Radar antenna installation
Chester
City/Region: home
Photos: Chester
PostPosted: Wed Aug 13, 2008 1:50 pm    Post subject: Radar antenna installation Reply with quote
On a C-Dory 22-Cruiser is the Radar antenna installed parallel to the roof or does it need a wedge to achieve best performance?
Thank you, Steve.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Wed Aug 13, 2008 3:37 pm    Post subject: Re: Radar antenna installation Reply with quote
Thank you, Steve.
That's a point of great debate actually. The vertical beam for radar's is right around 22-24 degrees, so 12 down and 12 up from the center plane on the radar unit.
I see boats with the down angle and those without. I chose a 2 or 4 degree angle for my setup.
Captain Matt
PostPosted: Wed Aug 13, 2008 10:40 pm    Post subject: Reply with quote
If you are going dead slow (which you may be in very limited visability), then the beam will be close to parallel with the lines of the cabin top. If you are going at displacement speeds--up to semi displacement speeds, you may be up 5 to 8 degrees--and at a plane you are often at a bit of an up angle. However, I have always installed my radars parallel to the cabin top, and found that I had good radar visabilty at all speeds. Theoretically the down angle of 5 degrees could be justified.
Les Lampman
Dealer
City/Region: Whidbey Island
PostPosted: Thu Aug 14, 2008 12:05 pm    Post subject: Reply with quote
I'll further add (to what Bob said) that your "need" for what the radar does often changes with speed.
When it's absolutely horrible and you're dead slow you really want the radar to "see" closer in (and regardless of the angle it will still see targets worth knowing about further out).
If it's not quite so bad and you can run at just over displacement speeds the nose will lift a bit and in these conditions (since you can physically see close in) you want the radar to "look" a little further out.
If you're using radar at cruise speed it usually means you're using it to pick up distant targets (primarily for navigation as opposed to collision avoidance) and you want the radar to "see" way out yonder.
If the radar is parallel with the resting waterline of the boat all these things happen automatically on planning hulls.
Les
www.marinautboats.com
Chester
City/Region: home
Photos: Chester
PostPosted: Thu Aug 14, 2008 12:15 pm    Post subject: Reply with quote
Very good, thank you for the responses.
Chester
City/Region: home
Photos: Chester
PostPosted: Fri Aug 15, 2008 9:58 am    Post subject: Reply with quote
We looked at some photos of Chester sitting in the water and the roofline is very close to being parallel with the waterline.
Todd at Portland Marine Electronics said the Seaview(?) radar riser has a little wedge built in so I told him not to install an additional wedge.
Page generation time: 0.0413s (PHP: 61% - SQL: 39%) - SQL queries: 19 - GZIP disabled - Debug on
