Fogging a suzzuki 90 for the winter
depperson
City/Region: Juneau
Vessel Name: Mary Ann
Photos: Mary Ann
PostPosted: Thu Sep 25, 2008 11:34 pm    Post subject: Fogging a suzzuki 90 for the winter Reply with quote
Not sure if I am doing it right, but spraying fogging oil in the air intake, tried several cans but can't get the engine to stall out? Is there a better way to do this? Thanks very much.
DeanO
helm
City/Region: Medford
Vessel Name: Chack Chack
Photos: Chack Chack
PostPosted: Fri Sep 26, 2008 12:19 am    Post subject: Reply with quote
I don't know what year your engine is but if it is fuel injected it won't die and you shouldn't fog, at least from what the guys on the Michigan pennisula told us when we left our boat in Mackinaw City. If it has a carb go for it.
PostPosted: Fri Sep 26, 2008 7:28 am    Post subject: Reply with quote
Did you disconnect the gas line? You should, then as it starts to sputter, fog it. Then remove spark plugs and fog inside the cyls and crank it over a little to distribute the oil. Then reinstall the plugs, hand tight.
Good luck. Make sure the fog oil is getting into the air intake.
PostPosted: Fri Sep 26, 2008 8:54 am    Post subject: Reply with quote
I can understand that a fuel injected engine with it's computer would compensate with rpm and fuel/air mix adjustments to avoid stalling, but what about oiling up the internal parts for the long storage period?
Don't the Evinrude etech engines have a pre-storage mode that is programmed to set the engine up for storage?
Page generation time: 0.0574s (PHP: 35% - SQL: 65%) - SQL queries: 17 - GZIP disabled - Debug on
