Installing a powered sink faucet in a 22 C-Dory
NC-TFC
City/Region: Hampstead
Vessel Name: Pegasus
Photos: Pegasus
PostPosted: Thu Apr 10, 2008 9:35 pm    Post subject: Installing a powered sink faucet in a 22 C-Dory Reply with quote
We'd like to replace the foot pump faucet on our 22ft C-Dory. Does any one have experience with a good pump & faucet combinations that will easily adapt to the existing system?
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Thu Apr 10, 2008 10:04 pm    Post subject: Reply with quote
We put in a whale pump from iboats.com based on the recommendation of another site member. You use it in addition to the foot pump. I think the foot pump may be a whale as well. Some pics are below.
Rob
this is the pump...not much bigger than a roll of quarters
this is the momentary knee switch
PostPosted: Thu Apr 10, 2008 10:05 pm    Post subject: Reply with quote
NC-TFC
Try starting with this thread:
Reconfigured Galley
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Thu Apr 10, 2008 10:09 pm    Post subject: Reply with quote
I put in a Jabsco in line pump from Boaters World. They sell the pump with a faucet (part number 357400274) or just the pump. The faucet with the switch in it is pretty cheap so I kept the standard faucet and put a push pull switch in the face of the cabinet. I mounted the pump under the sink mounted to the side of the cabinet. Works well.
marvin
PostPosted: Thu Apr 10, 2008 10:11 pm    Post subject: Reply with quote
Here's another link-
Freshwater Pump
PostPosted: Sat Apr 12, 2008 12:00 pm    Post subject: Reply with quote
We have an electric pump, with a push/pull switch on the cabinet front, top left corner. Things I would change if I were doing it (again) since I didn't do it the first time: I would put a push-to-engage spring loaded switch. Use less water and less likely to accidently get left momentarily on. I would change the position of the switch to be forward facing on the cabinet, to avoid getting it bumped (raked) when passing in the walkway.
Hope that is helpful,
PostPosted: Sun Apr 13, 2008 10:57 am    Post subject: Reply with quote
Another faucet / sink installation:
Amazing how happy the First Mate is over this Moen mixer faucet! Less than an hour job.Moen #87315C.
From Dreamer's Sub- Album on Mechanical Installations and Modifications
Joe. Thumbs Up Teeth
NC-TFC
Photos: Pegasus
PostPosted: Mon Apr 14, 2008 9:56 am    Post subject: Thanks! Reply with quote
These are all great reply's and have given me food for thought. I agree with re-positioning the sink and moving the Wallas forward. I'm glad I posted this question I'd hate to do these projects 1 at a time. So it's off to the store for laminate, plywood and parts.
PostPosted: Mon Apr 14, 2008 2:20 pm    Post subject: Reply with quote
NC-TFC
Don't forget that many galley modifiers have chosen to also build flat countertop extensions that fit over the folded-down helm seat to capture some more working space in the galley. (Just a reminder as you do your planning.)
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Mon Apr 14, 2008 3:29 pm    Post subject: Reply with quote
Speaking of galley mods, I am surprised that no one (AFAIK) has installed countertops other than Decraguard. Any thoughts out there on that?
Doryman
M/V Lori Ann
Anacortes, WA
Minnow
City/Region: East Amwell
State or Province: NJ
Vessel Name: Minnow
Photos: Minnow
PostPosted: Tue Apr 15, 2008 11:09 am    Post subject: Reply with quote
I had thought about other materials, like granite, (too heavy and expensive) corian (too ugly and expensive), decragard (too hard to get and fragile for a countertop), so went with Formica. Antique white (932-5Cool is a real good match.
I had thought about going with a different color, maybe faux teak Formica, but thought it was too much, adding another color to the mix.l
Minnow
Vessel Name: Minnow
Photos: Minnow
PostPosted: Tue Apr 15, 2008 11:12 am    Post subject: Reply with quote
Not sure how that emo got in the post and I can't edit it.
The Formica is 932-58.
Page generation time: 0.0379s (PHP: 65% - SQL: 35%) - SQL queries: 25 - GZIP disabled - Debug on
