C-Ranger Wiring
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time
kimshack
City/Region: Mill Creek
C-Dory Model: R-21 EC Tug
Vessel Name: KIMSHACK
Photos: Kimshack
PostPosted: Tue Mar 27, 2007 1:17 pm    Post subject: C-Ranger Wiring Reply with quote
Does anyone have a wiring diagram for the C-Ranger 21? I would like to know how the Batteries, Isolater, Power Switch and Guest Charger are all connected to each other.
It appears that the motor is directly connected to Battery #1, and so even when the main switch is off the motor will start. John stated this is done so it will not blow out the diodes in the alternator if someone turns the battery selector switch.
So, if for some reason if Battery 1 is dead, then I'm assuming that I will not be able to start the engine from battery two by simply selecting the battery switch to Two, but would need to "jumper" it in the engine box.
Tugly
City/Region: Santa Barbara
Vessel Name: Tugly
Photos: Tugly
PostPosted: Tue Mar 04, 2008 12:04 pm    Post subject: Reply with quote
Kimshack,
Just got a PDF of the wiring diagram on the Ranger 21'. talked at length with Andrew Custis, tech guy at the factory and now understand how the system works. Contact me if this is still an issue for you and I will send the PDF file.
Ron Cowan
City/Region: Athens
State or Province: AL
C-Dory Year: 1985
C-Dory Model: 22 Classic
Vessel Name: Elk-Tenn
Photos: Elk-Tenn
PostPosted: Tue Mar 04, 2008 3:09 pm    Post subject: Reply with quote
Kimshack, If #1 is dead turn the switch to both to start the engine. #1 is wired to the engine. #2 is wired to all accessories through the switch and both are wired to both on the switch. Both are charged by the alternator and #2 is charged by the guest charger. This is my understanding from Andrew after lightening got my Guest charger.
I would love to get a copy of the PDF to verify that I am right.
Ron
Ready to go with the '85 22' Classic
PostPosted: Tue Mar 04, 2008 3:23 pm    Post subject: Reply with quote
Hey Tugly, how about putting the .pdf file in the documents section of the forum for reference?
Tugly
Vessel Name: Tugly
Photos: Tugly
PostPosted: Tue Mar 04, 2008 3:31 pm    Post subject: Reply with quote
Charlie, I just put them there.
Bill
Ron Cowan
City/Region: Athens
C-Dory Year: 1985
Photos: Elk-Tenn
PostPosted: Tue Mar 04, 2008 5:11 pm    Post subject: R-21 wiring PDF Reply with quote
Tugly, Thanks for the PDF posting. I must look at what I have done because I believe this shows the charger hooked to the engine battery and I thought Andrew told me the house battery. Thanks again. Ron
PostPosted: Tue Mar 04, 2008 5:45 pm    Post subject: Reply with quote
Looking at the diagram, the charger is connected connected to the Engine battery, and the Alternator is connected to the buss bar, which is connected to House (#2) battery. The charging relay is "A" to the alternator, and would preferentially charge the house battery, and then the engine start battery. This is backward from the way most boats are set up. (unless I am reading something wrong).
You want to have the charger on the house battery, so that when you are plugged in, the house battery will charge. The engine battery should preferentially charge from the alternator, and then the house battery after the voltage on the engine start comes up.
I would buy a two bank charger, and make sure that the engine start is preferentially charged.
Tugly
Vessel Name: Tugly
Photos: Tugly
PostPosted: Tue Mar 04, 2008 6:54 pm    Post subject: Reply with quote
If you have your charging relay on both, both batteries will charge. I don't see the battery isolator on this diagram and don't know how that might change the charging pattern. On my boat, the isolator is in the position of the battery buss.
Ron Cowan
City/Region: Athens
C-Dory Year: 1985
Photos: Elk-Tenn
PostPosted: Tue Mar 04, 2008 8:34 pm    Post subject: R-21 wiring Reply with quote
I am reading the diagram as you are but thought Andrew told me to hook the charger to the house battery. We discussed the two bank charger and he felt it was probably an overkill if in fact the eng. battery was only used to start. The alternator should bring it back up quickly and you were not taking it down bad with the start only. The house would be different and could be a deeper draw. He suggested to only use both if in an emergency condition of a dead eng. battery. Ron
PostPosted: Wed Mar 05, 2008 12:03 am    Post subject: Reply with quote
Tugley, generally the charging relay reacts to the higher voltage of a designated battery to close the relay and charge both batteries. The way that this diagram appears is that only the alternator accomplishes this. If you have a switch to close the charging relay--then you could combine the batteries whenever you want--but you will want a 1/2 / all/ off switch to combine the batteries. I don't see the switch on the diagram. Some of the charging relays allow for a "combine" switch--but these relays are only reated at 60 to 100 amps, not starting loads.
