Cockpit mount for Dinghy Motor
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Sat Aug 16, 2008 10:43 pm    Post subject: Cockpit mount for Dinghy Motor Reply with quote
So I decided to buy a motor for the Dinghy, but where to put it? After lengthy consideration I decided to mount it in the cockpit. The Honda 2hp is small and weighs only 28lbs, so thought it would be possible to squeeze it in the corner by the port laz, and still have enough room for the cooler and cleaning table.
The bracket is actually a stainless steal moving handle that was used for a 400lb clinical chemistry analyzer, new I’d have a use for it someday; all I had to do is cut off some pipe and drill a few holes.
Mounting holes drilled into Port laz.
Some 520 and positioning of top spacer
Bracket in place
Picture from inside laz, had to split the top washer because I misjudged to thickness of the top.
Motor in place
Motor in place with clearance for cooler/cleaning table. Tight fit but isn’t everything on a CD
Boatless for now but looking
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Sun Aug 17, 2008 12:57 am    Post subject: Reply with quote
Good question !
Me too !
Pete
anchorout
City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
PostPosted: Tue Jan 07, 2014 11:51 pm    Post subject: dinghy motor mount Reply with quote
Another way. This mount is made of 1/2" marine ply and slides in between the forward transom and 1" tubing bar. Detailed on EZ DUZIT's album.
PostPosted: Wed Jan 08, 2014 2:35 am    Post subject: Reply with quote
EZ DUZIT (nice boat shed!):
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Fri Jan 10, 2014 6:39 pm    Post subject: Dinghy Reply with quote
Nice
I mounted my bracket on the rails and it has worked well. Very secure even in chop. I also lock mine when away from the dock.
Captain Matt
Page generation time: 0.0246s (PHP: 75% - SQL: 25%) - SQL queries: 22 - GZIP disabled - Debug on
