Truck campers and towing CD 25
PostPosted: Tue Aug 26, 2008 9:09 pm    Post subject: Truck campers and towing CD 25 Reply with quote
We are looking very seriously at a 2007 Chevy 4x4 2500 HD as our tow vehicle on the West coast. Currently I have a 1993 Road Trek--which does not have the tow capacity for the CD 25--and is my "condo" when visiting my children/grandchildren. We would put a truck camper on the pickup and that would become the "condo"--this also has the advantage of allowing my son to keep the truck (alone) at his condo to launch the CD 25--and sell his Expedition.
I am considering a folding top camper (to keep weight and windage down) in either a Pine mountain or Palomino brand. The Palomino I like best, is a 9'6" floor length--which means that the aft 18" of the camper hangs off the back of the truck bed. How much will this interfer with my trailering?
Other thoughts about pickup/campers on tow vehicles. My other option is a newer Chevy Road Trek or class B, which does have the capacity to tow the 25.
Thanks!
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Tue Aug 26, 2008 10:17 pm    Post subject: Reply with quote
Bob,
Although I have a 1 ton dually, I carry a 9'10"" Lance camper and tow my 22 with an extension bar. I installed a Reese Titan Class V hitch with the 2.5" square receiver. This set-up tows very well even with the 24in extension stinger. Many campers sit high enough in the truck to allow towing without an extension if your boat trailer tongue is long enough. My 22 is light enough to tow without an equilizer-the 25 would probably require one. You do need to know the weight of the truck, camper and boat to make sure you don't exceed the Gross Combined Vehicle Weight.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
Darkwater
City/Region: Fort Bragg
Photos: Darkwater
PostPosted: Wed Aug 27, 2008 1:45 am    Post subject: Reply with quote
Bob-
You might add Northstar pop top campers to your list. We are happy with the quality of our Northstar TC 650, which is designed to fit short bed trucks without extending beyond the bed. We have a 2003 Chevy 2500HD duramax crew cab. With the camper on the bed (1400 lb), and towing our 23 ft sea ray cruiser (6000 lb including trailer), I feel we are nearly maxed out, not in terms of raw tow capacity, but in terms of ride quality over humps in the road. Perhaps a load leveling hitch would improve the situation somewhat and allow more weight. Northstar makes a TS1000 designed for 8' truck bed and might be to your liking.
Anyway, if you want to haul a nice roomy pop top camper (1900 lb?), while towing a CD25 loaded with gear fuel and water, you might be happier (and safer) in the long run with a 3500HD with dually's.
Darkwater Doug
Fort Bragg, Calif
Boat and fishing obsessed...
C-Ray 230DA sold Aug 2013
Retired Dec 2013
2008 C-Dory 22 Cruiser (unnamed) Jun 2014
Cerahotl
City/Region: Fort Smith
State or Province: AR
Vessel Name: Prints of Whales
PostPosted: Wed Aug 27, 2008 3:10 am    Post subject: Reply with quote
I previously owned a 8' Palomino on a half ton Ford and had no problems camping over much of the midwest and on the east coast. The camper held up well and the lower profile of a crankup is appreciated at the gas pump and in less sway in strong crosswinds. At the time we towed at 17' Lund Fish and Ski and the combinations was comfortable in every aspect but breaking and that little boat pushed you down the road a lot further than you wanted in a panic break, so trailer brakes are a must even if you are below the weight requirement and opt for brakes on both axles if you have a choice.
Having moved to Alaska a few years ago, we decided it was time to move to something a little bigger and better insulated and traded up to an 9.5' Alpenlite carried on a 1 ton Dodge dually 4x4 powered by the Cummings Diesel which I felt was the minimum tow vehicle for a CD-25 and 2 tons of camper. The extra width of the dually's means almost no sway and I like the safety off not worrying about a rear tire blowout coming down a switchback.
We haven't been disappointed in the choice of the truck. Fuel usage is highly dependent on headwinds and cross winds but with both camper and boat and mountains almost anywhere I want to tow, I still get between 11 and 14 mpg driving the speed limit for towing -- 55 MPH. With only the camper or the boat milage is 13 to 16 and without them milage for the truck is 17 to 19 even running at 65 MPH. My buddies running gas rigs say they are lucky to get 12 MPG without a haul or a tow.
I did a lot of research before settling on the SuperHitch by Torklift with a 24" truss reciever extension. With the heavy duty springs on the truck I've had no need for a load leveling hitch. Torklift also makes great tie downs for your camper. The hitch/reciever/tiedowns come in as spendy as a camper back for the C-Dory or about $1600. You can order online from TL Central and save some bucks on the hardware over distributor price (the local dealer here marked them up almost 100%) and installation will run you about $250 for both the hitch and the tie downs.
Hope this gives you a reference point or two...
