a few little glitches with new C-dory
gary allen
City/Region: Santa Rosa
Vessel Name: Rosy B
PostPosted: Mon Sep 06, 2004 10:21 pm    Post subject: a few little glitches with new C-dory Reply with quote
We received the Rosy B, our new 22 cruiser, last week, and I have been having great fun learning systems and getting on the water for the first time this weekend. I have a couple of concerns, however, and given the collective experience of this group, I was hoping for some advice.
The first one is I choose the twin motor option (twin Honda 50's), but the dealer (Guenter's here in northern California) installed motors with the propellors rotating in the same direction. I'm a novice boater, but several folks have mentioned that there should be counter rotation. Is it a major issue? I have seen other c-dorys with twin systems that have propellors rotating in the same direction.
Second, after launching and retrieving boat two times, I noticed some major scrapes all the way through the bottom paint on both sides of the hull, towards the bow. The scrapes are just off-center of the bunks. Any theories as to the cause? Could there be a bolt head that is not countersunk under the carpet on the bunks?
Third, the blige pump is not working on the auto function, but seems to work fine manually.
I'm planning to talk to the dealer tomorrow, but I thought I might be better prepared armed with thoughts from this group.
Thanks for any help,
Gary
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Mon Sep 06, 2004 10:42 pm    Post subject: Re: a few little glitches with new C-dory Reply with quote
Hey Gary - welcome to the Pub!
Normal, that's how they all are on C-Dory's. I don't even think you can get 50's spinning in opposite directions - only on larger motors.
That, or it happened during transit to Guenters. Either way, I'd ask Guenters to take care of it when you take it in for the bilge pump problem. They're good folks - I'm sure they'll take care of you.
So - heading up to Shasta with us in October?
Tux Will, C-Brat Nerd Tux
Anita Marie
City/Region: Oak Harbor
Vessel Name: Anita Marie
PostPosted: Mon Sep 06, 2004 10:54 pm    Post subject: Reply with quote
Gary, the bilge pump is fused on both the manual and auto side. I would check the fuse on the auto side. I had the same problem when I first picked up my boat.
Fred
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Tue Sep 07, 2004 12:08 am    Post subject: Re: a few little glitches with new C-dory Reply with quote
Gary
Congratulations Gary on your new C-Dory. Counter rotating props in outboards under 100 HP are not available. (The outboard manufacturers just don't build them). I have twin Johnson 50's on Sea Shift and with very little practice you'll be able to spin your vessel around in its' own length without touching the steering wheel. (Just set your engines straight, put one engine in forward and one engine in reverse at roughly the same RPMs and "let 'er spin"). Smile I've found it helpful more than once in tight spots and when docking.
Dave S.
"Sea Shift"
C-Brat #16
Levity
City/Region: Shippensburg
Vessel Name: Levity
Photos: Levity
PostPosted: Wed Sep 08, 2004 10:27 am    Post subject: Reply with quote
Hi Gary,
The gouges on your hull at the bow may be caused by contact with the aft end of your trailer's tongue frame member. Over submersion of your trailer bunks will allow the bow of the boat to make unpleasant contact with this frame member. The foward bunks should be no more than 50% submerged when launching and retreiving as they are designed to lift the bow away from the aft end of the tongue frame member. There is a thread under Hull and Deck Fittings called Gel Coat Repair where you will find more on this subject and how to find correct color gelcoat to make a good repair.
Levity's Michael
wilbe asea
City/Region: Kenai
Vessel Name: Sunset Ride
Photos: Sunset Ride
PostPosted: Thu Sep 09, 2004 2:44 am    Post subject: Reply with quote
As far as the trailer tongue gouging the boat, the first thing I did to my trailer was to install a roller at the aft end of the trailer tongue, I don't think I have used it but once, no evidence exists on either the boat or roller.
Page generation time: 0.0583s (PHP: 42% - SQL: 58%) - SQL queries: 19 - GZIP disabled - Debug on
