Tongue weight of a CD 16
Montana Kev
City/Region: Bozeman/Yellowstone
State or Province: MT
Vessel Name: Grace
Photos: Grace
PostPosted: Mon Oct 06, 2008 9:09 pm    Post subject: Tongue weight of a CD 16 Reply with quote
Does anyone know the approximant trailer tongue weight of a CD 16 cruiser? I have looked thru the forums but not located anything. I am trying to decide if my Toyota Highlander is suitable for a 800 mile drive to bring back a CD 16 I may buy. My other option is my F150 and a higher gas bill.
Kevin
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Mon Oct 06, 2008 9:35 pm    Post subject: Reply with quote
I don't know the tongue weight. If the Highlander has the 3.4 L V-6 base engine you will have plenty of power to pull the trailered 16 footer essentially anywhere.
MartyP
Capn Jack
City/Region: La Conner
C-Dory Year: 1988
Vessel Name: Pocket Yacht
Photos: Pocket Yacht
PostPosted: Tue Oct 07, 2008 11:43 am    Post subject: Tongue Weight Reply with quote
Tongue weight is determined by how the boat is set-up on the trailer and can be adjusted by moving the C/G of the boat back and forth over the axel of the trailer (S/B at least 100 lbs). My new 5 cyln. Colorado does great pulling the Pocket Yacht.
CoolSmile Jack
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Tue Oct 07, 2008 12:29 pm    Post subject: highlander Reply with quote
We looked at the toyota when buying our Pilot. what year Highlander do you have The 05-06 had the 3.3 v-6 or the 2.4 4 cyl.the tow rating was 3500lb for the v-6 and 3000lb for the 4cyl.
The c-d16 weighs 875-950 lb , eng about 250lb and trailer about 500lb .So you are looking at less then 2000lb .As far as the tougue wt this can be manipulated by moving the winch stand a few inches one way or another. About 200lb would give you 10% .
use the Toyota save gas Good luck on your trip
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Tue Oct 07, 2008 12:49 pm    Post subject: Reply with quote
I used to pull mine with a toyota 4x4 with the old 4 cylinder and it did it without a problem. Tongue weight seems to be around 150 to 160 pounds.
bjidzik
City/Region: Juneau
Vessel Name: Betty Joe
Photos: Betty Joe
PostPosted: Wed Oct 08, 2008 2:03 pm    Post subject: Reply with quote
Our 16' Cruiser is loaded but we've had no problems towing with a 3.5L Jeep Liberty (3000-3500 lb max tow weight). Your Toyota Highlander will do just fine even on hilly roads.
Montana Kev
Vessel Name: Grace
Photos: Grace
PostPosted: Wed Oct 08, 2008 7:56 pm    Post subject: Jeep Liberty Reply with quote
Stopping is always the hard part. Sounds like it's not an issue from the feedback so fare, I think the Jeep Liberty is a good comparative vehicle to the Highlander. I was curious about the tongue weight just so I would know about how much sag to expect. Thanks for the feedback
Kevin
Page generation time: 0.0228s (PHP: 66% - SQL: 34%) - SQL queries: 20 - GZIP disabled - Debug on