Terry
Swee Pea
City/Region: Bath
Vessel Name: Swee Pea
Photos: Swee Pea
PostPosted: Wed Aug 27, 2008 7:28 am    Post subject: Reply with quote
I recently purchased a Northstar Freedom (hardside) truck camper for my 1/2 ton Ford 4x4. I was able to still utilize my Ford OE hitch because I changed out my surge brake actuator for a low profile model. (see my photo in Swee Pea photo album). Luckily, I did not need a hitch extension because my boat trailer tongue fits under the truck camper overhang and my trailer tongue is long enough not to interfere with sharp turning. With the 3/4 and 1 ton trucks, there are hitches that allow long extensions without great loss in towing/tongue weight, as have been mentioned in previous posts. They are not available for 1/2 tons, so I lucked out.
I think you should seriously look at the Northstar line of truck campers. If you have any questions, call Rex Willett at Northstar and ask. Their company reminds me of the old C-Dory crew, who you could call and talk to for any info. He will keep you on the phone as long as you want. He is the owner and VP of Northstar. Northstar is a very respected company in the truck camper industry (thats all they build).... And no, I do not have stock in the company. Just very happy with the product and service. http://www.northstarcampers.com
Swee Pea
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Wed Aug 27, 2008 10:08 am    Post subject: Camper opinions Reply with quote
Bob,
I will toss my 2 cents worth in.
We have a 2000 F250 diesel, automatic, 4x4. A Caribou 10F camper, and a Superhitch receiver with 3' stinger.
I like the truck, but a 3/4 ton is not enough for a camper of this size (3300# dry). I added airbags, but would recommend a 1 ton, and dual tires for weight and stability reasons.
The Caribou camper is an abomination of poor workmanship and poor quality materials. It was made by Fleetwood, and I am of the opinion that it was made by morons. The nose cap has cracked and allowed water intrusion. The cap at the rear was improperly sealed and allowed water intrusion down the rear wall. I occasionally find staples with my finger tips. The rubber roof started to deteriorate until coated with a latex sealant.
The Superhitch is great. It has a twin bar stinger that is stabilized with chains to the side of the receiver.
Back on the topic of campers, I would look seriously at a completely fiberglass, monocoque construction. The two that I am aware of are Bigfoot and Northern Lite. Both are highly weather tight when compared to a conventional frame and panel camper. They are usually lighter unless loaded with all the options, and then I think they are roughly equal in weight to the conventional camper.
Steve
patrick and linda
City/Region: somerset
State or Province: KY
C-Dory Year: 1986
Vessel Name: "Fan-A-Sea"
Photos: Misty Seas
PostPosted: Wed Aug 27, 2008 10:35 am    Post subject: Reply with quote
i'm seeking wisdom as well on this subject, although my situation is slightly different. i have recently purchased a motorhome and plan to trailer either my c-dory or a small vehicle with it. not sure exactly what to expect when launching the boat. also, i have found a company that manufactures an amphibious jeep. i have emailed them for pricing, and think this might be an interesting combination. you can check it out at www.watercar.com .
on a personal note, dr. bob, my son is now gainfully employed and thus the blood letting has stop. i can now stand up without feeling light headed!
pat
Sam Walker
City/Region: Wherever the RV is today
State or Province: SD
PostPosted: Wed Aug 27, 2008 10:46 am    Post subject: Reply with quote
Hi Bob, it is not often that I feel qualified to provide input here. Especially to you. You normally have everything so dialed in. So here goes. I have owned multiple RV's and trucks over the years and researched many others that I have not owned. I like the idea of the 4x4 truck for the launch ramps and for its unloaded versatility. If I were in your position, as several of the other folks have said I would be looking at least to be in a one ton or a 450. The reason is that there is always weight creep. One thing leads to another and pretty soon you are at or over the GCWR. I think that you are on target w/ the low profile camper w/ towing the 25. I would definitely go to a 450 chassis if a full sized hard wall camper becomes the choice. Those things can weigh up over 4000# then throwing the 25 on the back of that would put me into the creepy zone on a one ton and in the no way catagory for a 3/4 ton.
I would be really hesitant to try to pull a 25 on an extended hitch. What is the max tow rating when you use an extension? The ones that I have seen lower the tow rating.
As far as the RV portion goes, Four Wheel Camper out of Woodland, CA might be another alternative for a camper. Generally speaking, depending on layouts, the the liveability of a camper should be similar to the Roadtrek. Except for bathroom shower arrangements. Door access on the fold downs can be an issue.
The new truck and camper should also be less expensive than a new Roadtrek.
I will be watching this one. I am interested to see where you end up and why.
Sam on C's The Day or maybe Marinauty (Someday)
It does not matter how many moments that you take a breath, It is how many moments take your breath away.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Wed Aug 27, 2008 11:36 am    Post subject: Reply with quote
I had a Four Wheel Camper for several years. I was never very happy with the build quality.
