Handy New Gadget
Dreamer
Photos: Dreamer
PostPosted: Mon Jul 20, 2009 3:01 pm    Post subject: Handy New Gadget Reply with quote
I can't resist browsing around in an unfamiliar boat supply store. Even though 99% of the items are the same ones that you see in all the other places, I usually find at least one item that is new to me.
As I browsed through Westside Marine outside of Port Townsend, WA a few weeks ago, I spotted this.
I have a couple of pumps for filling the engine gear case with the smelly messy lube. The threads never match the proprietary Honda threads. Here's an adapter that adapts Honda to the rest of the marine world. Made by Sierra a division of Teleflex. Two part numbers on the packaging;
18-9794 and N3500.
Dreamer- Sold 25 Feb. 2013
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Mon Jul 20, 2009 6:12 pm    Post subject: Reply with quote
I ended up tapering the plastic tip so it fits in the drain hole, as long as pressure is applied not leaks.
The mess comes when attempting to thread in the drain plug while lube oil gushes all over the place. Evil or Very Mad Even with the top plug in place there always seams to be a gush of oil when attempt to thread in the drain plug.
I bought the biggest screw driver I could find and it still seems inadequate for removing the drain plug, thinking of sacrificing it to the grinding wheel for a custom fit. Smile
Thanks for the tip,,,,,,
Boatless for now but looking
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Mon Jul 20, 2009 6:20 pm    Post subject: Reply with quote
That's what I finally did after years of trying find one that fits. I hate changing gear oil because of the mess it makes. Even though I found Honda threaded ends for the lube tube, getting the plug started without making a mess is impossible for me. There must be a better way.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
Dreamer
Photos: Dreamer
PostPosted: Mon Jul 20, 2009 7:07 pm    Post subject: Reply with quote
Jay,
This was addressed in another thread recently. An Impact Screwdriver is the answer. It is tapped with a hammer and applies the twist along with being forced into the slot. I got mine years ago to take those pesky Honda motorcycles apart.
Try looking in a motorcycle shop for one.
breausaw
Photos: Triple J
PostPosted: Mon Jul 20, 2009 7:28 pm    Post subject: Reply with quote
Dreamer wrote:
Jay,
Roger,
I have one and had to use it last time, just concerned that continual use may bugger up the plug; maybe I’m wrong. Would be more comfortable using the right size slotted screwdriver; vise grip attached.
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Mon Jul 20, 2009 9:47 pm    Post subject: Reply with quote
Jay,
The answer last time was a drag link socket from Sears.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
breausaw
Photos: Triple J
PostPosted: Tue Jul 21, 2009 1:05 am    Post subject: Reply with quote
tpbrady wrote:
Jay,
Thanks Tom, that's the ticket! Seen them thingamajigs but never knew what they’re used for, beats the heck out of a vise grip monster screwdriver for sure.
Thumbs Up
PostPosted: Tue Jul 21, 2009 1:22 am    Post subject: Reply with quote
Drag Link Socket (in case you've seen one, or haven't, but are unfamiliar with the term):
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Tue Jul 21, 2009 2:58 am    Post subject: lower unti refill time soon Reply with quote
For us northern C-Dory guys in a couple of months it will be lower unit drain/refill time.
Get all of the correct "dooby-dobbers" that you need now to properly complete the job before it is too late. Otherwise you will be using a screwdriver with a vise grip attached and a threaded hose end for a Johnson stuffed into a Honda hole etc...etc.
I hate having to pickle my boat for winter storage.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Nunya
Photos: Nunya
PostPosted: Tue Jul 21, 2009 10:07 am    Post subject: Reply with quote
I've always wondered why the manufactures didn't put an allen headed screws in there?
PostPosted: Tue Jul 21, 2009 6:21 pm    Post subject: Reply with quote
I've found that the easiest solution (for me at least) is to let Les's group do all my oil and lube changes. I never make a mess this way. Wink
Page generation time: 0.0654s (PHP: 55% - SQL: 45%) - SQL queries: 24 - GZIP disabled - Debug on
