jlgray
Joined: 05 Feb 2007 Posts: 29 City/Region: Marysville
C-Dory Model: R-25 Tug
Vessel Name: Laurie Ann
Photos: Laurie Ann
Posted: Mon Aug 25, 2008 1:45 am Post subject: Distance Trailer Towing without the Boat |
We will be dropping our boat in the Mississippi for an extended boat trip and then bringing the truck and trailer about 1,000 miles to meet it. When I have done a shorter trip, the empty trailer bounced so much it made for a very uncomfortable ride.
What can we do to make the ride smoother? I have heard of reducing the air pressure in the trailer tires or carrying a sizable weight on the trailer. _________________ John & Laurie
"Laurie Ann" C-Ranger 25
Owners since 2007 |
Will-C
Vessel Name: Will-C
Photos: Will-C
Posted: Mon Aug 25, 2008 11:30 am Post subject: Distance Trailer Towing without the Boat |
Hello,
I would make sure to have all the wheels on the trailer balanced. Lower the air pressure to lowest recomended setting. I'm guessing about thirty pounds. The weight thing would calm things down but outside of some sort of water tank that you could drain I'm at a loss. Good Luck!
D.D. |
Posted: Mon Aug 25, 2008 11:49 am Post subject: |
If you have electric/hydraulic brakes, remember to turn the gain down on the brake controller. Or you'll smoke the tyres.
We've towed our empty trailer over several bouncy roads and it tracked well. Don't have any specific answers, but it's a 7500# E-Z Loader, and a 3/4 ton truck.
Good luck, Boris |
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
Posted: Mon Aug 25, 2008 12:00 pm Post subject: Re: Distance Trailer Towing without the Boat |
jlgray wrote: |
What can we do to make the ride smoother? I have heard of reducing the air pressure in the trailer tires or carrying a sizable weight on the trailer. |
I wouldn't put any substantial weight on the trailer because it can only drop fuel mileage accordingly. I would, however, lower the tire pressures and balance the tires as recommended by the posters ahead of me.
Our dual axle Pacific trailer seems to track quite well and I've never felt any trailer bouncing transmitted to the tow vehicles I've used it with while empty.
2003 4Runner
2001 Silverado 2500
2006 E450 based Class C motorhome
Don _________________ Mary & Don Anderson
Brat #483
"C-Brat" 1993 C-16 angler/50 hp |
Joined: 02 Nov 2003 Posts: 20812 City/Region: Pensacola
Posted: Mon Aug 25, 2008 1:45 pm Post subject: |
wonder if it is the type of suspension which is causing the "bouncing" issue. I have had that with some trailers in the past--but last year, towing an empty trailer 1200 miles it was no problem. This trailer had torsion axles, which seemed to cause less "bounce".
I believe that most of the mileage reduction is when pulling a trailer on level ground--is wind resistance. With some weight on the trailer and without wind resistance increase, the decrease in mileage will be much less than with the boat on the trailer.
On the other hand--it is often not practical to put weight on the trailer. Sand? Water? what do you put the "ballast" on or in?
I agree, drop the air pressure, and maybe drive slower...Incidently some of the freeways have segments which cause bounce, even with the boat on the trailer. _________________ Bob Austin
Posted: Mon Aug 25, 2008 1:51 pm Post subject: |
Quote: | Incidently some of the freeways have segments which cause bounce, even with the boat on the trailer. |
Yeah, they're called Interstates.
Boris |
Island Ranger
Joined: 02 Jul 2004 Posts: 326 City/Region: Whidbey Island
Vessel Name: Island Ranger
Photos: Two Lucky Fish and Island Ranger
Posted: Mon Aug 25, 2008 8:28 pm Post subject: |
I sure hope you can figure it out. When I towed my empty trailer back from Kent to Whidbey, it was an awful ride....
Mac |
Posted: Mon Aug 25, 2008 8:57 pm Post subject: |
A tandem or triple axle trailer will tow much more evenly than a single axle trailer, which has much more of a tendency to bounce around on it's single point of contact on each side of the trailer.
C-WEED
Joined: 14 Mar 2004 Posts: 338 City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
Posted: Mon Aug 25, 2008 11:30 pm Post subject: |
I would drop the air pressure and remove the tires from the front axle. I would think a heavier tandem trailer would run smoother, when empty on two tires than it would on four. Make sure you have clearance at the hubs. You even get a free set of spare tires for the trip. Just strap em over the back axle for more weight.
Twice the tires = twice the bounce for every bump. My aluminum I beam tandem bounces like a basketball just going across the parking lot after a launch.
If you have side bunks. You might run a strap or rope across the front and rear of those to keep tension. This will help cut down on those vibrating back and forth when the trailer bounces. _________________ Chris |
Posted: Mon Aug 25, 2008 11:45 pm Post subject: |
I vote with Joe--the tandem axle trailers are smoother when towed light. The more road contact--just be sure that both wheels are equally on the ground--and that may mean a different tongue height. Many trailers will run on one set of wheels when unloaded--and this may be the case in your trailer when you ran light before. |
Posted: Tue Aug 26, 2008 9:32 am Post subject: |
I have one single, two tandem, and one triple axle trailer, and the tandems and triple run much smoother than the single unloaded. The triple is even significantly smoother than the two tandems!
That experience, plus the logical analysis of why the increased number of axles resist bouncing around on a single tire on each side, led me to my post above.
The more axles you have, the more the trailer will "crawl" over the humps, bumps, and potholes. This is opposed to the single axle trailer where a single wheel / point of contact on each side "launches" on each significant road irregularity.
Joe. |
drjohn71a
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
Posted: Tue Aug 26, 2008 9:59 am Post subject: |
Joe,
Not to mention that each additional axle increases the weight substantially!
John |
Chester
Photos: Chester
Posted: Wed Aug 27, 2008 1:25 am Post subject: |
I agree with C-WEED, just run tires on one axle. Less chance of brake lock up, the tires are less likely to start cupping and the tires and suspension will be a little closer to their designed load. Many semi-trailers have air lift axles for just that reason. |
Posted: Wed Aug 27, 2008 1:35 am Post subject: |
There are apparently at least two or more different theories as to how to best get a good ride out of an empty trailer.
I suspect that the best method may depend on your exact combination of trailer and tow vehicle, so the recommendation would be to try the various suggestions and see which one works best for your set up and driving style.
Joe. |
Posted: Wed Aug 27, 2008 7:00 pm Post subject: |
Interesting, that the folks who propose running on one axle, have 22's--lighter boats and trailers, than those of us who have larger trailers, more like what the Ranger Tug will have.
I can see lots of problems with pulling the wheels and holding up the axles--not sure that brake lock up is more likely with the wheels off. I don't know about the cupping. I did have some of that on my trandem last year--no load for 1200 miles--about 4000 miles with a load--and the wear didn't show up until we were near the end of the trip. I have also had cupping on the front wheels of my Honda Pilot which I have towed behind my RV more than I have driven.
I thought that the lift axles were for over load--not taking wheels off the road when traveling light....At least that is how they are used in Florida. |