Quite a while ago I got a PM from HunkyDory who recommended I look at the Hallmark and the Apex 9.5 popup campers. If/when I am in the market for a camper for my new truck I will definitely be looking at these two.
Doryman
M/V Lori Ann
Anacortes, WA
Jim Gibson
City/Region: Sacramento
C-Dory Year: 1998
Vessel Name: Pounder
Photos: Pounder
PostPosted: Wed Aug 27, 2008 12:53 pm    Post subject: Reply with quote
Bob-
I have a 2500 HD Chevrolet truck, 3/4 ton truck with the Duramax Diesel and the Allison 5 speed. Mine is a 2004.
I would highly recommend this vehicle for your West Coast tow truck, but only with the Diesel and the Allison.
This is a wonderful truck, a true beast with 600 pounds of torque but still gets about 20 MPG with no trailer! This truck could pull your 25 footer up and down the Grape Vine all day with no problems. It also has a nice breaking feature going down hills that breaks the trailer for you under engine and transmission compression.
Best of Luck in Your Vehicle Search.
Jim on M/V Pounder
And the C-Tales Continue
Doryman
Photos: Lori Ann
PostPosted: Wed Aug 27, 2008 2:22 pm    Post subject: Reply with quote
Thank you for bringing this up as I have been wondering if the tow/haul and the manual shift features on my new Allison/Duramax are equivalent to and as effective as an an actual exhaust brake?
PostPosted: Wed Aug 27, 2008 3:04 pm    Post subject: Reply with quote
Hi Warren,
Having had exhaust brakes on several of our coaches, I think the tow/haul feature on the Duramax w/Allison (actually a transmission retarder) is every bit as effective as an exhaust brake, if not more so.
You're gonna like that truck.
PostPosted: Wed Aug 27, 2008 3:07 pm    Post subject: Reply with quote
We haven't heard from Brent, yet, but he made a triple receiver hitch to be able to tow his TomCat with his truck camper - nice piece of engineering.
That's the best solution to towing that I've seen with a camper that hangs over the truck bed.
PostPosted: Wed Aug 27, 2008 6:19 pm    Post subject: Reply with quote
Thanks for the great responses, and putting out several ideas and truck campers which I had not seen before. Surprisingly there are a lack of truck camper dealers in Florida. The nearest ones are in N. Alabama, and they only order in a model you are willing to buy site unseen.
To answer a couple of questions. Yes, we already use a weight distrubting hitch. We have disc brakes on both axles of the trailer--and when towing with my 30 foot Class A, I rare touch the brakes, because I gear down and start at a low speed at the top of grades.
There are great buys in the diesel dually trucks. The sales manger of the local Dodge dealer called me first thing this AM, knocking another 7% off a new long bed diesel dually which already had 35% off sticker price. The problem is that I don't think I can get a dually thru the gates to my daughter's back yard, in fact I may not be able to get a truck camper thru these gates--which she will measure this PM. I thought I had a "deal" on a 2007 Road Trek--but it was not a model which had enough room for me to sleep comfortably.
So we are still looking. I do think that a single rear wheel gas engine will suffice for us--we only tow any distance twice a year--and most of the time my son tows only a couple of miles on the level to the ramp. As much as I like diesels (economy, longivity, torque etc), the economics don't make a lot of sense unless I can get one for close to what a gas engine runs. With Diesel being a dollar a gallon more than gas, this almost negates the better economy, and 6 to 7,000 dollars difference does buy lot of gas in the differential of the current prices. Any camper we buy will be light weight--in the 1500 lb range. I don't carry a lot of gear in it, so we will not be over the weight capacity of about 3400 lbs of a 3/4 ton. I guess I will just have to see how the clearance of the winch post is, but I have 36" at least, since that is the length of my equalizing bars to the tongue pole cross bar adaptor.
I am looking at all of the alternatives you all suggested--thanks again.
Flyer
City/Region: Littleton
PostPosted: Wed Aug 27, 2008 6:39 pm    Post subject: Reply with quote
You may want to go with the 35xx series of trucks regardless of the camper you choose. There is not much reserve capacity left on a 25xx series truck when you get right down to it. The 25xx will tow a lot but the camper and the boat tongue weight may get you. If you are looking at a light camper consider the SRW 35xx series.
For a new gas rig there is only one truck out there with what would be considered a big engine and that is the Ford V10 which has of late been getting very good reviews.
We had a big Lance on a DRW GMC and it worked well towing an 8500# boat. We are now looking for a smaller camper and the boat will probably be a little lighter as well.
Rick Cool
Page generation time: 0.172s (PHP: 26% - SQL: 74%) - SQL queries: 32 - GZIP disabled - Debug on
