Kicker Lock On Sale Now
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Sun Sep 21, 2008 5:56 pm    Post subject: Kicker Lock On Sale Now Reply with quote
I'm on my third kicker lock (salt water) and just picked up what I'm sure will be the last. This one is all Stainless.
High Security Outboard Lock
Pete
ccflyer
City/Region: Bradenton, FL
Vessel Name: Retriever
Photos: ccflyer
PostPosted: Sun Sep 21, 2008 8:04 pm    Post subject: Reply with quote
I've had two Master padlocks in the past two years and I'm disappointed with both. My issue is salt water gets into the mechanism so it becomes impossible to get the key all the way into the keyhole let alone turn the key. I'm wondering whether this lock's keyhole is capped so salt water can't get in?
If not, I may just stick with the Master padlocks. At least at the end of the season I can cut off the lock with a Dremel. Cry
There is a very fine line between "hobby" and "mental illness".
Adeline
Photos: Adeline
PostPosted: Sun Sep 21, 2008 8:43 pm    Post subject: Reply with quote
No, it's not capped. I'm going to apply a Self Adhesive Bumper(as in drawers)to seal it up. I too have the Master Lock and salt water always finds its way under the plastic covering. This new lock is stainless. It's a thing of beauty really. Robust yet attractive. For $80.00(regularly $100) it should be.
PostPosted: Sun Sep 21, 2008 10:49 pm    Post subject: Reply with quote
I have gone through several dozen of the steel plastic coated (and several other) outboard locks. The brass locks seem to hold up fairly well, if you keep them lubed--but the steel rusts. Plus many small outboards have such small handles, that you can slip the lock off. Also it takes about 5 minutes to cut these locks off with a hack saw (if you loose the key--as I have)--actually you don't have to cut all of the way thru, just part way, and bend with Vise grips.
I'll have to look at these at West Marine--and see what the Port Supply price is...if it is equal to the on line price--thanks!
Adeline
Photos: Adeline
PostPosted: Sun Sep 21, 2008 11:26 pm    Post subject: Reply with quote
For those interested- On my '89 Johnson 15
Page generation time: 0.0422s (PHP: 67% - SQL: 33%) - SQL queries: 18 - GZIP disabled - Debug on
