air conditioning for 22ft cruiser
hunk e dory
City/Region: lovettsville
C-Dory Year: 1992
Vessel Name: HUNK E DORY
PostPosted: Thu Jul 31, 2008 10:00 am    Post subject: air conditioning for 22ft cruiser Reply with quote
my wife has asthma, need to add some kind of airconditioning for use at night, we have shore power. has any one used one of the portable vented airconditioners, if so how btu and was the unit able to cool the cabin.
Bob, Paula and Pop-eye (the sheltie)
paula and bob
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Thu Jul 31, 2008 10:13 am    Post subject: a/c Reply with quote
We had a c-22 cruiser 1999 so the front opening windows should be the same you can put a cheapo a/c from walmart for about $90 with shore power you will freeze yourself out of the cabin Its well worth the money
look into forums and look up a/c then you will see the a/c in the front window
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Thu Jul 31, 2008 12:19 pm    Post subject: Reply with quote
Bob and Paula,
I know many have been happy with the small window A/C units, and that is fine if that is what you want.
I have tried several of the portable "roll around" type A/C units and I prefer them. They usually have dehumidifying settings which really gets you back into a sweet, dry interior after sitting at the dock a long time.
The BtU ratings can be a bit misleading. I had a single hose vented 11,000 BtU unit that did not evaporate the condensate water well at all, so it had to be drained with a hose off and on, or the tank emptied.
When that unit failed, I found a De Longhi 9,000 BtU unit with DUAL VENT HOSES - one drawing outside air in and the other exhausting hot air off the coils and as such carrying off the condensate water without a hitch.
The 9,000 BtU De Longhi cools much better than the 11,000 BtU single hosed unit which had to draw outside air into the cabin thru a cracked window, etc., to work. That kept the hot, moist outside air coming into the cabin.
Right now many of these units are on sale at the discount stores and they are smaller than ever. I keep mine in place with the black rubber bungee cords, so it is easily moved or removed. The C-Dory 22 could probably get by easily with a 5-7,000 BtU unit.
Also, these units often have HEPA filters built in, which should help your wife's condition.
Whatever works well for you!
Page generation time: 0.0529s (PHP: 37% - SQL: 63%) - SQL queries: 20 - GZIP disabled - Debug on
