to cut open the oil filter at each oil change and inspect it for metal shavings... You will become an expert by the time you do the second filter... The other thing I do is to use a good oil, but not the most expensive razzle dazzle stuff advertised, and to change the oil at 2/3 of the recommended interval...
It is not the oil base that protects the engine against accelerated wear, it is the additive package... The high dollar oil has essentially the same additive package as the brand name stuff, and those additives wear out at the same rate in either oil... By changing my oil more frequently I have fresh additives over a higher percentage of the running hours than I do with the more expensive, extended change oils... In the end it costs me about the same but I 'feel' that looking at the filter more frequently is to my advantage along with the fresher additive package... _________________ Denny
K8DO |
BrentB
State or Province: IN
Photos: BrentB
Posted: Wed Aug 05, 2009 5:06 pm Post subject: |
I am not familar with technical details. What analytes are tested and what are the interpretations? _________________ Brent Barrett |
Joined: 30 Sep 2006 Posts: 4659 City/Region: Lake Stevens via Honolulu
Posted: Wed Aug 05, 2009 5:17 pm Post subject: |
Brent wrote: | I am not familar with technical details. What analytes are tested and what are the interpretations? |
Quote: | Blackstone's standard analysis will tell you what you need to know about the condition of your engine and how it's wearing. The standard analysis costs $22.50 and includes the following:
Spectral Exam: Establishes the levels of wear metals, silicon, and additives present in the oil. Also checks for coolant.
Viscosity: Determines the grade of oil.
Insolubles: Quantifies the percentage of solids present in the oil.
Flash Point: Determines the flash point of the oil. We use the flash point to determine whether any contamination is present in the oil (determined when the flash is lower than the "should be" range). |
I ordered a kit, but not for the outboard or my F-250. I'm gonna test the hi-performance engine in my air cooled VW to see how it's doing. _________________ "We can go over there...behind the 'little one'....."
BrentB
Photos: BrentB
Posted: Wed Aug 05, 2009 7:17 pm Post subject: |
How often should it tested? |
Sneaks
Vessel Name: C-Brat
Posted: Wed Aug 05, 2009 8:36 pm Post subject: |
Brent wrote: | How often should it tested? |
Personally, I ran an analysis just after I bought my Duramax (used) and again about 30,000 miles later. Up to you. It really should be tested once before the warranty expires if ya got a new truck, just to check for elevated metal levels and avoid surprises down the road. Depends entirely on your comfort level. Little use is harder on a diesel, but overall I think most folks waste more money doing 3,000 mile oil changes than going to the manufacturer's recommended mileage interval and getting an analysis every other change. Additives last a looooong time.
Denny has some good points but if you're not into changing oil yourself or (yuck) cutting oil filters and dealing with hazardous waste bullcrap, an analysis can be an easy way out.
Don |
BrentB
Photos: BrentB
Posted: Wed Aug 05, 2009 8:40 pm Post subject: |
thank you
Based your tests, did it help? |
Sneaks
Vessel Name: C-Brat
Posted: Wed Aug 05, 2009 9:10 pm Post subject: |
Sure, Brent. I bought on line from an owner living in Thailand and his truck was stored in Los Angeles. Definite peace of mind after reading the first analysis. The second showed no change from the first one so I stopped doing 'em.
Don
Oh, the owner turned out to be a PGA golfer playing in the Asian PGA tour. I don't play cow pasture pool so his name meant nothing to me. Johnson or Johnston. All I remember was that he was 6'5" and a nice guy. He flew in to LA, we swapped cash for pink at my bank and I gave them a ride to the airport. |
bshillam
Joined: 21 Aug 2007 Posts: 782 City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
Posted: Thu Aug 06, 2009 10:50 am Post subject: Good idea |
Thanks for the words of advice. I'm going to order a kit. I recently purchased a late model M2 Freightliner that is going to be out of warranty as of September. Good piece of mind on an expense piece of equipment! Again, thanks for the advice. I knew about these tests but had forgotten about them. |
Will-C
Vessel Name: Will-C
Photos: Will-C
Posted: Thu Aug 06, 2009 11:03 am Post subject: Oil analysis applies to our diesel tow vehicles!!! |
Brent,
Large truck fleet managers use oil analysis to extend oil change intervals by testing individual motors. Typically diesel oil changes are recommended at 10k intervals. By testing the oil they might find a particular engine's oil still tests well at 16k they stretch oil change intervals by five or six thousand miles on an engine that hold 10 gallons of oil it's easy to see the savings if you consider fleets with ten or one hundred trucks. As the engine gets older the testing showing high contamination of fuel or bearing material lets them plan on dumping the piece or the budgeting process. Not to mention the work load for the shop and the unit to come out of service. Our shop truck has a turbo charged Mercedes engine; we change it a 5k because it's cheap we do it ourselves and we want the engine to last forever. The other benefits it's quick and we don't have wonder about who did what at Wally World. Other folks living condos or right on the side walk simply don't have a place to do it. Everyone has there way of doing things.
D.D. |
BrentB
Photos: BrentB
Posted: Thu Aug 06, 2009 11:38 am Post subject: |
Good story Sneaks
Thanks again to you and Dave
This is well thought and useful infomation.
What is the estimated testing turnaround time?
I am always learning somthing from the C-Brats |
