More Wallsa stove/heater trouble
garyk
City/Region: Ketchum
State or Province: ID
Vessel Name: AMIGO 11
Photos: Amigo II
PostPosted: Thu Sep 25, 2008 1:01 pm    Post subject: wallas stove problems Reply with quote
[quote="Captains Cat"]
" We got on the boat though to show him where things were and I turned the batt switches on to power things up."
I think the key word here is, " I turned the batt. switches on"... Much has been posted about, disconnecting the power from the wallas to reset the Mother Board. One post in this regard, gave though to putting a toggle switch on the power input to his Wallas because he had to use this "reset" so often.
Just a thought.
Gary
PostPosted: Thu Sep 25, 2008 4:07 pm    Post subject: Re: wallas stove problems Reply with quote
[quote="garyk"]
Just a thought.
Gary
Thanks Gary but I don't think so. I ALWAYS turn off both battery switches when we come in because I don't have shore power on the pier yet. I use a genset to operate the lift and depend on the engines to do the charging during our underway periods. I'll keep everyone posted on this one though.
PostPosted: Thu Sep 25, 2008 5:23 pm    Post subject: Reply with quote
Many times the Wallas is wired diretly to the house battery--and there is a fuse in line.
I was curious about where the exhaust is installed--on my Tom Cat, the exhaust is 3 to 4" ABOVE the DECK--not below the hull to deck joint. I have had not problems withe the exhaust.
PostPosted: Thu Sep 25, 2008 5:41 pm    Post subject: Reply with quote
Mine IS wired directly Bob. When I shut both batt switches off, the fan continues to run to cool down as it is designed to do.
I don't know about the exhaust, the pier is underwater right now, I'll look in the AM and post a picture if I can.
PostPosted: Fri Sep 26, 2008 3:55 pm    Post subject: Reply with quote
Well, the wind has dropped and the tide receeded a little. Here's a pix of the stbd side of the TC. The upper chrome hole (behind the mooring line) is the Wallas exhaust. Above the main deck a couple of inches. The other two overboards are for the sink and the shower sump respectively.
Rest assured, the mooring line is moved when I use the Wallas (which I haven't lately)
The other two chrome "bumps" just above the rubrail are the fuel vent (left), the holding tank vent (right) and the water tank vent forward just aft of the cleat.
helm
City/Region: Medford
Vessel Name: Chack Chack
Photos: Chack Chack
PostPosted: Sat Sep 27, 2008 12:48 am    Post subject: Reply with quote
consider two words as the solution to all your woes --- origo alcohol
PostPosted: Sat Sep 27, 2008 10:12 am    Post subject: Reply with quote
Or maybe just one word.
SCOTCH
Also an alcohol!! Cocktail Laughing
Page generation time: 0.0357s (PHP: 62% - SQL: 38%) - SQL queries: 20 - GZIP disabled - Debug on