It is possiable that this specific relay is designed to close if either battery exceeds the theshold voltage; if this is the case, then the charger on one battery would charge the other. But this is not the usual setup.
Most owners spend more time at the dock--run various lights, sterio etc from the house battery--and like to keep this battery charged from the dock powered charger.
Tugly
Vessel Name: Tugly
Photos: Tugly
PostPosted: Wed Mar 05, 2008 3:32 pm    Post subject: Reply with quote
Thataway,
I think that I have my terms mixed up. On the diagram I was assuming that the box marked CHARGING RELAY was the battery switch that allowed one to do the 1/2/both/off stuff. I guess I don't know what a charging relay is. On my boat, if I have the battery switch on "Both", have the shore power attached, and check the voltage of the batteries, both are under charge. That is the position I use when I am using shore power, then both my starting and house battery are always up. When running, I still leave it on both to keep the batteries up, when I stop with no shore power, I switch to the house battery, I assume that is #2. The more I think about this, the more unsure I become.
PostPosted: Wed Mar 05, 2008 4:40 pm    Post subject: Reply with quote
Tugly,
That is the correct way to use the battery switch--and obviously your boat has the switch--which is not shown in the diagram. You probably do not have the charging relay.
Basically the relay separates the two batteries, untill the primary battery (hooked up to the alternator) reaches 13.6 volts (it can be varied in some, fixed in others). It usually stays closed as long as the charging voltage is above 12.7--at which point it opens, and isolates the batteries.
Some have a manual override--via switch in the console. Some have a high voltage cut off relay to protect some batteries like a gel cell (but I would not like to depend on this, because then the battery may be undercharged).
Hope that helps--the way you are rigged sounds fine. If you have the relay, you would not have to turn the switch.
acustis
Ranger Tugs Factory Rep
City/Region: Puyallup
PostPosted: Wed Mar 05, 2008 5:35 pm    Post subject: Wiring Diagram Reply with quote
Bob is completely right about the typical way of wiring. Our electrician made a mistake on this diagram. I have went over the corrections. Let me try and clear some things up on this wiring.
The battery charger we are putting on now is a one bank charger hooked directly to your house bank. We recently added in the positive bus bar due to too many connections on the batteries. We are in the process of switching chargers to a dual bank "smart charger" that automatically sense's 90-240 volts.
The battery switch we use is an off/on switch only which does not have a parallel option. The older 21 tugs did have a 1/2/both switch in them which was fine. It is shown in the diagram but not labeled.
The function of the charging relay is exactly what Bob Austin explained. That took the place of your battery isolator.
I hope this cleared alot of this up. Please feel free to email or call with any other questions.
Andrew Custis
Customer Service Manager
Ranger Tugs
denny48
City/Region: Peoria
Vessel Name: Tugger
Photos: Tugger
PostPosted: Sat Mar 08, 2008 9:10 pm    Post subject: Your Volvo 40 h.p. engine in your 21ec Reply with quote
Hi Kimshak,
In case you haven't been reading, there's been some postings about engine size recently. If my memory serves me, you have a 40hp Volvo in your 21ec. Several interested posters wondered about increased h.p. installed in our little tugs. We purchased one with the little Yanmar 30 h.p. and it seems to putt us along just fine burning about 2 pints per hour. If you have a chance, please post your experiences with your 21 Ranger Tug on steroids.
Denny
Marilyn & Denny
IT-SEA-BIT-C
Guest
PostPosted: Sat Mar 29, 2008 3:46 am    Post subject: Reply with quote
Hey kimshack, can't wait any longer do you have the 40 in your boat ? any real difference from the yan. 30. BOB, that thread cracks me up dude. when can i order my Austin 21-ec custom Very Happy . you never cease to amaize me . Ranger should pay you a ridiciouls amount of money to oversee the operation & in the end they would probably make back every nickel and then some , espiecally with no more war. work comming back Shocked were lucky to have you .......john
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time All times are GMT - 5 Hours
Page generation time: 0.1972s (PHP: 46% - SQL: 54%) - SQL queries: 27 - GZIP disabled - Debug on
